Old 14th June 2008, 13:38   #1
CrAzY dRiVeR's Avatar
Thanked: 19,801 Times
Default Help with part idenitification
Was just cleaning and checking the fluid levels, when i noticed this pipe hanging loose in the engine bay. Tried to keep it back in place, but it seems very arrogant not to obey. And, i need the car later in the evening, so cant leave it unattended.
1. What is the purpose of this hose?
2. Is it ok to drive the car to the service centre, which is a few kilometres away, with this wire hanging around?
3. Don't know when it came lose. But by the position, it looks like its been taking atmospheric air, instead of purified air from the air filter. Any harmful effects, or any parts i should get checked?
Pics are attached-
Name:  14062008199 copy800.jpg
Old 14th June 2008, 14:28   #2
Its too late to edit. So, another post-
Pic 1- shows the disconnected part.
Pic 2- shows the other end.
Pic 3- Shows the way its connected to the filter.
Old 14th June 2008, 14:46   #3
vikram_d's Avatar
Thanked: 940 Times
Looks like the breather/vacuum tube. You can drive all you want with that tube disconnected. Will cause no harm. But always better to get it put back in place.
Old 14th June 2008, 14:51   #4
Jaggu's Avatar
Thanked: 8,685 Times
Use a plier to press the clip at the tip and then insert it back OR spread the clip and move it backwards on the tube, insert the tube and move back the clip to lock. This is the valve cover breather tube.
Old 14th June 2008, 14:56   #5
Ford Rocam's Avatar
Thanked: 16 Times
The plastic part surrounded by clip looks like its broken.
Ford Rocam is offline   Reply With Quote
Old 14th June 2008, 16:29   #6
Jaggu's Avatar
oops yes, take it to garage and replace it. Dont run too much, though its not a crisis yet.
Old 14th June 2008, 19:55   #7
Thank you guys very much. I guess 10 kms of driving wont hurt. Will get it checked by monday.
It does look like the plastic broke off from the box!
Old 14th June 2008, 21:48   #8
nitrous's Avatar
Thanked: 285 Times
Thats the breather hose,man. No issues if its out of the airbox connection.
Old 15th June 2008, 02:32   #9
rohan_fonseca's Avatar
Crank case ventilation. No issues driving the car to the service station.
rohan_fonseca is offline   Reply With Quote
Polaris Slingshot: Part car, part motorcycle, all excitement ashkamath The International Automotive Scene 0 2nd September 2014 17:12
After service, part comes loose. Please help? hellmet Motorbikes 4 18th August 2012 15:31
Help Help Urgent Help!!! abhibh In-Car Entertainment 12 11th April 2006 12:15
