| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | |
| Senior - BHPian Join Date: Dec 2004 Location: pune
| Quote:
__________________ Drive fast, but drive safe. | |
| | #18 (permalink) |
| BHPian Join Date: May 2005 Location: Chd
| I guess for all Euro II cars 87 Octane should be ok. the contentious issue is about using higher octane fuel for Euro III cars. The general opinion here seeems to be that Engines with a higher compression ratio benefit from the higher Octane. So a Euro III Getz with a 10:1 compression shd benefit more from a 91 Oct Fuel as compared to a Euro III Baleno with a 9:1 compression ratio. Hopefully someone can put more light on this. |
| | #19 (permalink) | |
| BHPian Join Date: Aug 2005 Location: pune
| Quote:
| | #20 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Navi Mumbai
| Quote:
GETZ manual reccomends Octane 87 and Up as regular fuel along with optional additives for better economy and longer engine life. I personally found little diffrence in getz but the car is only one week old. My Santro on the oother hand improves in the bootm end torque on the higher octane( This is 1999 Santro - One of the few old origanal Epsilon engines) No idea of compression ratio though
__________________ It is never too late.- get your safety options right | |
| | #21 (permalink) | |
| BHPian | Quote:
1. Plain Regular 87 Octane: Lots of knocking at RPM below 1500, poor acceleration, poor average (12Kmpl highway, 10Kmpl city) 2. Regular 87 Octance + System G: Some knocking below 1500 RPM, slightly improved average (13Kmpl highway, 10Kmpl city) 3. Speed / Power: Moderate knocking below 1500 RPM, lots of knocking while accelerating in 4th and 5th at almost all RPMS! (This was a big surprise to me too!). 13Kmpl highway, 10Kmpl city. 4. Xtrapremium: No knocking right down from 1000 RPM! Slight knocking below 1000 RPM, but this is really asking for it... Great average... as high as 17Kmpl on the highway once, but normally 15Kmpl highway, 12Kmpl city. Best acceleration too... no knocking = lots of torque! I have not tried Speed 93 or anthing with a higher octane rating than Xtrapremium. I tank up on the Mumbai - Pune Expressway and actually let my car run on fumes to reach the only pump selling Xtrapremium! I may be wrong though... maybe my car is setup with an advanced / retarded ignition timing that gives a good performance with a slightly higher octane fuel, but makes it incompatible with the lesser stuff. My dad's carburetted '96 Esteem runs pretty well with the regular 87 octance and performs best with "Power"... nothing special happens with the more expensive higher octane fuels. - T u r b o C - | |
| | #22 (permalink) |
| BHPian Join Date: Aug 2005 Location: Kalyani, West Bengal
| Most of today's cars like Honda City, Accord, Corolla, Palio, Optra have knock sensors, which is nothing but a sophisticated and insulated high quality microphone attached to the engine block. What it does is monitor for engine knock and then tells the ECU to retard timing, leading to loss of power, using high octane fuel is one good way of assurance that knock won't occur, specially on hot day with a/c running and vehicle heavily loaded going uphill. One of the reasons for better mileage with high octane fuel is due to the engine running at its full efficiency rating and thereby developing its rated power. This means that the driver doesn't have to hold the throttle for longer duration to get to his/her desired power. Same thing with additive added higher cetane diesels like Turbo Jet etc. Not only do they keep injectors and combustion chamber clean, the high cetane ensures better burn preventing power robbing knock, specially in turbo diesels. One thing I would like to point out, if your vehicle suddenly develops knock using your regular brand of fuel, then using higher octane/cetane is stop gap measure, you have other problems looming like incorrect timing, bad plugs, clogged inkectors and most likely culprit, carbon build up inside the combustion chamber.
__________________ 1997 Trax Gurkha 1996 VFJ Jonga 1995 Accord V6 1995 Honda RC 45 Last edited by Gurkha : 23rd September 2005 at 22:59. |
| | #23 (permalink) | |
| Quote:
That's a very good analysis. I hope you are talking about XtraPremium 91 Octane fuel from Indian oil? I have topped up my tank for both the Baleno and the swift with this XtraPremium fuel. It's about 1.5 Rs costlier per litre to normal 87 Oct. Let's see the effect on FE and driveability.. ( i do notice the Baleno to be a tad..quicker at low rpm's but that cud be a illusion!).. BTW pardon me for the ignorance..but what do you mean by System G - are these the Iftex additives. Last edited by imjimmy : 27th September 2005 at 12:45. | |
| | #24 (permalink) |
| BHPian Join Date: Aug 2005 Location: hyderabad
| i have purchased wagon r lxi e3 model last month, first service done at 1100 kms. the owner manual and service engineer recommends unleaded plain petrol, and says that higher fuels are not required since the vehicle is an mpfi oneand also that engine life will be damaged. is it true, will higher fuel really show diff in performance and wht fuel is recommended? |
| | #25 (permalink) | ||
| BHPian | Quote:
- T u r b o C - | ||
| | #26 (permalink) |
| Hi Turbo C, I tried with Xtra Premium this time. Ride so far is OK and not so smooth like speed93 but i have noticed one change. Noq my car temp gauge goes slowly to half way mark. Earlier it used jump on half way straight. Maybe its bcos my car has crossed 1300 km and engine is getting tuned. Pickup and smoothness is ok. Calculating milage now...... |
| | #27 (permalink) |
| BHPian | i stick to power definately feels better to drive there is slight but definate difference(in my zen and ikon 1.6 both) no change in milage from speed (hav tried all except 97)or power either and also speed felt just the same!! but i feel power makes the car feel a littllle bit peppier!! i guess due to the compression ratio being low it doesnt respond to higher octane fuels but according to my knowledge any engine with a compression ratio of 10 or higher should respond to higher octane fuel !! |
| | #28 (permalink) |
| Senior - BHPian | I dont know whether this premium fuels are really good or not but they surely give me piece of mind. I know my car is having the best drink available. I additionally also get the additives extra some 2-3 months.
__________________ boyracer.blogspot.com |
| | #29 (permalink) | |
| BHPian Join Date: Sep 2005 Location: bangalore
| Quote:
Thats because your inital advance is high. With a stock setup this wont happen. Usually people make the mistake of setting the timing on the mpfi just like on a carb engine. What you got to do is short two terminals (terminal E and D) of the diagnostic coupler at idle, then set a timing of 5 +/- 1 degrees of ignition advance. Looking at the coupler (from the terminal side), sorry abt poor graphics, -------- | * * * | | E D * | --------- Hope this helps !! Last edited by rdkarthik : 13th October 2005 at 11:41. | |
| | #30 (permalink) | |
| Quote:
I have Indigo GSX euro-III and i felt considerable performance boost with xtra premium. Also i have got 10-11 kmpl in city driving with 50% AC on. I tried speed, power & speed 93 before xtra premium. I would say for indigo euro-III this is the best fuel dont know abt other cars. compression ratio is 9:1 as per manual. | |
| Thread Tools | |
Similar Threads | ||||
| Are High Octanes really high OCTANE | pratheesh | Technical Stuff | 9 | 20th September 2006 22:48 |
| premium diesels do they work like high octane petrol | garvit2002 | Technical Stuff | 2 | 20th February 2006 09:54 |
| High Octane and Maruti | pratheesh | Technical Stuff | 24 | 10th February 2006 21:30 |
| High Octane Fuel | Domnic | A Collection of the best threads | 88 | 27th October 2005 15:34 |
| High Octane for NHC? | srasania | Technical Stuff | 6 | 28th May 2005 20:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
