Old 22nd May 2008, 10:48   #1
Unhappy Hard clutch in Esteem.
hi guys,
im a new joinee to this population.
I will feel relieved if any one could guide me regardin hard clutch in my esteem.
Esteem-Type-1-- carbd.
i have a sore left knee after a drive in dense trafic...daily.
GoodGuy is offline   Reply With Quote
Old 22nd May 2008, 12:25   #2
Shashank.A's Avatar
Please also refer to this thread.
http://www.team-bhp.com/forum/techni...tml#post838588 (Esteem refused to Climb)
Might be useful for you..
Shashank.A is offline   Reply With Quote
Old 22nd May 2008, 12:44   #3
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by GoodGuy View Post
hi guys,
whats the odo reading in your car ?
Old 22nd May 2008, 12:54   #4
Sideways's Avatar
Thanked: 18 Times
changing the clutch cable and the release bearing should sort out the issue.
Sideways is offline   Reply With Quote
Old 23rd October 2013, 19:00   #5
rr_zen's Avatar
Thanked: 268 Times
Default Re: Hard clutch in Esteem.
Friends, I am in need of some advice on my Esteem's clutch. The car completed 10 years on 9th of this month and I don't intend to part with her ever. As part of a mid-life makeover I would like to give her, I wish to fix the clutch which has been a sore point from day one.
The car came factory fitted with Ceekay clutch plate and at the end of 39K kms I changed over to Valeo as suggested by an independent garage here in Chennai. I do not see a great difference despite that. The clutch cable has been changed too but to no avail. The car has done about 8K on the new clutch and am simply not happy with it. I would like to know if there are imported Suzuki OE clutch plates such as Asco etc that are available for the Esteem. I have tried Asco in my M800 long ago and it used to work like a dream. Any pointers in this direction would be appreciated. Thanks in advance.
rr_zen is offline   Reply With Quote
Old 23rd October 2013, 19:32   #6
invincible7's Avatar
Thanked: 154 Times
You can take a look at Exedy clutches, they are good.
May be OEM replacement or Stage 1 depends on your choice, should be available in Bangalore easily.
invincible7 is offline   (1) Thanks Reply With Quote
Old 3rd May 2014, 08:32   #7
hi,
I too am looking for a clutch overhaul on my esteem
1)Excedy clutch that i saw had formerly ceekay diakin written on the cover.
others that i saw were
2)Valeo
3)PHC
Which is the best for esteem? There is no problem with my clutch except that i experience engine shudder when i release clutch unless i accelerate higher while releasing...is it a clutch issue or something else?
Mod Note: There are several spelling & grammatical errors in your posts. This negatively affects the forum experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
caraholic is offline   Reply With Quote
Hard clutch shazikon Technical Stuff 8 27th November 2011 11:05
Hard Clutch on the Baleno bruce Technical Stuff 15 6th September 2009 20:48
04' WagonR - Poor FE, Hard clutch and judder DCEite Technical Stuff 12 30th September 2008 10:17
Ford Ikon Flair - Gear Shift & Clutch hard snaronikar Technical Stuff 6 6th October 2007 04:06
Palio and its hard clutch prkothan Technical Stuff 0 13th December 2005 12:04
