Old 18th June 2008, 13:57   #1
neoonwheels's Avatar
Thanked: 599 Times
Default Palio 1.2 NV Sport starting problem
Car: FIAT Palio 1.2 NV
Make: Apr 2005
guys,
I am facing a weird problem in my 3 years old Palio 1.2 NV. It does not start at times when I crank the engine. This happens randomly at anytime. It happened when:
1. Car was parked for 2 days
2. Car has run 50-80 KM for an hr. and stopped the engine for 20 min
3. If I stop at any signal and then try to crank the engine.
IIn 2-3 attempts I am able to crank the engine. This does not happen everytime but randomly at times. So I can not predict when can it happen. I have shown this at 3rd service to BU Bhandari and they did not experience this.
Could you guys please let me know probable problems?
neoonwheels is offline   Reply With Quote
Old 18th June 2008, 14:16   #2
finneyp's Avatar
Thanked: 160 Times
Neo, does it happen at morning cold starts or during the drive?
Sometimes, when you are driving and the car gets stopped abruptly like when car is moving dead slow in 2nd gear and engine stops (without you switching off the ignition) , it takes 2 - 3 cranks to start the car.
But, if you switch off the ignition & then switch on and start, the engine will start in the first crank itself.
If this is what you are experiencing, it is normal and nothing to worry about.
finneyp is offline   Reply With Quote
Old 18th June 2008, 14:25   #3
bottle's Avatar
Thanked: 133 Times
Originally Posted by neoonwheels View Post
Make: Apr 2005
guys,
I faced this issue sometime ago. Turned out to be a faulty starter motor/self start. Got it overhauled and its been fine since. Had the same problem where it wouldnt work randomly like when the engine stalled in the middle of a busy junction
but the symptoms i faced was that the engine would not even turn
bottle is offline   Reply With Quote
Old 18th June 2008, 14:34   #4
jacs's Avatar
Thanked: 715 Times
From past 2 months even I have faced the same issue couple of times on my 2004 1.2 NV Sport thought its not frequent.
My battery is now 4 years old and I'm really scared whether this is a symptom of age.
jacs is online now   Reply With Quote
Old 18th June 2008, 15:23   #5
kapilsharma80's Avatar
Thanked: 25 Times
Make: Apr 2005
guys,
ask the dealer to get the 'self' cleaned and serviced by TVS Lucas service engineer. I had the same problem and TVS guys took care of it (my car is stillunder warranty).
Last edited by kapilsharma80 : 18th June 2008 at 15:31. Reason: car - under warranty
kapilsharma80 is offline   Reply With Quote
Old 18th June 2008, 19:21   #6
Thanked: 599 Times
No Finney, it happens randomly. Say I switch off the engine at some place.. then whenever I try to crank after sometime lets say 10 min to few hours, the engine would not crank.. But you can not predict when it will happen..
Old 18th June 2008, 19:22   #7
Thanked: 599 Times
Facing the same issue. May be I can go back to BU and ask them to check starter motor
Old 18th June 2008, 19:23   #8
Thanked: 599 Times
I will do it at the earliest.. My car is 3 years old and so the battery.. Its Amaron though..
Old 19th June 2008, 16:39   #9
Thanked: 25 Times
neoonwheels - any progress!
Old 19th June 2008, 17:03   #10
Thanked: 599 Times
Will go to the Service center this Saturday... Will update you guys then...
palio 1.2 nv starting problem kapilsharma80 Technical Stuff 7 1st February 2010 22:51
Palio starting problem amit Technical Stuff 34 23rd August 2009 14:05
palio D starting problem garychopper Technical Stuff 7 19th August 2007 20:39
help me decide-palio sport or adventure sport 1.6 for city driving premchetan Hatchbacks 46 9th February 2007 17:44
palio 1.2 starting problem. passionpurple Technical Stuff 8 8th June 2006 23:24
