Old 18th May 2010, 22:31   #121
Thanked: 2,394 Times
If the engine uses a closed loop knock sensor based ignition timing setup, higher octane should show some performance improvement. Normally not enough to justify the higher cost.
Sutripta
Old 18th May 2010, 22:55   #122
rk_sans's Avatar
Thanked: 778 Times
Originally Posted by adisag View Post
@rk-sans - I got 548Km/29.8Litres = 18.6 Kmpl from the first full tank on 97(Got a service done during this tank-so may not be all that accurate) and then 573Km/28.7Litres= 20 Kmpl on the second.
Was this drive in City traffic or Highway run and what %age of AC usage.
rk_sans is offline   Reply With Quote
Old 19th May 2010, 07:39   #123
adisag's Avatar
Thanked: 42 Times
@rk-sans - I got 548Km/29.8Litres = 18.6 Kmpl from the first full tank on 97(Got a service done during this tank-so may not be all that accurate) and then 573Km/28.7Litres= 20 Kmpl on the second. Unfortunately I had to tank up on IOC Premium on my last fill as Speed 97 was'nt available :( definite drop in driveability and the mileage seems to be hovering back around the 15Kmpl mark.
@ rk_sans
My driving is mostly in "Non Rush Hour" city driving, so slow moving traffic, but rarely jammed.
70% AC (I keep the ac on for 7-8 minutes, and then switch to blower only until it starts to get warm).
I'm comparing this to the fact that my average using other fuels was consistently ~15 Kmpl so its a 30% improvement.
adisag is offline   Reply With Quote
Old 10th October 2010, 23:10   #124
Thanked: 12 Times
Hello Adisag,
Any change in your observations during last 5 months? Any further improvements in mileage?
naren_L is offline   Reply With Quote
Old 11th October 2010, 09:17   #125
adisag's Avatar
Thanked: 42 Times
Originally Posted by naren_L View Post
Hello Adisag,
I've settled into a routine of Filling up my tank with Speed97 (haven't been able to completely avoid the occasional 200 rs of regular petrol when I'm running low on fuel though)
In peak of summer (I was working late morning to late evening for a couple of months- so more rush hour travel as well) mileage was hovering between 17-18.
With cooler weather and my regular dawn till 3pm hours mileage is 19 with a light foot, but my regular route (MG road) now beckons the speed demons within, so more realistically I manage about 18kmpl.
Old 17th January 2011, 16:15   #126
neeld's Avatar
Thanked: 101 Times
Default Re: How does high octane fuel improve performance?
Does someone have any experience using the 93 Octane available in some selected IOC pumps in Delhi ?
neeld is offline   Reply With Quote
Old 17th May 2011, 16:04   #127
Sportsmind's Avatar
Thanked: 28 Times
Unhappy High octane fuel I am feelin the pinch
I have been using Shell premium fuel for over a year now on my swifty and with a TC upgrade i was feeling it better on the same fuel. Today when I did the regular fill I could feel the pinch when i saw the 78 bucks per liter on the bill.
Is there an alternative to Shell premium as far as the Octane level goes and competitive on the pricing after the recent increase.
I have been loyal with Shell premium but it has started to hurt.
Please advice.
Sportsmind is offline   Reply With Quote
Old 17th May 2011, 16:35   #128
Born2Slow's Avatar
Thanked: 42 Times
Modern cars like Ritz petrol ( CI 1:10) perform much better with higher octane petrol, especially better low end torque. So this should translate to better mileage.
Born2Slow is offline   Reply With Quote
Old 17th May 2011, 22:14   #129
It would be nice if someone could list out the cars/ engines with and without knock sensors. Esp. of our volume sellers.
Sutripta
Old 21st May 2011, 00:45   #130
Born2Slow's Avatar
Thanked: 42 Times
I thought all modern cars with ecu has knock sensors.
Also for Bharat st IV compliance, is a wide band lambda sensor compulsory.
Old 21st May 2011, 01:08   #131
msupercool's Avatar
Thanked: 26 Times
Default Re: High octane fuel I am feelin the pinch
Please advice.
Try using octane booster. It will workout cheaper. You should get it at some performance store or some spare parts shop might be keeping it.
msupercool is offline   (1) Thanks Reply With Quote
High Octane Fuel Domnic Technical Stuff 91 13th November 2013 14:12
Does Fuel Efficiency Improve over time and mileage covered? architect Technical Stuff 1 8th May 2008 17:41
Does adding few ml of Acetone improve FE & performance? finetuning Technical Stuff 7 27th March 2007 20:36
Are High Octanes really high OCTANE pratheesh Technical Stuff 9 20th September 2006 22:48
