Old 6th June 2008, 18:00   #1
MadRash's Avatar
Post Skoda Fabia: Will Red color fade quickly?
Hi everyone. I have booked a Skoda Fabia 1.4 TDI Classic. It has very limited color options. Silver, White, Satin Gery and Red. First I opted for Silver because of its low maintenance. But after seeing the Red, I decided to go for it. But my friend raised a concern. "Will Red color fade?" (Especially in Fabia). Please advice.
Mahesh S
MadRash is offline   Reply With Quote
Old 6th June 2008, 20:21   #2
GTO - Touring's Avatar
All Skoda's boast extremely high quality paint jobs. Don't worry about the colour red; get her waxed up once in a while and you should be all set.
GTO - Touring is offline   Reply With Quote
Old 6th June 2008, 20:29   #3
androdev's Avatar
Thanked: 2,304 Times
Old red octavias still look pretty good. So I don't think you should be worried about fading. But your washing method can cause heavy swirl marks and loss of gloss. This is the main reason behind faded look. It is actually loss of clear coat gloss and not color fading.
androdev is offline   Reply With Quote
Old 6th June 2008, 20:30   #4
svsantosh's Avatar
Thanked: 1,444 Times
good point,
Truth is RED is on Top of the color spectrum. TRUTH also is EVERY color fades on any automobile over a period of time, irrespective of the waxes and teflon coatings one can papmer her with. Red - being on the top of the spectrum, the Human eye can QUICKLY recognize if there is a fade of even a Tiny amount.
White is at the bottom end, and what ever happens to it, the difference is very less noticable.
svsantosh is offline   Reply With Quote
Old 7th June 2008, 23:12   #5
Hi Mahesh,
this being my first post would like to mention that yes dark colors tend to fade at a faster pace as compared to the lighter ones. At the same time it requires a lot of care on ur part to make sure u donot loose the gloss and thrill of that sparkling red colored fabia.
rgds
rubal1983 is offline   Reply With Quote
Old 8th June 2008, 11:31   #6
MadRash's Avatar
Default Thanks a ton
Thank you guys. I'm going for RED. Hope i will give more attention to my car's exterior.
Mahesh S
6 lakhs to repair Skoda Fabia engine. EDIT: Owner sells Fabia as scrap! zombiedriver Technical Stuff 234 27th July 2016 16:32
*Yikes* Brake fade / No Brakes - Cause and Solutions yzfrj Technical Stuff 59 20th September 2010 17:38
Brake fade on Vtec!!! Shan2nu Technical Stuff 11 21st March 2007 14:49
clutch depresses quickly prkothan Technical Stuff 1 16th December 2005 11:36
