Old 30th May 2008, 14:18   #16
babhishek's Avatar
GTO has explained it perfectly in his 2nd post. This is a normal feature, have a word with MASS and they should be able to explain it.
Car rolls in neutral and the revs go up, interestingly with gear changes from a higher gear to neutral the idle revs also go up.
Give it 5 mins, things settle down.
Or else don't roll in neutral when you start the car the first time/after a long time for at least the 1st 10 mins of driving.
babhishek is offline   Reply With Quote
Old 30th May 2008, 14:24   #17
headers's Avatar
Thanked: 464 Times
Originally Posted by ballkey View Post
but my problem is not at idling - it's when she's already rolling. It's like having a stuck accelerator pedal - that's why it's disconcerting.
Just spray WD40 on the Accelarator cable. Or lubricate it properly and the problem should dissappear.
Old 31st May 2008, 10:39   #18
Surprise's Avatar
Thanked: 272 Times
I too had this worry esp after installing the conical filters. Even I had to apply brakes (after engaging the gear) to control the car as it rolls fastly. But settles down after few minutes and this happens only during cold starts
Surprise is offline   Reply With Quote
Old 31st May 2008, 11:28   #19
Thanked: 28 Times
Originally Posted by esteem_lover View Post
If you read through the technical section of this forum you will realise that it is a feature in the MPFI cars to idle at 1000rpm when the engine is cold & will settle down to 900 rpm once it is heated up.
900 rpm, isnt that too high minus ice or a/c. which car is this you are talking about.
Which of the modern mpfi cars have an idling rpm of 600-750 ?
makes sense in the age of traffic & 50 +fuel prices.
kavesh55 is offline   Reply With Quote
Old 31st May 2008, 12:27   #20
headers's Avatar
Thanked: 464 Times
Most cars 3cyl and 4 cyl cars have idling set between 750 - 900 without a/c and 900-1100 with a/c
No response from engine after 4K RPM..Octavia vRS ashish22 Technical Stuff 35 14th April 2009 10:24
Dial 100 for quick response. heavy_foot Street Experiences 21 7th November 2007 18:31
F1 Rapid Response! madhav Int'l Motorsport 0 11th November 2006 19:50
My email to Maruti/their response abt the Swift Sport theMAG The Indian Car Scene 1 1st October 2006 14:59
HONDA CITY: quick response needed- Please Surprise Shifting gears 14 2nd March 2005 09:55
