Old 8th June 2008, 18:45   #1
revhappy's Avatar
Default Water in Silencer
Hi Guys,
I have a Zen vxi 2002 done 35000 kms. Off late I noticed that if I start the car and idle it for sometime, there is water in the silencer. I was shocked to see this as I had never thought water can come out of the silencer. I open the radiator and the water level was full, the coolant tank(which is rather small) was at 2 inches below the full mark. I had filled the coolant tank with water untill the full level some 2 months ago. So it doesnt appear as if radiator water is going through the exhaust, otherwise in 2 months all the water would have been over.
I am wondering where this water is coming from. Can you guys please help?
TIA,
Nitin
revhappy is offline   Reply With Quote
Old 8th June 2008, 21:23   #2
nawabnabeel's Avatar
Thanked: 20 Times
yeah its not an issue. i have seen it happen in maruti's petrol cars. don't worry!
nawabnabeel is offline   Reply With Quote
Old 8th June 2008, 22:17   #3
Awaiting Email Confirmation
Thanked: 19 Times
when a hydrocarbon burns in adequate oxygen, there will be 2 products mainly- 1.water and 2,CO2
the CO2 you wont see. the water will spurt out in the mornings or when you rev the car after it cools down when parked. nothing to worry.
Old 8th June 2008, 22:32   #4
manikjeet's Avatar
Thanked: 109 Times
water coming out of the tail pipe is a good thing
it means that the engine is a good state
manikjeet is offline   Reply With Quote
Old 9th June 2008, 18:19   #5
Ricky_63's Avatar
Thanked: 377 Times
Congratulations !!!!!! You have a health engine !! The small quantity of water that you see spewing out means that your engine is in prestine condition.
Though I may not be very technically correct, but I shall try.
This is true for most petrol cars, when the morning temperature is low, water does come out of the tailpipe. You may even have noticed some cars "smoking" in extreme winters, it happens when relatively warm air from the engine comes in contact with extremely cold air.
Hope this clarifies your confusion ?
Old 9th June 2008, 21:36   #6
revhappy's Avatar
Thanks a lot everyone.
Felt very nice to know my baby zen is in good health. I will continue to take good care of it
Old 9th June 2008, 21:41   #7
aaggoswami's Avatar
Thanked: 1,427 Times
Our M800 has the same phenomenon, and I am happy about this!
Its nothing to worry about.
aaggoswami is offline   Reply With Quote
Old 9th June 2008, 22:00   #8
Thanked: 31 Times
Its good sign! My Petrol Innova omits water many occassions when I switch on the engine in cold engine conditions, I saw water dropping from silencer in many MUL cars and when checked with experts I came to know its good sign.
I saw water came out from my Matiz silencer after Mr. Keshav (TBHP username Physco) has installed FFE, I am so happy with his work and improvement of performance of Matiz even with AC on.
I feel after engine heats up water drops disappears into air.
Ravi.
ravibhat is offline   Reply With Quote
Old 10th June 2008, 12:49   #9
aaggoswami's Avatar
Ravi.
When / As soon as the engine heats up, the O2 ( Water ) released in the exhaust is now converted into vapour. So its not visible. This is sometimes the reason for rust inside the surface of silencer.
In case of two stroke engines, we add oil in fuel itself, so the oil deposits wont allow so much rusting. But the silencers of two stroke last less, because they get choked thanks to the unburnt oil that comes out from exhaust.
Old 11th June 2008, 08:01   #10
aaggoswami's Avatar
Originally Posted by aaggoswami View Post
, the O2 ( Water )
Sorry for typing mistake. It was suppossed to be read as the H2O ( Water ).
It was not suppossed to be O2. Again Sorry for this.
Old 3rd May 2009, 08:55   #11
sabret00the's Avatar
Thanked: 43 Times
Almost throughout the entire winter season (Kolkata winter is never extreme) my car's exhaust was smoking a "vapour" like thing. I was extremely concerned with this. It's just a 2 year old ALTO. When I would keep my hand near the exhaust my hand would be filled with condensed water. When I took with up with MASS they played it down saying the engine is in good shape. Even now when there is enough heat and humidity in Kolkata water spurts out of the exhaust. It's just that it didnt seem normal to me that why I'm asking this question.
sabret00the is offline   Reply With Quote
Old 3rd May 2009, 10:50   #12
ImmortalZ's Avatar
Thanked: 139 Times
It is steam yo. No need to be worried. Suffice to say, water in the cylinder will blow up your engine. Therefore, the water is a byproduct of combustion and nothing that is flowing through the system.
Old 4th August 2009, 14:27   #13
devrajman's Avatar
Thanked: 116 Times
why do we say water drops out of silencer is a good sign of a healthy engine?
devrajman is offline   Reply With Quote
Old 4th August 2009, 14:29   #14
Thanked: 24 Times
It's a good sign, my Amby petrol also emits water from the silencer, and I'm happy about the same, though I thought it only happens in Maruti's first.
musicmanaman is offline   Reply With Quote
Old 4th August 2009, 15:46   #15
Blue Thunder's Avatar
Thanked: 330 Times
It is a sign that the catalytic converter is doing it's job well.
One of the things that a catalytic onverter does is as below :
Oxidation of unburnt hydrocarbons (HC) to carbon dioxide and water:
CxH2x+2 + 2xO2 --> xCO2 + 2xH2O
This is the water that we see in the tailpipe. If the tailpipe is not suitably angled to let the water drain out, this could lead to rusting of the tailpipe in humid cities like Chennai !
If the engine heats up and has been running for some time, most of this water will escape in the form of steam : hence the water will be visible mostly in the mornings or other times when the engine has just been started up.
Blue Thunder is offline   Reply With Quote
GoldStar Silencer goswami.j Motorbikes 320 7th February 2016 20:25
RE Thunderbird - Water in silencer - Help! naveenroy Motorbikes 16 14th October 2011 22:41
Wagon R, whitish smoke + water droplets from silencer Rohit26 Technical Stuff 13 5th December 2009 19:45
Baleno silencer touches filcord Technical Stuff 12 8th December 2005 22:20
MATIZ - Silencer noise SCH Technical Stuff 7 23rd March 2005 00:32
