Old 25th May 2008, 21:47   #1
amit_mechengg's Avatar
Thanked: 1,556 Times
Exclamation Silencer Noise!! need urgent help
suddenly i noticed that there is a strange noise coming from the beneath of my alto done 30000 kms. it wasn't long before i realized that the banging sound of tin is coming from the end can of my silencer. when inquired the mechanic said the material "jaali" inside has fallen off.
will this affect my performance of the car? i am finding the top end is reduced a bit. still not sure about the ill effects of the fallen muffler material.
also i want some suggestions to fix it.
Old 26th May 2008, 10:28   #2
Thanked: 245 Times
Goto a local silencer shop for repair, the jaali will keep hitting the silencer from inside rupturing it at some stage.
Old 26th May 2008, 11:10   #3
Thanked: 146 Times
the proper thing will be is change the rear muffler.
the jaali repair is not worth it as it usually breaks at the muffler ends internally.
I had a similar problem the internal jaali will vibrate at certain frequencies of the exhaust.
Jr Godzilla is offline   Reply With Quote
Old 26th May 2008, 11:28   #4
Technocrat's Avatar
Thanked: 2,589 Times
Amit I think its time you went for the planned FFE now
Old 26th May 2008, 11:37   #5
Thanked: 18 Times
Yea Amit, I too second Technocrat on that as after your much research done on FFE, go for it and am sure your baby is crying for it through this
VJ_MAVRICK is offline   Reply With Quote
Old 26th May 2008, 13:49   #6
yeah i think i need to get the FFE. this seems a better reason to go for it. as it is the end can is costly. better i go for a FFE. is 3-2-1 configuration applicable to 800cc alto? i have heard only of 3-1, middle and high end performance. my city (Pune) calls for a low end maximum torque.
Old 26th May 2008, 13:53   #7
ramie2400's Avatar
Thanked: 58 Times
FFE will be a better thing to insall now as you have a genuine reason opening the stock silencer and getting it on the original shape will cost you as much as getting a FFE so go for it man
Old 26th May 2008, 15:38   #8
and how much would the FFE cost? i recently spent 400 bucks on getting my silencer welded in my accent!
harsha.cs1 is offline   Reply With Quote
Old 26th May 2008, 15:41   #9
esteem_lover's Avatar
Thanked: 451 Times
Just jab a few holes in your end can with the help of a screw driver & you have the most cost effective free flow.
Old 26th May 2008, 16:49   #10
i just paid to get the holes plugged! not a prob, will not get it fixed the next time around! but are you sure it no way affects the FE and performance?
Honda Accord - Hissing Noise in Stock HU after adding an amp - Kinda Urgent Help Akshay1234 In-Car Entertainment 44 2nd February 2011 11:33
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Hole in silencer (OHC VTEC). Need help. hondadude Technical Stuff 18 15th February 2008 14:19
Need Help - for replacing Hyundai Accent GVS silencer deepaktpatil Modifications & Accessories 6 16th September 2007 11:39
MATIZ - Silencer noise SCH Technical Stuff 7 23rd March 2005 00:32
