| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #61 (permalink) | |
| Newbie Join Date: Aug 2007 Location: Bangalore
| Quote:
As always the service center guys are clueless and all known temperature, air direction, etc balancing acts have failed to resolve this. Wiper blades move up, create milky hazy layer which impedes visibility greatly. Blades do a fine job of wiping the water but layer remains. Then it magically disappears after about 20 seconds. If the rain is heavy and blades are being used continuously the layer actually gets worse!Tried changing the blades, different cleaning liquids from MGA to Amway to something from the Dollar Store. All help with cleaning, but nothing, i repeat NOTHING, fixes the layer. Someone...anyone, HELP! | |
| | #62 (permalink) |
| BHPian | Coincidence or not, even the thread starter Raja also had a Swift Vxi. Looks like the issue is model specific than generalised with other cars. I have seen the fogging issue in most cars, but trying different methods mentioned in this thread, atleast one will defenitely work. Trying methods keeping the fact in mind; hotter side of the glass gets fogged/misty, will help anyone. I found certain things to be followed against our inclination in a rainy situation ; AC ON in the rain, Heater ON when you are in a comfortable, cozy feeling etc.
__________________ "Woods are lovely, dark and deep. But I have promises to keep and miles to go before I sleep." Robert Frost Last edited by shajufx : 9th July 2008 at 22:06. |
| | #63 (permalink) |
| BHPian | There are two basic reasons behind condensation/fogging, and hence two things required to resolve it. First is humidity and second is temperature. More humidity means more condensation, and also less temperature means more condensation. Humidity is increased due to rains and people inside the car. AC lowers the temperature and de-humidifies the air. For internal fogging AC is very effective, de-humidification instantly clears internal fogging even if inside temperature is quite lowered due to AC. For external fogging, we don't have control over humidity as well as temperature of outside temperature. So, for that the only thing we can do it is raise the temperature of the "glass". This can be done by using heater along with AC. Rear defrosters too do the same, they are nothing but low powered heaters for the "glass". There seems to be probably a myth that heater and AC can not be used simultaneously, or may be some (probably older) cars indeed don't allow this for some reason. However, I would expect defrost mode in modern climate control ACs to be using AC and heater simultaneously. All that aside, I think the problem reported here somewhat different, it has something more to it than just temperature and humidity. I have started facing this problem in my 2 and a half year old car. That misty layer gets formed only when wipers are used. It clears automatically withing a few seconds, sometimes takes more. Also it tends to get spread with wipers. When the car was new, this problem was almost non existent, but it has grown over time and now about to become a concern. I naturally thought that it may be due to aging wiper blades, and was also thinking of replacing them with "Bosch" ones, but going by the experience here, it may not really solve the problem at all! Sometime I feel like it is some sticky, oily layer that may have formed on the glass. So, cleaned it properly with detergent and started using Colin glass cleaner in the wiper solution, but in vain. Hope somebody nails it down and suggest a sure shot solution ![]() |
| | #64 (permalink) | |
| BHPian Join Date: Aug 2006 Location: Pune
| Quote:
| | #65 (permalink) |
| I also agree with Santosh S.I have tried cleaning windshield with MGA glass cleaner,but the result is not satisfactory.Even dealer people are clueless.Surprisingly,the problem has erupted this year only. Should I try contacting windshield experts?what do you feel friends? |
| | #67 (permalink) |
| BHPian | If that is the situation, there should be lot of drivers complaining about the same issue, whichever car is passing the 2nd year. My car is only 1 year old, I had a terribly blocked view of the road previous week, while moving towards cubbon park in the heavy rain after 7pm. In a hurry to reach the place, I didnt try any of the methods mentioned in this thread (infact I saw this thread yesterday !!), but desperately tried to wipe the driver portion of the glass (inside) with a towel every 5 minutes ! I wished there was a wiper inside too ! So, the solution seems to be trial & error method as someone already mentioned above !
__________________ "Woods are lovely, dark and deep. But I have promises to keep and miles to go before I sleep." Robert Frost |
| | #68 (permalink) |
| BHPian | Memphis, Raja, Try the following: - Do a thorough clean of the windshield with Colin or a good brand of windshield cleaner. Use a Window Squeege ( Its a rubber strip with a handle that works like a wiper blade, but does a much better job than a cloth ). - Clean the wiper blades with a wet cloth. if you suspect dirt sticking, then use a very fine sandpaper ( zero number?? ) to clean the blades and then clean with water. - There are anti-rain liquids - ABRO and Rain-X that you can use on the outside to coat the glass with. These will improve the beading of water thereby making it easy for the wiper blade. - Check if your windshield has micro scratches. this normally is the cause for the milky coating when you use the wipers, since dirt/oil may getinto the scratches and cause this. replacing the blades and a thorough cleaning normally should 'reduce' the effect. Hope this helps. cheers
__________________ "Horn Please OK Tata" ---------------------- Landrover.....ka bhai, aur ek tall boy! |
| | #69 (permalink) |
| BHPian Join Date: Sep 2007 Location: NA
| Guys, before jumping on the effective measure of cleaning and all that, let me ask one question first: Do you have the same problem of poor visibility when you splash water and wipe even on a sunny day? If not, the glass is perfectly fine. You don't have to take so much pain to clean it as of now. If the issue is of the condensed vapours on the glass inside the car, this is purely because the temperature of the glass is lower than the air inside the car. Please cool the inside cabin (or the air near the glass) with closed air circulation A/c turned on or please warm up the glass using heater. PLEASE, this is very IMPORTANT. I have seen enough of petty accidents even at snails pace when rain pours. It is important because the other drivers will not know that someone is not able to see what is in front of him. |
| | #70 (permalink) |
| BHPian | Let us not digress into fogging problem in general, which can happen anywhere on all glasses, from inside or outside. As many people have already mentioned, including myself, that AC+heating definitely works fine for this. The specific problem that needs to be addressed is the milky layer getting formed when wipers are used, which tends to spread with moving wiper blades and stay for some time. Washing the glass has not helped many people, and in case of the thread started, even changing to Bosch blades has not helped. Please note that it is applicable only to outside portion of front windscreen and that too the area covered by wipers. (raja748, kindly correct me if I am wrong. That is the case with me at least) |
| | #71 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| May have posted this before, solution is very simple: For the outside of the windshield, the cause is traffic grime and oily deposits which come from fumes - wipe with a wet cloth with some Surf excel/Ariel powder on it, do the same to the wiperblades. Rinse with clean water. This will clear the problem, guaranteed, for at least three days. For this purpose I keep a small cloth dampened with strong detergent solution in a plastic bag in my door-pocket. For the inside of the windshield - the A/c on recirculation mode should clear it up. If your car has no a/c, wipe the inside of the windshield with a dilute detergent solution and let it dry, without rinsing. This will prevent fogging on the inside.
__________________ Baleno Vxi 05 Ritz Zxi 09 |
| | #72 (permalink) | |
| BHPian | Quote:
After few seconds of the wiper blade wiping the area, it clears up by itself. So I practice to keep the wiper to intermittent mode, or sometimes trigger manually for more delay when it just drizzles or small showers. But can't help much when it pours. Driving slowly and cautiously is the solution. (Fogging is something different than this issue has many remedies which are tested to be working and explained many times on the forum and in this thread. So no more solutions are required for fogging.) | |
| | #73 (permalink) | |
| Quote:
| | #74 (permalink) |
| My understanding of possible cause/solution aspects of the "milky" situation from what's been posted here thus far:
I know I haven't really provided a solution here, but its comforting to know I'm not the only one with this freak occurance. Guess I'll keep doing the trial and error method with all possible options and keep everyone posted on results. All the best to members of the Milky Way ![]() |
| | #75 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Urgent - help required for ps3 | akshay1234 | Gadgets, Computers & Software | 12 | 14th October 2009 22:21 |
| Urgent Help Required - Sub Enclosure | manojgautham | Ask the Gurus | 7 | 11th February 2008 15:24 |
| Urgent: Blood required at Delhi | Joz | Shifting gears | 6 | 13th July 2007 18:10 |
| urgent help required with spyware | aadix | Shifting gears | 34 | 21st March 2007 21:38 |
| Help required on a used Palio 1.2... Urgent! | extreme_torque | The Indian Car Scene | 13 | 6th February 2006 07:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
