Old 13th June 2008, 16:15   #1
Thanked: 70 Times
Default Water entering my car through the floorboard
My cars a Santro Xing, and I'm having this wierd problem that theres water entering my car through the floorboards. This is not due to driving thru flooded roads or stuff. It appears that when the car is in motion on wet roads, the water is splashing up and entering the car. I've tried to look under the carpets and find a hole or rubber stopper missing, but no luck. I also seem to have water in my doors, so when I open/close the doors, I hear the water swishing inside. Any idea how to stop this. Cars pretty well maintained, and in an AMC. Been thru three monsoons before without any issues.
Would appreciate any help in resolving this issue.
Lalvaz is offline   Reply With Quote
Old 13th June 2008, 16:22   #2
kapilsharma80's Avatar
Lalvaz, there should be a rubber seals underneath the doors. remove them and the awter will drain out.
kapilsharma80 is offline   Reply With Quote
Old 13th June 2008, 16:30   #3
Thanked: 70 Times
Hi Kapil,
I'll do that. Infact I've already done that to drain water in the boot, but the water keeps returning. Is there any permanent solution to this? Am I the only one with this problem or is it something that other Santro owners are facing as well.
Cheers,
Lalit
Old 13th June 2008, 16:43   #4
thirst4torque's Avatar
[quote=Lalvaz;865308]theres water entering my car through the floorboards. This is not due to driving thru flooded roads or stuff. It appears that when the car is in motion on wet roads, the water is splashing up and entering the car. I've tried to look under the carpets and find a hole or rubber stopper missing, but no luck. I also seem to have water in my doors, so when I open/close the doors, I hear the water swishing inside. Any idea how to stop this.quote]
Water entering the doors can be attributed to the worn out window rubber moulding. Rain water might be seeping inside because of this.
Water entering the floor is surely because of a damaged rubber stopper.
Also check for the ac pipes. They might be the source of water condensation.
thirst4torque is offline   Reply With Quote
Old 13th June 2008, 16:48   #5
V-16's Avatar
Thanked: 621 Times
There are various points in the flooring where water could be entering from. Check the rubber boots near the pedals. Maybe one of them is missing. Also check the front wheel wells. Other that that there could be a leakage from under the engine side. If you can figure out from which part the water is coming in, ie which part of the flooring gets wet first then you should mark it and take the car to an authorized Hyundai dealer and get this sorted out or you will have a bad time during floods.
V-16 is offline   Reply With Quote
Old 13th June 2008, 19:20   #6
abhik's Avatar
It might be condensation like i faced in my car.
abhik is offline   Reply With Quote
Old 26th June 2008, 21:02   #7
Thanked: 70 Times
Hey finally seem to have gotten rid of the water issue in my car. Apparently the problem was that there are two channels for rain water which enters near the windshield to drain away from the underside of the car. Now, these channels were blocked at the discharge end, so all the water that entered from the windshield area was stagnating in there, leading to it entering the car from near the firewall area. Since I have rubber matting over my carpets, the water was not visible over the mats, but was all over the carpeting.
The reason for the blockage was leaves and corrosion, so anyways, the Hyundai service center has increased the size of the holes and cleant the debris there, so the water now drains thru the channel and does not enter the car. However, theres some corrosion in the car, due to all the water accumulation. So, need to get some tin work done. Thinking of waiting till the monsoon gets over to finally tinker with the metal and then do the paint job as well.
Thanks for all your inputs guys. Surprised none of the other Hyundai Santro owners seem to have faced this problem ever, atleast none of the folks on this forum...
Old 26th June 2008, 23:21   #8
theMAG's Avatar
Thanked: 372 Times
Earlier cars used to have drainage holes in the floor . But on a newer generation car this is surprising.
Old 27th June 2008, 10:59   #9
amit_mechengg's Avatar
Thanked: 426 Times
can you tell the exact location where you find the water. i had faced similar problem in my brand new car. it happened to be the wheel arcs where the most trusted brand MARUTI had missed out one weld spot due to which the water was entering.
Old 27th June 2008, 13:35   #10
Thanked: 70 Times
Hey Amit - Sorry, I dont know the exact spot the water was entering, but it was somewhere below the dashboard, actually just below the ending of the rubber mats on both the left and right sides. So, I could not see the water on top of my rubber mats, but the floor carpetting was soaked, and on one occasion, we've mopped up a whole bucket of water from the soggy carpet, and it was still wet.
Like I mentioned the Hyundai service center fixed it now. But have'nt checked it, since I've not yet driven the car in the rain since then. Will check over this weekend.
Old 27th June 2008, 13:40   #11
Thanked: 70 Times
I believe the Santro has drainage holes in the floor too. I'm sure they have it in the boot, cos I've opened that a couple of times to drain off excess water, but these drainage holes are usually blocked with rubber stoppers, so you need to open the holes manually in case of water logging.
In my case, apparently two drain channels were blocked with leaves etc.. which resulted in water stagnating in those two channels. This water somehow entered the car just below the rubber mats, so I was'nt even aware of the water till my cleaner pointed it out to me.
And as per Amits email, a similar case happened to his Zen as well, so I guess even modern cars have old problems.
What to check for outside smell entering the car cabin? satish_appasani Technical Stuff 19 31st August 2012 09:17
Help!Water getting inside car sans33 Technical Stuff 31 11th July 2012 12:06
Skoda:Rain water entering the engine through the air filter koshy10 Technical Stuff 28 11th November 2009 10:22
I'm entering the mother ship of all car freaks turbolover Introduce yourself 16 16th June 2005 19:30
