Old 4th August 2009, 16:47   #16
pradipk's Avatar
Thanked: 21 Times
Hey nice explanation Blue Thunder. Also, as mentioned by you, can this be the major cause of rusting tail pipe?
pradipk is offline   Reply With Quote
Old 4th August 2009, 18:21   #17
devrajman's Avatar
Thanked: 116 Times
Good explanation!
How does good engine health equals to water in silencer?
Also why are fewer new cars having this water discharge?
devrajman is offline   Reply With Quote
Old 14th October 2009, 13:32   #18
black12rr's Avatar
Thanked: 274 Times
^^ I think you dint read the 15th post correctly. Its the cat con doing its job perfectly .
black12rr is offline   Reply With Quote
Old 14th October 2009, 13:52   #19
vintagepoint5's Avatar
Thanked: 40 Times
Useful tips, my elders when used to buy used cars, one of test they check the silencer, if it spewing black smoke that means engine health is bad, if it spewing little water that means engine is in good condition.
If there is a problem in the silencer or muffler, the car will not run smoothly, it makes a difference if the silencer is good the cars well and silently.
vintagepoint5 is offline   Reply With Quote
Old 14th October 2009, 15:44   #20
sgiitk's Avatar
Thanked: 3,884 Times
All cars condense water in the exhaust drum when cold. In fact they need to be run so that the water (and acid) are evaporated off. This is why exhaust life (in non SS units) is about the same irrespective of how much you drive.
Old 15th October 2009, 19:34   #21
mithun's Avatar
Thanked: 59 Times
Just having the Catalytic converter working doesn't makes an engine healthy. There are loads of other factors to consider !
Old 15th October 2009, 20:13   #22
Thanked: 40 Times
hey Guys,
My friend who works in Suzuki factory at Hosur suggests that the steam & further water indicates that the engine is getting the right ratio of fuel & air. The engine getting the right amount of mixture also means to the large extent the engine is sound too.
nandans2005 is offline   Reply With Quote
GoldStar Silencer goswami.j Motorbikes 320 7th February 2016 20:25
RE Thunderbird - Water in silencer - Help! naveenroy Motorbikes 16 14th October 2011 22:41
Wagon R, whitish smoke + water droplets from silencer Rohit26 Technical Stuff 13 5th December 2009 19:45
Baleno silencer touches filcord Technical Stuff 12 8th December 2005 22:20
MATIZ - Silencer noise SCH Technical Stuff 7 23rd March 2005 00:32
