| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #76 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
| This happens a lot to all cars, it is not manufacturer specific. I think you probably have a pollution, wax, grease, cleaner chemical cocktail layer on the outside windscreen. You will not remove it unless you are willing to use a LOT of near boiling water, strong soap and muscle. You may have to repeat the dose 3 or 4 times, and clean the wipers or get new ones while you are at it.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #78 (permalink) |
| BHPian | DirtyDan, I do not think the problem is due to contaminated surface of windshield. If so, ity would not be clear and satisfactory "other than 'milky layer' problem only during showers'. Shreyas, do you think windshield of all over cars who experienced need any kind of repair? I hope not so. Looks like there is no solution to eliminate the problem or workaround. Some-one here would already have addressed the concern by this time if there is any. I also feel that, not all of us have experienced the issue and so most of the posts on this thread are made without visualising the problem detailed in the first post of this thread. |
| | #79 (permalink) | |
| Team-BHP Support ![]() | Quote:
Can it just be that nowadays due to availability issues a lot more cars are running on premium fuel instead of ordinary.
__________________ Ever catch yourself listening to a nice song on the radio and dedicating it to your car. | |
| | #80 (permalink) |
| BHPian Join Date: Aug 2006 Location: Pune
| Dear Friends, After all the discussion and suggestions here...I am very sad to say that the problem still persists.I miss the clarity I used to get two years back.The misty/milky layer makes my drive scary...especially in the night when the lights of the vehicle coming from the front is on my eyes ![]() |
| | #82 (permalink) |
| Newbie Join Date: Aug 2007 Location: Bangalore
| Switched to new Bosch ones too. Been using them a few days. They work like a charm. Raja I know you changed blades earlier but still faced the same issue, me too, but I really feel you should try again. Make sure you get the original ones through the company or distributor. You can check on the company website for contact details and download the official size spec sheet. I had posted details of both in a different thread (sorry in a hurry or I'd do it here too , just search June/July threads for Bosch. ATB! |
| | #83 (permalink) | |
| Quote:
I have got original from authorised distributor of BOSh in Pune,M/s.Kotkar Automobiles,Pune.You can find his name on BOSH website as well. | |
| | #84 (permalink) |
| Team-BHP Support ![]() | Installed some local wipers for 200/-. Bosch (wipers) and time (mine) not available. waiting for it to rain. Rain Rain come again, Little Jhonny wants to play.
| | #85 (permalink) |
| Raja, how's the experience with the new blades been? After a fortnight's use I'm seeing that mist but just for a second and then the blades take care of it. Much much better than stock wipers. Also can anyone confirm, for the Swift, these are just supposed to clip in, right? Because I changed them myself and want to be 100% sure. |
| | #86 (permalink) |
| BHPian | Try using the thermostat setting to get the right ambient temperature so that there is no mfogging up either on the inside or outside. It works. And add colin to your windshield washer tank to remove grease from the glass.
__________________ The greatest mistake you can make in life is to be continually fearing you will make one. Last edited by wanderernomad : 5th August 2008 at 15:02. |
| | #88 (permalink) | |
| Senior - BHPian | Quote:
Would suggest you change the wipers.
__________________ Honk your Head off. I will NOT jump the red light | |
| | #89 (permalink) |
| BHPian Join Date: Jun 2008 Location: Kolkata
| He changed the wipers to Bosch Blades as mentioned in the first post... I am a complete novice here, but will putting a cleaning agent/colin in the windscreen washer reservoir help? If this milky layer is indeed oil/grime from the atmosphere, then we can spray some of the windscreen washer fluid and clean the windscreen on the move... right? This experiment will also confirm is the layer of dirt is responsible for the impaired vision... Last edited by AbhiJ : 5th August 2008 at 15:42. |
| | #90 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| I am facing the same problem. No matter whether it is raining or dry outside, the moment I switch off the AC after a few mins of operation, the inside windscreen becomes heavily misty/foggy. I tried opening the window but it doesnt help. As a last resort, I direct cold/hot air to the windscreen (though still in RECIRC mode) and it clears the windscreen momentarily, but the problem still persists. Is there a permanent solution to this?
__________________ This is your life and it's ending one minute at a time. |
| Thread Tools | |
Similar Threads | ||||
| Urgent - help required for ps3 | akshay1234 | Gadgets, Computers & Software | 12 | 14th October 2009 22:21 |
| Urgent Help Required - Sub Enclosure | manojgautham | Ask the Gurus | 7 | 11th February 2008 15:24 |
| Urgent: Blood required at Delhi | Joz | Shifting gears | 6 | 13th July 2007 18:10 |
| urgent help required with spyware | aadix | Shifting gears | 34 | 21st March 2007 21:38 |
| Help required on a used Palio 1.2... Urgent! | extreme_torque | The Indian Car Scene | 13 | 6th February 2006 07:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
