Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 27th May 2008, 11:50   #1 (permalink)
Default Torque Curve For Safari 2.2 & Scorpio 2.6 CRDe
Does anyone have the torque curves for above mentioned vehicles ?
I wanted to compare the two to gauge engine characteristics.
__________________
Thanks,
rb2399
rb2399 is offline   Reply With Quote
Old 27th May 2008, 13:40   #2 (permalink)
Here's the one for Safari 2.2l
Name:  2.2l power graph.gif
__________________
"I cannot be fair with everyone in Life" - dadu, 2001
Old 28th May 2008, 07:14   #3 (permalink)
kuttapan's Avatar
@rb2399 - The proof of the pudding is in the eating, not pictures.
Though the torque curve will give you an overall idea about the two engines, you are discounting the gearboxes, vehicle weight etc.
Take a test drive instead of going in for a deep theoretical study. I did all this nonsensical stuff before I bought my first bike and found it to be a waste of time. Nothing beats a test drive over different types of terrain/road conditions.
kuttapan is offline   Reply With Quote
Old 28th May 2008, 10:32   #4 (permalink)
I have owned Scorpio before and now have 2.2 with me.Somehow I am not getting the feel of "sudden acceleration" in 2.2 that was present in Scoprio.Hence wanted to study the torque curve.
Yes the other aspects like GVW,gearbox do come into picture.
Looks like the torque delivery of Scorpio is flatter like Swift diesel as compared to Safari.
__________________
Thanks,
rb2399
Old 28th May 2008, 10:48   #5 (permalink)
im_srini's Avatar
Hi, these power & torque curves look interesting...
As far as I know, power is computed by measuring torque (on a dyno) by using the formula Power = Torque * RPM / 5252. So usually, the power & torque curves will intersect (i.e. they're the same) at 5252 RPM. Here they seem to intersect at 2850 RPM, does torque fall off so drastically in a diesel as the revs increase ?
im_srini is offline   Reply With Quote
Old 28th May 2008, 12:07   #6 (permalink)
IMHO diesels torque generated is at lower rpm and in case of safari the torque spread is in a very small rpm 1700 to 2700 range. starts higher rpm and ends quite fast
compare this to torque of innova 1400 -3400rpm which starts early ends farther up.
so i its engineering STROKES short and long to create the torque spread.
__________________
Zindagi ek rangmanch hai aur humsab kathputliyan hain
Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta
Jr Godzilla is offline   Reply With Quote
Old 28th May 2008, 12:54   #7 (permalink)
Not sure if this is a good comparison, because the Innova produces a peak torque of 200nm (surprisingly low for a 2.5 litre Common Rail engine - even the Swift Diesel produces almost similar peak torque from a 1.3), while in comparison the 2.2 Dicor crosses the 200 nm figure at 1,100 or 1,200 rpm and still produces 250 nm when the torque curve has trailed off completely at 4,000 rpm.
Like someone said before, there are a whole host of factors including absolute torque figures produced (as I have pointed out in the earlier paragraph), vehicle weight, gearing etc - nothing beats a test drive.
__________________
It is no measure of health to be well adjusted to a profoundly sick society.
- J Krishnamurti
Steeroid is offline   Reply With Quote
Old 28th May 2008, 15:27   #8 (permalink)
absolutely.
test drive will help you know whether the torque / power is sufficient for each persons driving requirement.
__________________
Thread Tools
Scorpio 2.6 T vs Scorpio 2.6 CRDe engine comparison Mohnish SUVs, MUVs & 4x4s 19 19th October 2009 19:20
Buying a Used Car - Safari DiCOR LX or Scorpio CRDe DX ~ H O N D A ~ SUVs, MUVs & 4x4s 9 31st January 2008 10:27
Looking for a Scorpio CRDe or a Safari Dicor ~ H O N D A ~ Shifting gears 0 29th January 2008 11:00
Safari DICOR vs Scorpio CRDE devarshi84 The Indian Car Scene 279 25th June 2007 10:26
New Safari Dicor Or New Scorpio Crde ? ramkya1 SUVs, MUVs & 4x4s 1 18th May 2007 17:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
