Thread Tools
Old 17th June 2008, 19:48   #1 (permalink)
Unhappy Indigo Engine Problem
I Drive a Petrol2004 Model Indigo GLX model ,which is also fitted with LPG kit.
Recently i am facing a problem,that whenever the car is idling it shudders/Jerks in between.The same thing happens at lower gears and slow speeds.Also at 4 and 5th gear ,there is not much acceleration and after continously flooring the throotle to the ground car is only manages to reach 85-90km/hr.hence around 10 days back i gave it for servicing at the company outlet .Even after 6 days they are not able to fix the problem or even say what is wrong.
Yesterday they called and told me that they have identified the problem.i am no expert on car ,but this was their explanation-that there is problem between the connection from the vaprisor of LPG kit and the Injectors on the manifold.On taking the car along with the service guy to the place where i fitted my LPG kit.LPG kit guys removed the LPG kit injectors and reconnected the original connectors.The problem persisited .the LPG guys told its not the problem of LPG kit,coz problem is therein the original petrol mode of the car.
Now my Service guys are spooked ,best thing they came up with is to ask me to drive the car for a while(50-100km) and if the problem persist again they will check the same .
I did Exactly that and after driving for about 170 km(in petrol mode),found that the problem still continues and Insult to injury is that for the highway runing that i had done ,the mileage i got was only 8km/litre.Hence three days back i again gave the car to the authorised Tata service centre .Now i've been told that there is a current leak from "hot wire cable"( i have no idea what it is),which i have to replace with a new one(cost around Rs900).All these things are not inspiring much confidence because for the same problem,eachtime the service guys are coming with newer solutions.
Some other information about my Car
It has done a total of 45000km.As a part of
the service All sparkplug has been replaced,new airfilters,Coolant and engine oil etc has been changed.
Kindly give your suggetion what might be wrong with the engine.
ranjeetnair is offline   Reply With Quote
Old 17th June 2008, 23:01   #2 (permalink)
wolfinstein's Avatar
Are you noticing any soot deposit on the New Plugs...!
Also did you check the Ignition Coil, At times these weaken not neccessarily fail to be recorded by the ECU.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 17th June 2008, 23:36   #3 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Check spark plugs, plug wires, coils and then only proceed to injectors. Also a good time to do a compression check to see if all well with cylinder, rings etc.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 18th June 2008, 00:17   #4 (permalink)
drpullockaran's Avatar
Default Have a fuel pimp check
After the compression and spark flow is verified please check the fuel output of your fuel pump.
__________________
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Thread Tools
Tata Indigo LX Problem: Car Constantly Pulling Sideways Digital Vampire Technical Stuff 10 11th October 2007 17:53
Tata Indigo SX 15000 Km Report - Clutch problem shankaranand Long-Term Ownership Reviews 2 24th August 2007 12:39
Problem with ICE in Indigo Marina prakashchopper Ask the Gurus 7 11th May 2007 21:44
Small-engine Indica @ Rs 225,000, Indigo XL DICOR and Petrol 100bhp rkg The Indian Car Scene!! 47 2nd January 2007 21:46
Tata Indica, Indigo and Marina : Dicor engine sakthivelm The Indian Car Scene!! 1 16th October 2006 21:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
