Old 12th September 2011, 20:54   #31
dhawcash's Avatar
Thanked: 141 Times
Default Re: My Lancer jerks at low rpms
Glad to hear the problem in your case were the injectors.
Another reason for shuddering at low RPMs can be the engine mounts. Don't be surprised!
An engine is mounted on rubber or hydraulic mounts, which absorb the 'shocks' as the engine tries to twist in the direction opposite to the wheel movement.
A friend faced similar problem on his Honda City 1.5 Vtec. He tried all sorts of things like a spark plug change, fuel additives etc. The problem seemed to get solved, but cropped up again after a few days. maybe it was not actually solved, and a psychological thing.
So one day we were brainstorming, and the engine mounts hit me. popped the hood and told him to rev the engine. it was moving about more than normal. On detailed checkup, one of the mount's rubber was split which was allowing the engine to shake because of torque reaction at low revs. Changed the mount and the shuddering is gone for good now.
dhawcash is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 10:19   #32
gov626's Avatar
Thanked: 12 Times
Originally Posted by dhawcash View Post
On the dot !
My Lancer had the same problem too, had to get the injectors cleaned but that did not solve it. A mechanic outside of the A.S.S suggested replacing the engine mounts and Voila ! She was back to normal !
gov626 is offline   Reply With Quote
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO In-Car Entertainment 165 18th June 2014 16:10
What makes the Cast Iron (CI) engined Bullets cruise effortlessly at low rpms? aruncheloor Motorbikes 30 2nd July 2012 23:00
Lancer Sluggish at low RPMs leadf00t Technical Stuff 17 14th April 2009 19:00
