Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 10th June 2008, 23:40   #31 (permalink)
mobike008's Avatar
Well, what a perfect thread for the upcoming monsoon. Even i faced the same problem yesterday while driving back from home. I was faced with heavy rains and my windsheild was fogged like crazy and i use the same method of turning the defrost mode and internal air-circulation and fan speed to top. Still the problem persisted
Now, i will try using the same ac mode and when it fogs, change the setting to fresh air mode, defrost position and turn the switch to red position ( heater). Hope this works, let me try it out.
Any ideas when it will rain again in Hyderabad to try the above?
__________________
I have terrible reflexes- I was once run over by a car being pushed by two guys !!!!!!!
Old 11th June 2008, 02:06   #32 (permalink)
Tool's Avatar
i use 3M's Anti Fog & Demister Liquid.
No Foggy problems for me EVER !
not even if i switch my ac off and roll down my windows straight.usually this is when the glass gets all fogged up.
it used to happen every single time i used to roll down the windows after switching off the a/c . Cold cabin and moist and humid warm air = instant condensation/Fog.
can upload pics of the bottle if you guys want.
Distributed by 3M India. Bought it for 175 Rs.
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 11th June 2008, 13:43   #33 (permalink)
vnabhi's Avatar
Not very far away, I guess. Last year, I was in a similar dilemma, and I was trying all sorts of things. One thing i do remember is that I put the heater on with AC off, and this made my windscreen so damned misty that I could not see an inch ahead, and had to pull over and open the windows a bit to get better visibilty.
__________________
Ford Fiesta 1.6 sxi 2007
WagonR LXi 2001
M800 1986 (sold)
Old 11th June 2008, 13:48   #34 (permalink)
This sounds good. can you please upload the pic?
__________________
This is your life and it's ending one minute at a time.
nishantgandhi is offline   Reply With Quote
Old 11th June 2008, 13:56   #35 (permalink)
mobike008's Avatar
This sounds like a simple solution. Picture please and also how to use the same.
__________________
Old 11th June 2008, 14:17   #36 (permalink)
condor's Avatar
raja748 : Yesterday I have used all the suggestions posted by you in reply to my query.I am happy to say that my problem is nearly resolved now.
@Rajendra, we have given you conflicting suggestions. Which one has worked for you ? Pls let us know.
Eg: I use cooling of the air directed to the windshield to prevent fogging. Others have used warm air on the windshield to prevent fogging. Which one did you use ?
__________________
Life is Analog. Digital is an approximation.
Old 11th June 2008, 14:46   #37 (permalink)
amit_mechengg's Avatar
i dont know what solution was that, but i had purchased a kit from bharat petroleum pump. it had a solution to be mixed with water, very dilute and put in the washer tank. the water dropplets dont remain on the windshield. it was effective even when my wiper blades had gone bad.
__________________
" I dont Drive Fast , I Fly Slowly "
Old 11th June 2008, 14:53   #38 (permalink)
rkbharat's Avatar
How is this done? I am bit confused
In my SX4, first I have to switch on the AC and then set the temperature to low or high. And switch on the blower. If I switch off the AC with pointer on hot, blower just gives the normal air. I do not see AC and heater as two separate unit.
__________________
Cheers. Rajiv
SX4-ZXi, May 2008, 21000KM, FE City 12, 20% AC
Maruti 800, 1999, 9600 KM
Indica V2, Sold, 97234KM 18Km/L.
rkbharat is online now   Reply With Quote
Old 11th June 2008, 16:39   #39 (permalink)
Jaggu's Avatar
That reminds me i have the same with me, havent used it yet, picked it up from Ind Nagar 100ft Food world. Will try and post feedback.
@Tool: Did you apply it only on the inside OR even outside? My issue was with outside fogging.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 11th June 2008, 16:41   #40 (permalink)
Jaggu's Avatar
Yours is an automatic climate control unit i assume since its Zxi, there are two separate units but controlled automatically by the electronic climate control.
__________________
Old 11th June 2008, 17:30   #41 (permalink)
rkbharat's Avatar
Yes its automatic climate control, and that might be the reason. Still today I will check if heater is working when AC is switched off. may be its not working because it senses the temperature.
__________________
Cheers. Rajiv
Old 11th June 2008, 17:47   #42 (permalink)
vnabhi's Avatar
Yes, if you have climate control, I guess you cannot use both AC and heater, as the inbuilt program might think you have gone bananas!
__________________
WagonR LXi 2001
M800 1986 (sold)
Old 11th June 2008, 17:50   #43 (permalink)
condor's Avatar
Jaggu : My issue was with outside fogging.
@Jaggu, if you are seeing outside fogging, is it when you use warm air on the windshield as your anti-fogging ?
if yes, you could try using cool air on the windshield instead.
__________________
Old 11th June 2008, 18:00   #44 (permalink)
I wasnt talking greek here or was I ??
Originally Posted by dadu View Post
Well then buy and try this Anti-Fog and please post the results.
__________________
"I cannot be fair with everyone in Life" - dadu, 2001
Old 3rd July 2008, 14:40   #45 (permalink)
condor's Avatar
nishantgandhi : Actually my issue is still un-resolved. I have to probably get my wiper blades replaced.
raja748 : ...I never faced this problem before as I am driving this car since more than 3 years now
raja748 : ... since last 2-3 years during rainy season. I never experienced this problem before.Why only now..Same place,same car,same AC setttings,same kind of rain..I am really unable to figure it out..
@Raja, I may have the definitive answer to your problem : Looks like your car -and your wipers are about 3 years old. The problem is possibly with your wipers. Replace them, and check it out.
My wipers are into their 3rd season, and I seem to be facing the same problem now. Problem seems to disappear after some time of using the wipers.
__________________
Thread Tools
Urgent - help required for ps3 akshay1234 Gadgets, Computers & Software 12 14th October 2009 22:21
Urgent Help Required - Sub Enclosure manojgautham Ask the Gurus 7 11th February 2008 15:24
Urgent: Blood required at Delhi Joz Shifting gears 6 13th July 2007 18:10
urgent help required with spyware aadix Shifting gears 34 21st March 2007 21:38
Help required on a used Palio 1.2... Urgent! extreme_torque The Indian Car Scene 13 6th February 2006 07:45
Powered by vBulletin
