Old 10th June 2008, 14:38   #1
nishantgandhi's Avatar
Thanked: 151 Times
Question Weird sound from the rear in Getz
I have been facing a strange noise since the last few days in my car. It has worsened with the onset of rains.
When in 1st/2nd gear at normal speeds, or when I slow down to stop at a signal, or when there is sudden braking (not at very high speed), I hear a 'thump' kind of sound from the rear (left) of the car.
It is as if someone suddenly dumped a heavy box in the boot. The car feels slightly weighed down (for a fraction of a second) at the rear. At times I felt as if the car was being 'pulled' at the rear, in the opposite direction, when this sound came (although only for a fraction of a second).
This sound is not continuous and does not occur on a daily/regular basis.
I also noticed that the sound has accentuated after I start the car which has been parked in the rain throughout the day. So initially I thought the brakes have gotten wet.
Braking is fine and the car has done 21000 kms till now. However, this sound is making me feel uncomfortable.
What could be the degree of intensity, source and solution of the problem?
nishantgandhi is offline   Reply With Quote
Old 10th June 2008, 14:44   #2
Thanked: 25 Times
What could be the source and solution?
Sry no clue!
Getting it checked @service centre might help!
Elito
Elito11 is offline   Reply With Quote
Old 10th June 2008, 14:51   #3
Thanked: 151 Times
Originally Posted by Elito11 View Post
Sry no clue!
Elito
Thanks that was extremely helpful!!
Old 10th June 2008, 14:54   #4
Jaggu's Avatar
Thanked: 8,693 Times
Check the rear drum brakes, seems like a sticky brake pad due to water.
Old 10th June 2008, 17:54   #5
Akshay1234's Avatar
Thanked: 7,243 Times
the getz is known to have a tak tak sound from the rear when braking.
Old 10th June 2008, 17:58   #6
Thanked: 151 Times
So any solution to it? What is the cause for the same?
Old 10th June 2008, 19:33   #7
aaggoswami's Avatar
Thanked: 1,542 Times
Its nothing but the rear brakes.
@akshay1234:
If this was the fact, it would have been troubling him since 21K kms. But this problem surfaced now.
Mostly rear brakes are culprit.
aaggoswami is offline   Reply With Quote
Old 10th June 2008, 19:44   #8
DirtyDan's Avatar
Thanked: 776 Times
I think Jaggu has nailed it. Many rear brakes do this on many vehicles. A 100 rupee clean up and inspection is in your future.
Old 10th June 2008, 20:28   #9
Akshay1234's Avatar
@akshay1234:
it might not be but im just letting him know that this is a common problem in the getz. there are enough including me who have faced this. the tak tak noise is very soft and isnt even noticeable most of the time.
Weird Sound in AC Blower Fan in Swift petrol Endofdayz Technical Stuff 16 7th May 2011 18:46
Getz CRDi - Heavy Clunky sound when the rear tyres go over broken + uneven surface. pb10gagan Technical Stuff 13 9th March 2011 14:39
Scorpio VLX weird sound while reversing pramods Technical Stuff 9 8th October 2008 11:14
Palio 1.2: Weird sound while driving extreme_torque Technical Stuff 8 8th May 2008 14:07
