Old 29th May 2008, 22:16   #1
techn0l0gist's Avatar
Thanked: 27 Times
Default how does one take apart a strut damper
Hi Everyone,
I have a bunch of Esteem front struts with me lying around (old ones). I wanted to take a peek inside the damper and see how it works. I was wondering how does one take them apart non-destructively.
Any pointers guys on how to do this. I'm the DIY types so would like to take it apart myself :-)
Amit.
techn0l0gist is offline   Reply With Quote
Old 30th May 2008, 00:37   #2
ananthkamath's Avatar
Thanked: 46 Times
There are many things one can do DIY. Non-destructively taking apart a damper is not one of them. Take it to a machine shop and ask them to use a parting tool near the weld. That's the easiest way I can think of.
The other way would be to remove the flanged sheet metal top somehow. Anyone who rebuilds old shocks should be able to do that for you.
ananthkamath is offline   Reply With Quote
Old 30th May 2008, 00:52   #3
iraghava's Avatar
Thanked: 153 Times
If they are old struts why do you want to take them apart non-destructively?
Old 31st May 2008, 23:25   #4
Thanked: 27 Times
I do have access to a machine shop, so i meant doing it myself 'in the machine shop' Thanks , shall try to remove the flanged sheet metal part
hmm I want to figure out what exactly happens when the damper goes kaput, and also I want to experiment with trying to fix/rebuild the damper myself.
Old 1st June 2008, 22:46   #5
you go to howitworks.com and you can read about how the strut works. you can save yourself the hassel of opening up the strut
Shardul is offline   Reply With Quote
Damper (shock absorber) recommendation for Jeeps? ringoism 4x4 Technical 3 12th December 2012 01:11
Ford Fiesta 1.4 TDCI Crankshaft pulley (Damper Pulley) Born 2 Be Wild Technical Stuff 12 24th February 2012 17:13
Damper Disposal dhanushs Technical Stuff 9 19th August 2011 00:14
damper pulley in the palio 1.9d sfilinto Technical Stuff 8 8th December 2008 17:32
What are the benifits of Engine Torque Damper dhananjay Technical Stuff 5 25th August 2006 14:35
