| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) | |
| BHPian Join Date: Mar 2005 Location: bangalore
| Quote:
__________________ There is more to life than incresing its speed! | |
| | #32 (permalink) |
| Senior - BHPian | Hi Guys, I have carried out porting / polishing on almost all the cars I own and will recommend it to anyone who is performance oriented. Like any performance modification to gain something you have to loose something. FE is affected only when you drive hard. If drivem normally it improves. This will again defer in the manner in which the porting is carried out. Also porting should only be done after a free flow and not before . Call or pm for any more details/ Viper
__________________ NO ONE DARES COME CLOSE |
| | #33 (permalink) | |
| BHPian | Quote:
It wouldn't be feasible to port and polish standard passenger cars.......... if you've read anything on the subject you'll know that it's the cast irregularities that we're out to smoothen........... assembly line cars are like building blocks put together...... they work fine that way so the manufacturers don't care.......
__________________ Zeropointeight for me to keep and miles to go before I sleep............ | |
| | #34 (permalink) |
| BHPian | " polishing ports to a mirror finish. This actually does more harm than good. Remember it is not only air which is flowing but atomised fuel along with it. The problem with fuel is that, since it weighs more, it's difficult to keep it evenly mixed with the air as it follows the contours of the port." " he next time you drive a car in the rain, notice that when the car is going 60 KMPH, the rain drops go up the hood of the car at walking speed. That's because the smooth surface of the car creates what's known as a boundary layer, and the portion of that layer of air that's nearest to the surface is almost still. The same thing happens inside an intake port. Except instead of raindrops, it is fuel droplets that will run down the port wall slower than the air. That causes a serious change in the fuel air mixture by the time it reaches the cylinder, ruining much of the engine's potential power. Polishing the port walls will ensure this happens. Instead, by making a series of rough 60 grit lines that purposely go against the flow, the ‘boundary layer area’ will be turbulent, and the fuel will stay well mixed and suspended in the air. Remember: Rough is Good !!" Source: http://auto.indiatimes.com/articlesh...,prtpage-1.cms Now many a times i have see that shaving and shining the ports seem to be a std level 1 mod for almost all car entusiasts! Can someone be kind enough to eliminate the doubt? Thanks, Madan
__________________ Taken the plunge! www. virtu. in __________________ 2002 Lancer | 2006 Palio | 2008 Trek 4300D |
| | #38 (permalink) |
| BHPian Join Date: Apr 2006 Location: navi mumbai
| that was going to be my second question. seriously speaking, i read something online about smaller ports making more power, and i thought it was bs. just confirming.
__________________ America's best sedan! 220hp, 143mph, $20,000. Olé! |
| | #39 (permalink) |
| i just read up more on it. they are called high velocity ports. they are smaller than stock and make more power. some of the bikes that won the AMA supersport championship have them. the real question, as viper said, is how to make them.
| | #40 (permalink) | |
| BHPian | Quote:
I read that article close to 2years ago and asked a whole bunch of similar questions. Then realised what a bunch of bull all this velocity porting really is. Will post up tomo morning about why it doesnt work in detail.Too sleepy rite now Heres a like to the article for those who havnt read it Think Fast--Intake Porting For Motorcycles and Cars | |
| | #43 (permalink) | |
| BHPian | Quote:
Also all this welding and all doesnt quite work when your working on engines. | |
| | #44 (permalink) |
| Distinguished - BHPian ![]() | Velocity porting will only work on very high revving NA engines and there too they are of limited use. Port angles are way more important to give you the maximum gain. The best way to explain is to say that you ought to be able to design a port that would maximise the air entering the cylinder with the least resistance on the valves.
__________________ Learning is a continuos job that keeps me busy. |
| | #45 (permalink) |
| just the kind of answer i was hoping to get. yes it was motoman, been reading a couple of things that seemed too good to be true. @cbr do write why it doesnt work, i'm interested.
__________________ America's best sedan! 220hp, 143mph, $20,000. Olé! Last edited by heelntoe : 30th November 2006 at 12:55. |
| Thread Tools | |
Similar Threads | ||||
| Polishing the car/bike. | v12 | Technical Stuff | 40 | 27th September 2008 12:27 |
| Glass/headlight Polishing | itszain | Technical Stuff | 3 | 3rd July 2008 11:29 |
| Looking for porting polishing & valve grinding in Delhi | RedMM340 | Modifications & Accessories | 15 | 25th June 2008 22:19 |
| Hi every1 - Porting / polishing in mumbai? | cancerm | Modifications & Accessories | 2 | 18th October 2007 01:52 |
| Waterless washing and polishing system | giri | Modifications & Accessories | 0 | 7th December 2005 12:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
