| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Sep 2005 Location: Pune
| Hi Experts I am witnessing a very strange mettalic rattling sound in my Alto LXi whilst taking a left turn @30kmph+.This mettallic sound is also present when going over small humps.... Had both the CV joints checked from MASS and were found to be ok. What all do I need to get checked... Thanks Rahul Last edited by Rahulk76 : 26th May 2008 at 19:02. Reason: Spell Check |
| | #5 (permalink) |
| MASS checked both the Drives Shafts and CV joints for any issues and found them to be ok.. However I will ask them to recheck by opening the stuff called drive shaft /axle etc....This is only coming when taking a left turn.Apart from this any other expert pointer.. This seems to be a one off case....Not sure if anyone else having an alto has seen this kind of issue. ![]() Thnx Rahul Which One.. Front/Rear Last edited by Technocrat : 27th May 2008 at 13:38. |
| | #7 (permalink) | |
| BHPian Join Date: May 2007 Location: Noida
| Quote:
The problem is still there after 1 year! ![]()
__________________ "Alcohol doesnt solve any problems", but if you think again, neither does milk... | |
| | #9 (permalink) | |
| BHPian Join Date: Jul 2007 Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
| Quote:
...I am not sure it is a problem, since the ride is otherwise normal..I mean, i dont feel any steering hardness/vibration or drivetrain straining etc.. So havent got it checked yet. Probably some suspension bushes are getting worn out...will get it checked at next service.Maybe, you should get the steering/suspension elements also checked ? Last edited by Blue Thunder : 27th May 2008 at 13:47. | |
| | #10 (permalink) |
| Newbie Join Date: Apr 2007 Location: Mumbai
| I get a rattling sound from the rear....and also near the passenger door. It sounds more plasticky than metallic. and it only happens within the first 15 mins of starting and driving the car. any suggestions? everytime i take the car to the service centre, the noise doesnt show up when the technician comes for a test rice. So this time around I have used my phone to capture a video. Will shortly upload it and link u guys. In fact I have been postponing my ICE just because of this so that the service center guys dont blame it on the ICE! |
| | #12 (permalink) | |
| Quote:
So I am not the only one... I have fixed a appt with MASS to TD the car around the place where I stay as there are ample of left turns windings with some 80degree left handers where the noise is pretty awfully evident(with sparewheel, toolkit and jack & without them as well ~ just to rule out some trivial noise makers.)Like others have suggested, Ill get all the suspensions, linkages,swaybar, shafts,steering wheel components. underbody nuts etc...checked out Initially I thought it was the torsion bar or something like that getting loosened and therefore on a tight bend when the pressure was being exerted on them they were touching the underbody parts.. or maybe the left side suspension / damper might have gone for toss..This started when I went to Panchagani during first week of may Last edited by Rahulk76 : 27th May 2008 at 14:05. | |
| | #14 (permalink) | |
| Quote:
| | #15 (permalink) | |
| Quote:
Ok Did a longish testdrive with the mass technician today instead of tommorow......and on tight left turns the noise was caught red handed by the snr mass technician as well... They said they will check out the same(LEFT DRIVE SHAFT) by opening the things etc and return the vehicle day after tommorow after rectification. The noise was pretty familiar to them it seems..I distinctly remember one of them say "Oh! heh noise ka...tujha Left Shaft cha noise aahe, tencha cv joint gayela." Thanks to all for pin pointing this(LEFT DRIVE SHAFT) thing Next update when i get the vehicle Last edited by Rahulk76 : 28th May 2008 at 18:31. | |
« Queries On The Indica Dicor's Footwear
Problem: Ford Ikon vibrating (almost shaking) when Idle. »
| Thread Tools | |
Similar Threads | ||||
| Strange problem with Air Filter K&N/Stock on Alto | amit_mechengg | Technical Stuff | 29 | 10th July 2008 19:42 |
| Strange sound from Alto front left wheel | mail4ajo | Technical Stuff | 12 | 27th December 2007 13:32 |
| Alto LXI for sale | rjstyles69 | Shifting gears | 12 | 27th March 2007 13:56 |
| alto lxi | amitava | Shifting gears | 0 | 13th March 2005 21:47 |
| Alto LXI | VMG | The Indian Car Scene!! | 9 | 5th September 2004 02:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
