Old 3rd June 2008, 11:18   #1
gd1418's Avatar
Thanked: 656 Times
Default RPM blues
Friends,
A few days back I noticed by chance a peculiar happening with my Scorpio that is being shown by the RPM meter. When I switch on the side indicators, either the left or the right, then the RPM needle jerks/blinks backwards along with the blinking indicator lights as long as the indicator is on.
But this doesn't happen when the hazard blinkers are switched on. Now, why does this happen? Has anybody experienced this? Does it have to do something with the alternator charging circuit or the battery has gone weak?
Any input shall be helpful.
Old 3rd June 2008, 11:55   #2
suman's Avatar
Thanked: 257 Times
Sounds like a wiring or fuse issue. The hazard warning would be on a separate fuse as compared to the regular indicators I'd think?
Old 3rd June 2008, 12:07   #3
Thanked: 60 Times
Well now this is quite unusual and interesting . Guys shed some light on this please ??
kaush666 is offline   Reply With Quote
Old 3rd June 2008, 12:54   #4
benbsb29's Avatar
Thanked: 4,281 Times
On my bike, when the same started happening, i was told its owing to a weak battery. Replacing the battery took care of the problem.
GD Bhai, i feel its something to do with a weak battery.
Old 3rd June 2008, 14:30   #5
Get the earth in the vehicle checked, also check the amps being made by your alternator with an amp meter.
Gurkha is offline   Reply With Quote
Old 3rd June 2008, 16:47   #6
tsk1979's Avatar
Thanked: 16,422 Times
Do you see any dip etc., when you switch on the headlights?
Old 3rd June 2008, 21:19   #7
gd1418's Avatar
Thanked: 656 Times
No. The alternator is charging properly and the battery is fully charged
Old 3rd June 2008, 23:50   #8
badboyscad's Avatar
Thanked: 172 Times
has to be something related to the wiring from the alternator. few days ago i too experienced a problem(somewhat different kind) with the rpm needle and the diagnostic resulted in an alternator problem.better check it out quick wit a.s.s, because my battery was fully discharged suddenly on a night trip due to this problem.
badboyscad is online now   Reply With Quote
Old 4th June 2008, 00:40   #9
tsk1979's Avatar
Ok gd, try this. Switch on headlights, park close to wall, and then switch on indicator, do you see change in headlight intensity when indicator blinks?
Old 5th June 2008, 00:10   #10
gd1418's Avatar
Thanked: 656 Times
Tried this, but had my own doubts as I've HIDs, that come with their own relays and ballasts. I didn't find any change in the intensity of HLs. However, I did this with my fog lamps as they were the normal bulbs. They too didn't show any change..
Old 5th June 2008, 01:15   #11
ankitahuja's Avatar
Thanked: 46 Times
I can only assume of such possibilities could be due to moisture in the air that's causing some circuit disturbances, that it's been raining frequently in NCR?
Why dont you park in bright sun for few hours and then check the indicators.
Old 5th June 2008, 09:06   #12
tsk1979's Avatar
gd, switch on the fog lights, and then switch on the indicator. Do you see fog lights dimming, or only the alternator needle jerking
Old 5th June 2008, 11:54   #13
Thanked: 103,777 Times
Damn the Mahindra electronics! GD, I am dead sure its a problem with your vehicles earthing. Get it checked.
Old 5th June 2008, 12:18   #14
Thanked: 53 Times
This is due to an earthing problem at the switch, as the hazard lamp work of different switch, the column mounted switch may have a wire touching the earth and drawing more current than required and so this may cause the problem.
dinar is offline   Reply With Quote
Old 5th June 2008, 13:27   #15
gd1418's Avatar
Thanked: 656 Times
Read my post #: 10..
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Radiator Fan Blues tsk1979 Technical Stuff 14 29th October 2007 17:31
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Rain Blues! v.tec Shifting gears 16 11th March 2006 12:28
Suspension blues typeOnegative Technical Stuff 9 29th June 2005 12:51
