Old 12th June 2008, 07:46   #1
Default Sluggish Alto VXI
I have 2 cars bought in Oct 2002, both alto VXI. Both have done similar kms, 45k or so. One of them offlate has been very sluggish in accelerating on all gears. Also its mileage has come down to 12kms/l. Got the timing checked, injectors cleaned, compression checked, air filter changed but no improvement. Even at slightest of climbs I have to come down to lower gears ...some time at first if the speed is low ....where the other car races at 2nd or 3rd gears.
Any pointers as to what can be wrong? Should I get the timing advanced? I have always taken the car to Maruti authorized dealrship and they dont hav a clue as to what could have gone wrong with the car.
Ankur426 is offline   Reply With Quote
Old 12th June 2008, 12:52   #2
Worn out clutch, wheel alignment could be other reasons..
amu1983 is offline   Reply With Quote
Old 12th June 2008, 14:35   #3
thirst4torque's Avatar
Everything points to a worn out clutch. Get it checked.
thirst4torque is offline   Reply With Quote
Old 16th June 2008, 13:50   #4
It cannot be a worn clutch, because if that case the RPMs would go up on hitting the gas but car would still not accelerate. In my case he rpms were also not going up.
Got the timing advanced by a degree and things look good now. Does anyone know if there can be a side effect of this on the fuel efficiency or engine life?
Old 16th June 2008, 15:07   #5
amit_mechengg's Avatar
Thanked: 1,556 Times
did u do this from MY car, they are the only people i have seen asking for timing advances
Old 16th June 2008, 18:01   #6
arpandiv's Avatar
Thanked: 27 Times
How is the timing advanced by 1deg. on the Alto VXi
arpandiv is offline   Reply With Quote
Old 16th June 2008, 23:09   #7
by adjusting the distributor setting.
Sluggish Swift, Edit: And other swift speed related queries pillainp Technical Stuff 90 8th September 2009 21:27
LPG mis-firing/back-firing/sluggish ranjithbalan Technical Stuff 4 26th April 2007 14:55
Pulsar 180 sluggish after 100kmph member Motorbikes 6 23rd August 2006 22:51
Sluggish Brakes on my Accent libre sito Technical Stuff 15 8th October 2004 19:19
Why is Suzuki India so sluggish? SLK The Indian Car Scene 7 10th June 2004 15:42
