Thread Tools
Old 9th June 2008, 12:35   #1 (permalink)
Default Problem in shifting to lower gear
Dear friends,
I have a Hyundai Accent 2000 model. Of late i have noticed that when i am driving and i try to shift to a second gear at a low speed itself, while driving, the gear shift is not very smooth. in fact the notchy shift is even more pronounced when i try to shift to first gear even while driving slowly. sometimes there is some resistance in shifting to first gear. similarly, while engaging a reverse gear, of course from a dead stop, sometime the gear does not fall smoothly and there is a kharr sound.
i know that the gear box is not very smooth. what could be the trouble? should i try changing the gear oil? i have bought this used car and am not aware when the oil was last changed?
Please let me know how to go about this. it is not a major trouble but i do not want to ignore the issue and wait for it to worsen.
Cheers,
Harsha
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 9th June 2008, 17:46   #2 (permalink)
iceman91's Avatar
check the oil and also the syncromesh...
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 9th June 2008, 17:50   #3 (permalink)
nitrous's Avatar
Sounds like a Synchro problem.
__________________
youtube.com/watch?v=FiVicNOA3bY
Old 9th June 2008, 17:52   #4 (permalink)
iceman91's Avatar
yeah the synchro is out of sync
__________________
...91 is back !!!!
Old 9th June 2008, 17:58   #5 (permalink)
snaronikar's Avatar
Best option for gear box problem is take it to a showroom and show them the vehicle.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 9th June 2008, 18:20   #6 (permalink)
Thanks for the inputs guys. now that it seems to be s syncromesh issue, how do you think i should go about it? should i show it in the showroom as mr. naronikar suggests or is it something simple that can be taken care of by the simple roadside mech? any estimates of the possible scenarios and the associated costs?
__________________
Old 9th June 2008, 18:37   #7 (permalink)
Harsha, it could be a simple clutch adjustment issue.
Old 9th June 2008, 18:52   #8 (permalink)
I second Anup. That sounds like a clutch issue to me.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 9th June 2008, 19:01   #9 (permalink)
viper's Avatar
Hi Harsh,
Is is most likely a synchro issue only.
@GTO & Anup - The Accent has a hydraulic clutch where there is no setting available.
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 9th June 2008, 19:21   #10 (permalink)
You could be right Viper.
It is a hydraulically actuated clutch. That does not preclude adjustment of actuator. The symptoms appear to be of a clutch that is not getting fully un-coupled.
Old 9th June 2008, 19:30   #11 (permalink)
viper's Avatar
The only scenario I visualize that happening would be a faulty clutch bearing or loss of clutch fluid where that could happen(unlikely). My money would still be on the synchronizer.
@ Harsh - Is the pick up of your car ok and how many kms have you done on your clutch. If you have clocked in excess of 50k kms then it could be your pressure plate as mentioned by the others.
Viper
__________________
Old 9th June 2008, 20:09   #12 (permalink)
DirtyDan's Avatar
Default Kind to you
Harsha
I am afraid you have classic symptoms of tranny going bad. GTO and Anup are trying to save your wallet undo strain but I think its the synchros and collars as noted in other posts. The symptoms are too well described by you.
See...
Howstuffworks "Shifting Gears"
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 9th June 2008, 20:22   #13 (permalink)
iceman91's Avatar
If only Synchromesh should not cost more tahn 5k including labour.
__________________
...91 is back !!!!
Old 10th June 2008, 10:30   #14 (permalink)
Hi pals,
to answer some of your queries, the accent is a 2000 model which has surprisingly done only 38 k kms till date. i am the third owner and i have reason to believe the kms represented because the interiors were pretty fresh, the tyres were the same 7 year old ones bearing the right date etc. i know they are not fool proof methods but did seem convincing then. even my mech agreed.
coming to the issue, i have noticed that the clutch releases a little late. that is when i release the bottom half movement of the clutch, the gear is not fully engaged, it is the few centimetres of the latter(upper) half of the clutch release that engages the gear fully.
so, in addition to the above diagnosis, is my clutch open to setting?
now that the clutch issue is clear, i do not think it could be a matter of the clutch not fully engaging, could it?
as regards pick up, it is just fine n i love the way the car pulls. i run it on lpg though.
as regards syncromesh, is it a part capable of being repaired or is it necessary to change it? i will also read the link of how stuff works.
Harsha
__________________
Old 10th June 2008, 10:57   #15 (permalink)
iceman91's Avatar
Synchromesh rings have to be replaced they cannot be repaired.
__________________
...91 is back !!!!
Thread Tools
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 42 12th June 2008 07:45
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 81 10th February 2008 11:58
Car banged. Gear shifting problem! maxbhp Technical Stuff 15 15th September 2007 12:48
Car shudders in lower gear ajayclicks Technical Stuff 21 2nd April 2007 15:15
Future of gear shifting naveendhyani Technical Stuff 1 22nd April 2006 02:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
