Old 10th June 2008, 14:41   #1
amtak's Avatar
Thanked: 382 Times
Default Water in Running board of my Zen
Guys, like last year, water has again entered the running board of my Zen due to some water logged area i had to drive through. I tried to clean the drain holes which are there below the running board so that the water can come out. However, its is still there and not coming out. Please help me to get it out as I don't want it to get rusted.
Thanks!
amtak is offline   Reply With Quote
Old 10th June 2008, 14:55   #2
Jaggu's Avatar
Thanked: 8,694 Times
Remove the carpet fully and let it dry outside after washing it, meanwhile wash the inside of the car and wipe it clean (floor area), allow it to dry. You have to remove the seats and gear lever console for the same.
Old 10th June 2008, 15:02   #3
kpzen's Avatar
Thanked: 1,655 Times
The car's floor is flooded or the running board ???
Old 10th June 2008, 15:31   #4
amtak's Avatar
Thanked: 382 Times
Its the running board. Water did not enter inside the car.
Old 10th June 2008, 19:33   #5
thirst4torque's Avatar
That is only possible if there is a hole in the running board somewhere. You will have to eliminate the source otherwise it will create more problems.
thirst4torque is offline   Reply With Quote
Old 11th June 2008, 11:54   #6
amtak's Avatar
Thanked: 382 Times
AFAIK, there are 2 holes on either side of the running board for the water to drain out. I went to the service station and got the clogged water out.
Old 11th June 2008, 12:13   #7
theodore_ftw's Avatar
Did they offer you any solution to the problem? I hope the water is not entering through the drain holes themselves! If it is then it might a good idea to probably seal it off to avoid water coming in.
theodore_ftw is offline   Reply With Quote
Old 11th June 2008, 13:12   #8
Jaggu's Avatar
lol i mis read your post sorry.
Pressure wash helps to clear of the muck, leaves etc that get stranded and block the drainage provision for running board.
Old 11th June 2008, 13:16   #9
I hope they are sealed by a cap? Blowing air through the holes might help in drying the water. But I am not sure how effective it will be, you can give it a try.
Distilled Water : A scam running? lapis_lazuli Technical Stuff 59 23rd December 2015 19:12
Inspiration: Sign Board @ Silk Board. Drive to Tamil Nadu kaushik_ak Travelogues 17 3rd January 2014 20:37
Yellow board running with my stolen spare wheel cover - what to do next? HappyWheels Street Experiences 57 1st June 2010 16:34
Maruti Zen submerged in water AKNAN Technical Stuff 9 28th August 2009 18:16
Zen - Running in (engine noise) gchandra Technical Stuff 25 7th January 2007 17:56
