Thread Tools
Old 30th May 2008, 08:53   #16 (permalink)
wanderlustindia's Avatar
Thanks one and all for your suggestions.
Latest observation. Yesterday wifey filled in 'Speed' from BP COCO (opposite RTO) worth 1000 bucks. I ran the car this morning to work (20 kms from home) and I thought the car ran well. Could feel the jerks but was not as frequent as it was earlier.
I would not conclude just yet about the bad fuel theory. Am heading to Mumbai over the weekend and see how the car runs on the e-way.
Originally Posted by n_aditya View Post
I faced the same issue few weeks back where the engine felt sluggish and used to jerk at RPM's between 1k and 1.5k. Got the spark plug's cleaned (not much visible deposits though), got the distributor cleaned and feels much better now. Need to get the injectors cleaned and the TB cleaned too.
My suggestion is get the injectors and the throttle body cleaned. Also check for worn out spark plugs and loose plug wires. It could be possible that not all cylinders are getting fired. If your engine is pinging or knocking then bad fuel is the culprit. How is the FE? Check the timing also. This should resolve the issue IMO.
The throttle body was cleaned in the last service (2000 kms back). However, the injectors have not been cleaned since I bought the car last June. And it has run with the same set of spark plugs as well since then. A good 12k kms.
__________________
'Real Freedom lies in wildness, not in civilization'
wanderlustindia is offline   Reply With Quote
Old 30th May 2008, 09:30   #17 (permalink)
I guess he has advanced the timing. Do you hear any pinging or knocking sound? If yes, then get the timing retarded or adjusted to normal settings.
Yes, that is what he had said. I don't hear any new sounds from the engine (or maybe, I need to observe further). My car is gone for a fresh coat of paint. Once I get it back, I'll drive it around some more and then get back to SM ...
lancer_rit is offline   Reply With Quote
Old 30th May 2008, 13:27   #18 (permalink)
smsrini's Avatar
wanderlust,
put one bottle of Bardhal Fuel Injector cleaner with your next tankful. This should be available from your Lancer A.S.S.
This is the simplest thing to do before doing any major changes / repair / injector cleaning etc.,
__________________
"Horn Please OK Tata"
Landrover.....ka bhai, aur ek tall boy!
smsrini is offline   Reply With Quote
Old 30th May 2008, 15:40   #19 (permalink)
Originally Posted by smsrini View Post
wanderlust,
I have been doing my regular services at the used car dealer's workshop. Any idea where I can source it from? Is it available on petrol pumps? Or some other place?
__________________
Old 30th May 2008, 16:25   #20 (permalink)
smsrini's Avatar
try petrol pumps or any dealer for performance mods... some of the local service stations also may stock.
You can still walk into the Mitsu *** and ask for it.
__________________
Old 30th May 2008, 16:27   #21 (permalink)
n_aditya's Avatar
If you are unable to get Bardhal fuel injector cleaner, try getting Iftex System G (for petrol engines). It is available at most BP bunks. Sonax also has a similar product. Off late though System G is not available in few bunks i enquired at. It seems due to low demand stocks have stopped being refreshed.
__________________
RIP Tootie !!! Missing you terribly.
Old 31st May 2008, 13:42   #22 (permalink)
rohan_fonseca's Avatar
Wanderlust get your fuelling checked. Fuel quality, filter, pump, injectors.
rohan_fonseca is offline   Reply With Quote
Old 2nd June 2008, 13:22   #23 (permalink)
n_aditya's Avatar
Also check the throttle position sensor. I got the TPS in my car re-adjusted and the throttle response is better. Will be getting the throttle body cleaned along with the injectors soon. TB will be removed, soaked in thinner and refitted. Injectors will be removed, cleaned and refitted.
__________________
Old 2nd June 2008, 16:35   #24 (permalink)
Went to a BP pump near Koregaon Park. Picked up this petrol additive called Iftex System G. It is supposed to clean injectors of gum and vanish deposits and many more virtues. Its worth Rs. 250/- for a 200 ml bottle. As per instructions on the bottle, 1 ml/ ltr of fuel. Which means this can serve me for four tank fulls. I did a tank full yesterday, will dump 1/4th of the bottle and see how the car runs for the next 100 odd kms.
Will update all in a few days time.
__________________
Old 4th June 2008, 09:53   #25 (permalink)
Well, here are the first impressions after adding about 100 ml of System G to a tank full. The jerking is now almost not there. Its been two days of running, 40 kms each day and I think the problem is resolved to a great extent.
In the next tank-full will use the remaining 100 ml System G and hope to see even better results. Fingers crossed!
__________________
Old 4th June 2008, 10:55   #26 (permalink)
razor4077's Avatar
Good to know that man. So it seems the injectors were the culprit in your car's case.
razor4077 is offline   Reply With Quote
Old 4th June 2008, 10:57   #27 (permalink)
Yes, looking at how the car has responded to System-G it has to be the injectors. Will wait to see if the effect is there in the long run.
Wifey took the car to work today and she called me up to say the car did not jerk at all . Its working!
__________________
Old 4th June 2008, 11:47   #28 (permalink)
smsrini's Avatar
wanderlust,
Use System-G for 4 tankfuls ( if you have been using regular petrol all this time and havent got the fuel system cleaned ever ). That should rid the problem completely.
If you wish to continue using regular petrol, then use the Bardhal Injector cleaner ( one bottle in a tankful ) every 5000kms and you should be fine.
Happy Motoring.
__________________
Thread Tools
Matiz : Jerks and MIL lamp ON Tawwa Technical Stuff 6 9th July 2008 12:39
Low FE on Xing with AC on ! Vishesh Technical Stuff 1 25th August 2007 00:21
Increasing torque at lower rpms swathyd Modifications & Accessories 42 5th May 2007 10:57
Fiesta engine jerks and rpm varies while idling tortoise Technical Stuff 16 13th March 2007 19:22
What's up with RPMs? neverclever Technical Stuff 5 23rd June 2004 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
