Closed Thread
Old 4th October 2008, 13:12   #121
archat68's Avatar
Thanked: 290 Times
Can any private service station in Kolkata do it? Suggest me Kolkata guys.
archat68 is offline
Old 4th October 2008, 17:07   #122
Raccoon's Avatar
Thanked: 105 Times
Well, I just got my Esteems injectors cleaned by Millenium Mobility (it is a M.A.S.S. in Pune).
This is what read in the Labour charges section of the bill:
FUEL INJECTOR CLEANING (PETROL) 400
So they have used petrol to clean it... and used 400 bucks worth of it??
If one uses additives like System G, should it not keep the injectors clean and not require cleaning by the service centre?
Raccoon is offline
Old 4th October 2008, 19:46   #123
Eddy's Avatar
Thanked: 5,067 Times
I think they meant cleaning of petrol fuel injectors.
Eddy is offline
Old 4th October 2008, 20:25   #124
Sudipto-S-Team's Avatar
Thanked: 266 Times
Your carburetted zen, by definition, doesn't have a fuel injector!! It has a carburator. You should let only highly experienced old mechanics touch that. The Johnny Come Lately mechanics can ruin the carburator setting by trying to clean it and adjust it etc.
With old machines, don't try to fix things that aren't broken.
Sudipto-S-Team is offline
Old 5th October 2008, 19:28   #125
archat68's Avatar
Thanked: 290 Times
I didn't mean injector cleaning. I meant engine de-carb.
archat68 is offline
Old 6th October 2008, 16:28   #126
Thanked: 266 Times
Any reputed service station should be able to do it. Where do you stay in Calcutta?
Old 6th October 2008, 16:57   #127
archat68's Avatar
Thanked: 290 Times
Haridevpur - near Tolly Metro. I do all my work at Lansdowne Automobile (I know the owner there) - but they don't have facility for decarb.
archat68 is offline
Old 7th October 2008, 19:04   #128
amit_mechengg's Avatar
Thanked: 1,556 Times
the workshop should have a machine that costs around 25k for the decarb procedure.
bigger workshops might have them, but almost all the authorised service centres have them
amit_mechengg is offline
Old 7th October 2008, 20:30   #129
humm's Avatar
Does anyone know any reliable service center in Mumbai wherein I can get my dad's opel car decarbonized and fuel injector cleaning etc done?
Any idea how much will manual cleaning cost and how much the other method wherein using additives the guys clean?
Main question... Where in mumbai?
humm is offline
Old 8th October 2008, 04:18   #130
mdesai_1981's Avatar
hi humm,
i know a service center in borivali west. its called St. Francis. its located near St. Francis ITI in borivali(w). ask anyone and its a well known place.
they are A.S.S. for maruti and hyundai but they service all cars they have the equipment and peace of mind. they charge 750/= for my chevy optra injector cleaning and 1000/= for engine decarb for my car.
u can also search this very same thread for the guys located in santacruz west.
mdesai_1981 is offline
Old 8th October 2008, 12:13   #131
kailashnj's Avatar
Thanked: 281 Times
Hi Mdesai,
Can you provide correct address for ST. Francis. I would be interested in getting my car serviced from there for Injector cleaning and decarb.
kailashnj is offline
Old 8th October 2008, 22:43   #132
hi,
st francis is loacted at poisar in borivali west. its in the same line ahead of bhagvati hospital. the contact number is 28951206. contact a guy called waltern he's the best guy around and his knowledge is fantastic in cars. i know him personally and u can give him my reference.
Old 27th October 2008, 12:45   #133
Default Engine flush vs Decarbonisation
Went to the Maruti workshop the other day with my brother's Alto for some suspension problems. It also needed some long due servicing. The car has done 32K and so the service person suggested doing a decarbonisation. Later on was informed by a friend that it's actually an engine flush and not a decarb.
Did some digging around and ended up with more questions.
Engine flush: The machine is hooked up to the fuel lines while the engine is being revved up. I can understand the solvent will be able to clean up the intake ports off any old oil (no carbon as we surely haven't started to burn anything). Once inside, the solvent burns up like normal fuel. Will it still retain the capability to clean the inside of the engine and the exhaust ports?
How is a decarb done? The cleaning I think involves the combustion chamber and the exhaust ports as well. Sounds very much like a manual process, but they sell machines for decarb, don't they?
As if all this was not enough add to that, soft and hard decarbonisation!
Any help from the experts please?
Lumina is offline
Old 13th November 2008, 09:26   #134
NetfreakBombay's Avatar
Thanked: 402 Times
As per this news Engine Flush can actually wreck the engine and is not recommended. Though it was sold by quite a few service centers to undercover reporters.
Could This Damage Your Car? | NBC Los Angeles
NetfreakBombay is offline
Old 13th November 2008, 09:39   #135
Swifty2008's Avatar
I'm sacred now. I just did an engine flush during my 30k service. But this is the first time I'm hearing this kind news.
Swifty2008 is offline
Closed Thread
Cleaning a cast-iron engine block? jagadeesh.b Technical Stuff 10 7th September 2015 18:21
My Fuel injector cleaning with carbon clean enigmatictech Technical Stuff 17 15th May 2014 20:36
Carbon Cleaning RJK Technical Stuff 5 23rd June 2011 19:59
Automatic Engine Decarbonisation bill1182 Technical Stuff 15 3rd September 2007 14:27
