| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2006 Location: New Delhi
| Hi,my Baleno is making some boom kind of sound and vibration at around 2200-2300 rpm.This sound starts at near 2000 RPM and peaks at 2500 RPM.It is similar to sound we get from worn-out wheel bearings at high speed.But it is coming even when it is raved standing still.I spent nearly 2 hours at Maruti Service Masters,but they couldn't sort it.Strangely,it has started after regular service at 50000 km,when they changed all filters and spark plugs,cleaned injecters and throttle body.
__________________ Great ideas need Landing gear,as well as,Wings. |
| | #2 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Did you check all the air filter hoses, are they fit properly? Any leakages at intake side? What about your water pump/fan belt? Is it tightened proper, read as NOT over tight.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #3 (permalink) |
| Yes they checked,and found belts a bit tight and loosened these.But still no difference.While driving,it sounds like diesel jeep.You reach above 2000 rpm and start to sound boooom and as you lift off,it increases and gives vibrations.
| | #4 (permalink) |
| Ok plug in the engine diagnostic thingie and see if anything is wrong. If ok move on and see if your engine firing is proper (plugs, plug wire, coil) and also the injectors (any lef over stuff after cleaning).
| | #5 (permalink) |
| They diagnosed with Tech 2 and told me there is no error code.They didn't checked plugs and injectors,saying there is no missing.May be Ineed to go to another workshop.
| | #6 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
Infractions: 0/1 (4) | Looks like ignition problem. OT: Our family friends Baleno ( also bought with us in October in 2005 ) had this problem but was more pronounced at 2000 rpm. The fault they could find was ignition system. They replaced coil and plugs.
__________________ EVENTUALLY FATE DECIDES EVERYTHING. |
| | #7 (permalink) | |
| BHPian | Quote:
Check the following: The exhaust manifold, the muffler itself and The catalytic converter. | |
| | #8 (permalink) | ||
| Quote:
I got muffler checked,its ok.Don't know about manifold and cat
__________________ Great ideas need Landing gear,as well as,Wings. Last edited by sans33 : 19th June 2008 at 13:57. | ||
| | #9 (permalink) |
| Forgot to mention,FE has gone down as well.Prior to this 50000 km service,Iwas getting 11+ in city and 15+ on highway.Now its down to 10 in city and 13 on highway.
| | #10 (permalink) |
| BHPian | @sans33 - Can you please take a video of this and post it on youtube?
__________________ Don't quit when the hill is steepest, for your goal is almost nigh; don't quit, for you are not a failure until you fail to try Last edited by BlackPearl : 19th June 2008 at 14:46. |
| | #11 (permalink) |
Infractions: 0/1 (4) | They have one equipment that looks like a Gun. I forgot what is it really called. With this they can check wheather the sparks are proper or not. If the plugs are new then Ignition coil can be identified as improper.
| | #12 (permalink) |
| I consulted a local mechanic today.He says I better ignore this sound,as it is from some internal bearings,and for which whole engine will have to be opened. But I'm not ready to believe it,as it has started suddenly after sevice.
| | #13 (permalink) |
| Distinguished - BHPian ![]() Join Date: Feb 2005 Location: Mumbai-India
| Going by symptoms i could only think as of now that it could be sound from the intake, since you have got it serviced recently & got filters changed including the intake filter, have them recheck the entire intake,filter box,intake pipe and the hoses associated with it.
__________________ Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap. Last edited by Ford Rocam : 19th June 2008 at 21:05. |
| | #14 (permalink) | |
| Quote:
If you can post a sound clip of the sound, we might be able to help further.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #15 (permalink) |
| Checked the intake myself.Everything is fine.Interestingly,as I revved engine,standing in front of it,I couldn't notice this particular noise and vibration. Will try to record this in morning.
| Thread Tools | |
Similar Threads | ||||
| Scorpio 2.6 non crde mild engine vibration | Mohnish | Technical Stuff | 23 | 13th July 2008 19:39 |
| baleno making kr..kr..kr..kr noise | gigy | Technical Stuff | 19 | 6th July 2007 19:33 |
| noise and vibration | akshay1234 | Technical Stuff | 7 | 5th July 2007 20:10 |
| Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL | DieselFan | Technical Stuff | 36 | 2nd May 2007 11:37 |
| Engine noise | DaCentaur | Motorbikes | 0 | 19th August 2006 23:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
