Old 9th September 2011, 00:25   #16
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: Help - removing kumkum stains on new car!
Originally Posted by AbhiJ View Post
A light rubbing compound is worth a try...
or else rubbing compound.
+1
Plain 'ol rubbing compound should do the trick. Just don't overdo it.
Old 9th September 2011, 01:19   #17
torquecurve's Avatar
Thanked: 670 Times
Have faced the same problem. Rubbing compound will do the trick, have to be careful not to rub too much. Then wax the area/car.
Another thing I have tried and which worked is using a 1:2 solution of Pril liquid with water. Used a plastic foam pad and lightly rubbed it and the stain is gone.
After this you MUST wax the spot, you will probably be removing 1mm or so of top coat.
torquecurve is offline   Reply With Quote
Old 7th September 2014, 21:27   #18
shoaib3030's Avatar
Thanked: 114 Times
Originally Posted by Sam Kapasi View Post
I have two words for you. Zippo Fuel.
Use a cloth moistened with Zippo Fuel to remove any stain.
I'm gonna try your method ! My brand new A4 has kumkum stains !! :(
shoaib3030 is offline   Reply With Quote
Please help..Stains on Chrome on My Bullet panky12345 Motorbikes 31 29th August 2016 15:14
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
How to remove oil stains??? sidd_city Technical Stuff 9 8th October 2008 18:26
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
Paint stains on my car Chetu Technical Stuff 26 3rd April 2007 21:22
