Thread Tools
Old 28th May 2008, 21:52   #1 (permalink)
Default Esteem Battery discharged -ECU reset
one day my Esteem Battery discharged completly and after i charged the battery now the engine noise is very high as well the car maximum speed is only 100kmph and i feel the engine is very harsh now.
Is this due to ECU reset due to battery discharge
how can we remap the ECU to the correct setting?
-MUKE
muke31 is offline   Reply With Quote
Old 29th May 2008, 00:44   #2 (permalink)
-MUKE
imo just disconnect the negative for say 2 minutes and reconnect should reset ecu
__________________
Zindagi ek rangmanch hai aur humsab kathputliyan hain
Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta
Jr Godzilla is offline   Reply With Quote
Old 29th May 2008, 08:52   #3 (permalink)
Rehaan's Avatar
muke31,
This does not really sound like an ECU problem. (though resetting it once is probably worth a shot!)
Why did your battery discharge in one day? Do you know what the reason for that was - it might provide some insight to the problem you are currently facing.
cya
R
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 29th May 2008, 09:56   #4 (permalink)
The car was kept parking for a week and that was the reason why the battery discharged, but why max speed decreased and harsh engine
I noticed this while i took my car from Bangalore to chennai and car refused to go beyond 100kmph and the RPM was showing only 2500-3000
i recently changed my clutch plates for esteem? is this the problem?
-MUKE
Old 29th May 2008, 12:25   #5 (permalink)
-MUKE
in one week normally battery should not discharge but can happen
is your car carb version
after changing clutch did you try +100 speeds
has your FE dropped??
__________________
Old 1st June 2008, 22:49   #6 (permalink)
you cannot reset the ecu by disconnecting the battery. the dealerships use a special diagnostic machine to reflash the ecu.
Shardul is offline   Reply With Quote
Old 4th June 2008, 18:04   #7 (permalink)
quicksilvr's Avatar
You can very well reset the ECU as described by Jr Godzilla.
Reflashing is a total different ball game.
Make sure that, after resetting the ECU, start the car and let it idle for about 3mins and then turn it off.
quicksilvr is offline   Reply With Quote
Old 4th June 2008, 20:41   #8 (permalink)
Ideally to reset a ECU you should disconnect the negative terminal for atleast 15minutes(sum even recomend 30mins).
On a cielo showing check engine light,we disconnected all connectors,disconnected the batt for almost an hour or so(meantime we were cleaning the plugs)after this when we reconnected everything and started the engine the check engine light had stopped glowing(no this was not due to a faulty plug,as prior to this we had checked by replacing all four plugs with plugs from the other car)
its worth a try just disconnect and leave it for 30 mins or so....
scorpian is offline   Reply With Quote
Old 4th June 2008, 21:06   #9 (permalink)
iceman91's Avatar
You have to discharge and reset the ecu as described by dischargin the battery, then reconnect the battery.Start the car drive it hard for a few minutes switch it off and start and drive again normally and then once more.
this should set the parameters again for your car.
have done this a lo of times..will work. especially with the suzuki ecu
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 4th June 2008, 21:07   #10 (permalink)
iceman91's Avatar
other option o dicharge battery is disconnect the two terminals and touch them to each other thereby removing complete charge even residual.
else disconnect battery and crank the engine a couple of times.
__________________
...91 is back !!!!
Old 1st September 2008, 19:16   #11 (permalink)
kishoryk's Avatar
Default ECU Reset
I bumped into this thread while wandering around in the TBHP forum.
Mods - this may be slightly out of topic, so if you wish you may please post this as a new thread.
I've two questions on the ECU reset:
1. As the original post from MUKE, recently I had my car battery drained for the same reason of not being used for long time. THen when the mech arrived, he wanted to quickly re-charge it - so ran the engine at high RPM for few minutes immediately after jump starting it with another battery. Could this have effected ECU mapping? Does this require an ECU reset?
2. The car I recently bought was a pre-owned one. It's highly likely that the first owner's driving habits/behaviour is quite different from the way I drive. He could be slightly inexperienced and might not have used the clutch+accelerator+gear combination appropriately. I can't claim myself an expert but now I'm better learned in optimal/effecient driving. Does it help to reset the ECU now and let it re-map for my driving style so that I can get better performance from my car than what it's currently?
Please clarify.. Thanks in advance!
KK
kishoryk is offline   Reply With Quote
Old 4th September 2008, 10:06   #12 (permalink)
mithun's Avatar
KK
1. Running the engine at high RPMs for few minutes might not have affected the ECU mapping. No need for ECU reset.
2. Don't worry about how the previous owner had used the car. Just stick to the best practices. And, the ECUs are not having too much of AI !
Also see : http://www.team-bhp.com/forum/techni...resetting.html (Basic ECM Resetting)
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 4th September 2008, 16:03   #13 (permalink)
kishoryk's Avatar
Default THanks
mithun, Thanks much for that piece of information and the link is useful too.
Cheers,
KK
Thread Tools
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
Which Car Battery For Esteem. passion4cars Modifications & Accessories 19 7th February 2008 10:46
Reset ECU after installing K&N PatienceWins Technical Stuff 15 25th August 2007 22:51
Need Mad Help With My New Esteem Vxi Car Battery ..... Tool Modifications & Accessories 4 17th May 2006 20:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
