Old 17th June 2008, 09:47   #1
lurker's Avatar
Thanked: 678 Times
Default Rear Jack placement in M800 ?
A M800 has flat rear tyres. But I cannot find the place (a stable flat surface) to fix the jack near the rear wheel. There seems to be no flat surface available. The older model of the M800 used to have a flat surface near the rear wheel IIRC. But the later models seems more crude. Any advice on this count is welcome.
lurker is offline   Reply With Quote
Old 17th June 2008, 09:52   #2
manikjeet's Avatar
Thanked: 110 Times
its placed under the rear shocker
manikjeet is offline   Reply With Quote
Old 17th June 2008, 09:56   #3
lurker's Avatar
Thanked: 678 Times
So do I need to fix the jack from behind the car, rather than from the conventional sideways ?
one can't approach the rear shocker from the side no ?
Old 17th June 2008, 10:02   #4
manikjeet's Avatar
Thanked: 110 Times
yes you have put the jack from behind you can put the jack sideways but it will require a lot of force
Old 17th June 2008, 10:05   #5
lurker's Avatar
Thanked: 678 Times
thanks for the advice manikjeet, i will try it out now.
Old 17th June 2008, 10:43   #6
lurker's Avatar
Thanked: 678 Times
ok the flat has been replaced. But I wonder why Maruti has made it so cumbersome.
It is a surefire method of soiling a clean pair of trousers.
manikjeet, many thanks to you again for your timely help.
Old 25th June 2008, 19:38   #7
jramprakash's Avatar
Question Can leaf spring handle pressure of Jacky...
Guys,
If we put Jacky on the Leaf Spring can it handle the pressure??
Looking for an expert reply!!!
Ram
jramprakash is offline   Reply With Quote
Old 26th June 2008, 00:43   #8
rider60's Avatar
Thanked: 47 Times
Originally Posted by jramprakash View Post
Guys,
Ram
well its not recommended unless one has no choice but to try this, mounting the jack on the leaf spring might be very very risky as the jack has high chances of slipping as its not straight(non parallel to the ground), only under helpless conditions and under the guidance of an experienced person should one do so.
EDIT:instead why not try the rear axle for the same in the leaf spring version of m800, i have the same version too.
rider60 is offline   Reply With Quote
SQ settings for my Santro's setup and rear speaker placement options sidindica In-Car Entertainment 2 6th February 2012 15:46
LED placement options in the rear of a hatch greenhorn Modifications & Accessories 12 6th April 2009 19:32
2004 Zen: Rear speaker placement sansjunk In-Car Entertainment 4 8th March 2006 17:38
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
