Old 1st June 2008, 18:31   #46
CR-V's Avatar
Thanked: 15 Times
Well than I will leave the anti rust.
I tried finding the mats at several places.
There were these standard Rs.500 4 piece transparent mats.
And second was special CR-V mats but in beige (and that also dull one). for Rs.1800
And I not familiar with too many places in bombay of car accessories.
CR-V is offline   Reply With Quote
Old 1st June 2008, 19:23   #47
Thanked: 50 Times
Can some one point me to an accessories shop in Bangalore(preferable Indiranagar side) which has all required accessories at one place.
thanks in advance..
sriturl is offline   Reply With Quote
Old 2nd June 2008, 11:16   #48
Ricky_63's Avatar
Thanked: 394 Times
Your "location" also says Delhi. When you are here try Lajpat Nagar OR Karol Bagh....you WILL find whatever you are looking for . Sorry I for one cannot help you with Bombay - maybe you can PM some Bombay members
Old 2nd June 2008, 12:15   #49
mobike008's Avatar
Thanked: 8,238 Times
Originally Posted by vnabhi View Post
A few feet before the Narayanguda flyover on the left, if you are going from Liberty. There is a small temple on the roadside exactly opposite to WSE, and that is the best landmark.
I think it is around 30 feet from the beginning of the flyover, sreenivass.
I stay approximately 100 ft from this showroom
Old 2nd June 2008, 14:31   #50
vnabhi's Avatar
Thanked: 1,300 Times
That would be somewhere near Jwala's dental clinic, right?
Old 9th June 2008, 21:21   #51
Ricky_63's Avatar
Thanked: 394 Times
Interesting - raining hard in Mumbai & not a single post on the thread ??? Is it raining that hard ? The picture in HT Delhi today was pretty bad - water almost upto headlights of an esteem....
Old 9th August 2008, 17:19   #52
Ricky_63's Avatar
Thanked: 394 Times
Just discovered a NEW FEATURE in the Audi. My car is amphibious !!!
It "waded" thru bumper high water in the rain lashed NCR yesterday !!
Old 10th August 2008, 12:28   #53
Thanked: 149 Times
Infractions: 0/1 (4)
Originally Posted by Ricky_63 View Post
Just discovered a NEW FEATURE in the Audi. My car is amphibious !!! It "waded" thru bumper high water in the rain lashed NCR yesterday !!
If the wheels were touching the road, what is so special about that?
Old 10th August 2008, 13:25   #54
RuffRyder's Avatar
Talking
my "Monsta" is 100% not ready for the monsoons!!
being a open top ride, its a great feeling to get drenched in the rain..
RuffRyder is offline   Reply With Quote
Old 10th August 2008, 15:57   #55
Ricky_63's Avatar
Thanked: 394 Times
Sir,
That is what is special (sense of humor to be kindly used)
Old 21st July 2016, 15:31   #56
ariesonu's Avatar
Thanked: 1,432 Times
Default Re: Is your car ready for the rainy season ?
Ensure that all the lights (External & internal) and blinkers of your car are working properly
Today cars are heavily dependent on electronics & computers so understand your car fuse box (there is diagram on every fuse box / do remember to note position of fuse puller)
– keep fuses of 10 -15 - 20 Amps handy in car
If headlight lenses get clouded by mud/muck, ensure to clean it with wet cloth at the end of day – leaving it will cause your lenses to get duller
Check the sweeps of your wipers, both front and rear (if installed) – Change them if you see sweep is not clean – bad wipers can cause windshield damages too
Ensure that all the fluids in your car are topped up: Engine Oil, Brake Oil, Coolant, Wiper wash, Steering Oil and Gear oil – Use manufacturer spec products only
Keep a can of WD-40 or similar agent in car
- WD 40 works wonder if the ORVM’s are getting clouded – a single spray and the glasses will not get clouded
- It also helps is loosening rusty bols
Keep tools like Pliers, Standard size screw driver, a length of wire, spanners between 11-18 mm in car
Ensure that all the tyre treads are good – Rotate tyres and keep the Stepney ready
Keep your tyres pressure accurate in all tyres
Car jack & tools should be oiled as they can attract rust in rains
Ensure to get wheels alignment done
Ensure to carry hazard triangle in the trunk
Ensure to carry YELLOW beam torch or LED lantern in car – Yellow beam has better penetration at night & in fog
Get brake pads checked and changed, if required - Brake pads should have enough tread
Brake drums should be cleaned of residue & rust
Brakes work on a master & slave cylinders – ensure all are pumping freely
Ask mechanic to bleed your brake lines when doing above service (bleeding = pumping out air bubbles from brake oil lines)
Do not brake hard but use pumping action (ABS) when braking in wading water or slippery road
Get the battery & alternator checked – keep a bottle of distilled water in the car – in case of an emergency even ordinary water will do
Get battery terminals and contacts cleaned and apply gel or simple petroleum jelly to avoid corrosive build up
Women drivers should make ample use of safety apps wherever possible or call a family member before beginning journey at odd or late hours
Few days before rains; drive your car without playing music and with all the windows closed and note any strange sounds and get them fixed
Keep a list of emergency numbers and immediate family numbers in glove box
Made this for my colleagues
Hope it is of use to BHPians
Regards-Sonu
ariesonu is offline   (2) Thanks Reply With Quote
Painting a car on a rainy day sumeethaldankar Technical Stuff 10 1st November 2012 21:17
Thekkady & Munnar In A Rainy Season Mysticeyes Travelogues 37 19th September 2011 22:44
Things to note while visiting Indian Jungles during the rainy season abheekg Route / Travel Queries 4 29th June 2011 18:11
2008 F1 season: Pre-season banter MaserQ Int'l Motorsport 27 13th March 2008 09:12
places to visit in rainy season around 350 kms from bangalore sharu Route / Travel Queries 29 19th June 2006 20:12
