| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Distinguished - BHPian ![]() | Nitrous Oxide [n2o] - all we "Need 2 knOw" ![]() Nitrous Oxide is becoming popular by the day and is the answer to everyone's need - POWER, SPEED, ACCELERATION! The world famous brand that gave this magical thing soo much hype is "NOS - Nitrous Oxide System"! They provided one of the most safest, easy-to-use and best systems. Lets see the system that has changed Mumbai cars in the last three years. Speed Run 2003 had a handful of cars [mostly Indian] using NOS. In two years, the number of cars using NOS has almost tripled, and was also being used in the Foreign class. The NOS system can enable you to get almost 20-200 bhp gains. You can improve on your timings by 3-4 seconds. I've found some information on nitrous oxide from the NOS site itself. Nitrous Oxide systems are safe, but you need to select the right system for your engine. If you have a perfect match, you'll have perfect and superb results. Depending on the match, you can get anything between 40-60 bhp minimum. Lets now see the different types of Nitrous Oxide Installations/Systems. Types of Nitrous Oxide Systems - An Overview Of Wet, Dry And Direct Port SystemsFor a FAQ of "Holley | NOS", you can click here > http://www.holley.com/HiOctn/TechSer.../NOSTech5.html or view their Tech section Have any information on NOS? Have any questions on NOS? Share it here!!!
__________________ Team-BHP.com > Motorbikes > Yamaha Cafe Racer Last edited by Rehaan : 21st April 2006 at 12:40. |
| | #6 (permalink) |
| BHPian Join Date: Jan 2005 Location: Hyderabad
| Can we get little deeper!!! Which cars require which NOS Also guys who have NOS , please comment on Increase in BHPS, ANY BLOW UPS, AND INCREASE IN SPEEDS ON DIFFERENT CARS
__________________ One of the things we know is, It's not how stand by your car, its how you race your car. --Jarule |
| | #7 (permalink) | |
| Distinguished - BHPian ![]() | icaeman91, All I understood was that a lean air/fuel mixture helps in less consumption of fuel. With small plug gap, the molecules in the gap are very less, so it was difficult to light. Hence, larger plug gaps were made. Is this information right? Moreover, I didn't understand the following. Please explain in complete detail: Quote:
__________________ Team-BHP.com > Motorbikes > Yamaha Cafe Racer | |
| | #8 (permalink) |
| Senior - BHPian | modern high energy ignition is nothin but the new ignition systems in our cars as compared to those which came quite a few years ago! also it is often practised that 2 separate sets of plugs are used, one when using nitrous and one when not using nitrous,i.e. daily use. for more details and diag on spar plugs visit this link: http://www.ngk.com/sparkplug411.asp
__________________ ...91 is back !!!! |
| | #9 (permalink) |
| Distinguished - BHPian ![]() | This link will give you all the info you need on Spark Plugs http://www.ngksparkplugs.com/techinf...000&country=US In addition to that let me try and explain the other points you have raised: 1) modern high-energy ignition: High energy coils being used on cars for a higher voltage and a shorter pulse, this allows for a larger gap between the points to aid ignition. 2) As for projected nose plugs: They are the standard plugs that look somehat like this: === ^ || --------- | | This is where the center point is raised from the body of the plug. 3) The top arch which acts as the second point is known as the ground strap. In NOS / Forced Induction engines the temprature of the ground strap is about 70 to 100 degrees hotter than in normally aspirated engines. Hence this leads to the ground strap to start glowing(red hot) when it does it can cause premature ignition within the cylinder leading to misfiring, this can be reduced by using plugs that have a shorter ground strap the image below illustrates the same: Do also realise that spark plugs also dissapate heat from the cylinder to the engines head(like a metal spoon kept in boiling milk).
__________________ Am transitioning out... sorry for my absense from the forum, need a couple of weeks more to let things settle down. |
| | #11 (permalink) |
| BHPian Join Date: Feb 2005 Location: Mumbai
| Hey Gordon and all, That Information was just Amazing . I am sure that has cleared many doubts from the minds of the members. Also does anyone know if there are any NOS kits made for bikes in Mumabi like how KS Motorsport makes for cars. If Yes how much do they cost? ![]()
__________________ Regards, Speedster... LIVE LIFE IN THE FAST LANE Last edited by Speedster : 22nd February 2005 at 23:59. Reason: typo error |
| | #13 (permalink) | ||
| Distinguished - BHPian ![]() | Quote:
Another question, what is fouling??
__________________ Team-BHP.com > Motorbikes > Yamaha Cafe Racer | ||
| | #14 (permalink) | |||
__________________ Am transitioning out... sorry for my absense from the forum, need a couple of weeks more to let things settle down. | |||
| | #15 (permalink) |
| Thanks Iceman and Psycho, So where can I find these (sneaky bitz)kits. Are they customised to your bike or standard kits. I have a CBR400 Aero. And how much would Nos (N2O)cost me for a bike or for a car.
__________________ Regards, Speedster... LIVE LIFE IN THE FAST LANE |
| Thread Tools | |
Similar Threads | ||||
| How to go about, for buying Nitrous (N2O / NOS) in India? | Pferdestärke | Modifications & Accessories | 33 | 29th May 2008 08:49 |
| Do-It-Yourself Nitrous Oxide System | zen-ith | Technical Stuff | 1 | 15th January 2007 11:16 |
| nitrous purge kit | street racer | Modifications & Accessories | 14 | 4th February 2006 00:28 |
| NOS, How does NOS work? | DRC | Technical Stuff | 2 | 26th December 2005 12:53 |
| Nitrous Oxide availability? | ashwingop | Modifications & Accessories | 5 | 12th December 2005 11:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
