Old 5th June 2008, 13:37   #16
tsk1979's Avatar
Thanked: 16,422 Times
It seems that there is some problem in your control stack module due to which there is some connection between this circuit and the rpm meter circuit. Was the console ever opened?
Old 5th June 2008, 14:10   #17
gd1418's Avatar
Thanked: 656 Times
No, the console was never opened. But could there be a relation with the steering wheel? During alignment, a few days back the steering was removed for centering and then fitted. But I doubt if this could be the cause.
I detected this blinkering only a couple of days back.
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Radiator Fan Blues tsk1979 Technical Stuff 14 29th October 2007 17:31
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Rain Blues! v.tec Shifting gears 16 11th March 2006 12:28
Suspension blues typeOnegative Technical Stuff 9 29th June 2005 12:51
