Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 25th May 2008, 13:28   #1 (permalink)
btirthankar's Avatar
Default Sensing lack of Engine Braking in Toyota Innova D4D
I have a Toyota Innova D4D. I previously used toi drive a petrol Astra so am used to its engine braking.
Of late I have realised I am using more brakes and less downshifting in my Innova as the engine does not provide adequate braking.
I know that engine braking is all about how much vacuum the pistons have to produce.
My one question. Is the engine braking less in my innova due to the turbo after-revvs? Is it because that it does not have a device to stop the air during intake stroke at the same ytime when the turbo is pumping in air?
__________________
DRIVOBLOG® | Tirthankar Basu
btirthankar is offline   Reply With Quote
Old 25th May 2008, 13:30   #2 (permalink)
vid6639's Avatar
I had read somewhere on t-bhp that Diesel engines don't have good engine braking. I don't know the technicality behind it but I'm sure some expert will be able to provide more details.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 25th May 2008, 13:41   #3 (permalink)
reignofchaos's Avatar
Diesel engines have very little engine braking as they are unthrottled. Thats the reason that heavy trucks come with specialized devices like a Jacobs Brake (also called a jake brake). However these devices are noisy and banned at many places.
Old 25th May 2008, 14:54   #4 (permalink)
DirtyDan's Avatar
Default Yes, no engine breaking
Yes, let me rephrase that, diesel engines have very little engine braking when you get off the throttle. They have little compression when not under throttle. Also, you will notice that when you take your foot off the throttle of a diesel that it will go to idle speed right away. So fast, in fact, that inexperienced diesel drivers sometimes have a little trouble shifting because the engine revs drop immediately and the engine is turning much slower than the rest of the drive train between shifts. This is why you hear some big trucks rev their engines between shifts, to bring their engines up to speed.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
DirtyDan is online now   Reply With Quote
Old 25th May 2008, 14:59   #5 (permalink)
Thank you for the correction. I basically meant the same thing.
Old 25th May 2008, 18:28   #6 (permalink)
But does the turbo has anything to do with it?
__________________
Old 25th May 2008, 19:20   #7 (permalink)
condor's Avatar
Engine braking in diesels would also be affected by gearing I guess. My 3rd is versatile. But 2nd is what I would use when I want to 'engine brake'.
__________________
Life is Analog. Digital is an approximation.
Old 25th May 2008, 20:40   #8 (permalink)
CrAzY dRiVeR's Avatar
I feel its also got to do with the torque offered by these diesels. The first time i drove the Swift diesel, i was expecting it to slow down with foot off the accelerator pedal, and it just kept pulling!
Isn't that for matching the speed to shift into a lower gear?
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 25th May 2008, 22:26   #9 (permalink)
Yes I can see that when compared with my Petrol Innova, My new driver who has experience of driving trucks in NH17 entire stretch and more areas told me this Petrol Innova's foot off the accelerator itself is one brake! even if he is in 5th gear.
Technically speaking Petrol vehicles have such more advantages except Diesel vehicles feel more peppy in City driving.
Ravi.
ravibhat is offline   Reply With Quote
Old 26th May 2008, 11:31   #10 (permalink)
I agree, same with me, perhaps the gear ratio's in Innova allow for lesser engine braking.
__________________
"I cannot be fair with everyone in Life" - dadu, 2001
Old 26th May 2008, 12:04   #11 (permalink)
alpha1's Avatar
Ravi.
But that peppyness is very shortlived, as the diesel hits the redline pretty soon, and you need to upshift.
I recenty had a Test drive of Scorpio mHawk, and was not at all please with the short rev life that engine had, compared to Swift and Vtec which I've driven.
Old 26th May 2008, 12:55   #12 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
lets not get into this here. both have their advantages. there are enough threads to discuss this.
akshay1234 is offline   Reply With Quote
Old 26th May 2008, 14:28   #13 (permalink)
androdev's Avatar
You mean lesser compression losses? Compression ration remains constant.
They are transmission/frictional losses and not engine braking/compression losses.
No comments on petrol vs diesel topic. But <b> engine braking is not always a good thing </b> for the following reasons:
It transfers wear and tear to transmission and engine parts that are an order of magnitude more expensive and difficult to replace than brake parts.
Dramatically increase in engine RPM is bad for engine and FE (in cars without fuel cutoffs)
androdev is offline   Reply With Quote
Old 9th May 2009, 02:54   #14 (permalink)
well, i feel it is because diesel engines have a low rpm compared to petrols .diesel engines rely on torque rather than rpm to power the car . In diesels the torque is still there ,but the rpm only goes down and , even if the car is in the top gear , you might still be able to drive the car ,but in petrol you will have to downshift due to the low rpm of the engine in top gear
Thread Tools
Understanding Toyota Innova D4D Technicals Better btirthankar Technical Stuff 3 7th May 2009 15:19
Toyota Innova D4D test driven Revvmaster Test-Drives & Initial Ownership Reports 48 24th October 2007 18:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
