Old 23rd June 2008, 07:38   #1
panky12345's Avatar
Thanked: 150 Times
Default BRC MPFI CNG Kit?
Hi, I tried searching but couldn't find about the above....
I'm planning to buy a Tata Xeta and put a CNG kit. The dealer advised me to go in for a BRC MPFI kit and quoted me 62K for it. I feel thats on a higher side. He also told me that Shrimankers are no longer associated with TATA and I need to get the CNG fixed from them only to avoid warranty issues.
Can someone advise? Where should I get the CNG installed from to avoid warranty issues? Is the BRC thing better than normal one?
Old 23rd June 2008, 12:56   #2
amit_mechengg's Avatar
Thanked: 1,556 Times
why dont u buy the newly launched indica Xeta LPG instead. and yes you have to speak to your dealer once before u plan to put an outside kit, to ensure that ur warranty doesnt get void.
Old 23rd June 2008, 15:03   #3
abhik's Avatar
Bro the price quoted to you is a very good deal because a CNG MPFi kit or more commonly known as Sequential Injection Kits are available at around 70k. These kits are very good as compared to normal kits as they provide maximum efficiency and performance.
abhik is offline   Reply With Quote
Old 26th June 2008, 08:04   #4
wolfinstein's Avatar
Panky,
The BRC kit is good, but its a 4 Gen Sequential. which functions like a sequential, but also does give petrol running option.
However the advantage over closed loop is great, and It has my recommendation.
Please note that putting in sequential, will need replacement of the Intake manifold and drilling into the new manifold.
Shrimanker does only Open or Closed loop fittments. BRC is the new OEM for Sequential kit.
At 55 K + RTO work, its a great buy. Go for it.
wolfinstein is offline   Reply With Quote
Old 26th June 2008, 18:09   #5
nitrous's Avatar
Thanked: 285 Times
If Tata Indica Xeta CNG is available at the showroom, pick it up.
Or pick up a diesel Indica.
Why are u particular about petrol + CNG?
Old 26th June 2008, 18:34   #6
panky12345's Avatar
Thanked: 150 Times
thanks guys
@wolf: its 62 + 2,500 for insurance extra
@ nitrous: no factory fitted option is available, already have a diesel indigo. want something to run real cheap. also, the warranty doesn't get void.
Old 29th October 2008, 12:40   #7
panky12345's Avatar
Thanked: 150 Times
Update: The car is steady Rs. 1.26/km on BRC CNG kit, is it OK? Heard perkm costs are under 1 Re.
Old 29th October 2008, 12:43   #8
nitrous's Avatar
Thanked: 285 Times
Is this the CNG sequential injection kit that you enquired about earlier,panky??
Old 29th October 2008, 12:58   #9
panky12345's Avatar
Thanked: 150 Times
yep, thats right nitrous! thats the same one..
Old 29th October 2008, 13:00   #10
Eddy's Avatar
Thanked: 5,078 Times
1.26 does sound a little on the higher side. Speak to Wolfie and confirm though.
Eddy is offline   Reply With Quote
Old 29th October 2008, 13:11   #11
panky12345's Avatar
Thanked: 150 Times
i recollect wolfie gets around 15.5 - 16km/Kg, that amounts to around Re. 1.22/km.
Old 29th October 2008, 13:42   #12
kjdesigns_2000's Avatar
Currently my Esteem with a clogged air filter is giving approx .90 - 1.00 Rs/-per KM. And i seriously, find it on the higher side.
The best i could do was one way to the border of Ludhiana from delhi on a tank full of 180/- Rs Gas.
Keep your airfilter clean and see the average go up. Also i feel short distance travels really kills the average.
kjdesigns_2000 is offline   Reply With Quote
Old 29th October 2008, 15:24   #13
panky12345's Avatar
Thanked: 150 Times
esteem is known to give the similar results as you posted here.. just wanted to have an opinion from any Indica + CNG user.
Old 1st November 2008, 13:08   #14
panky12345's Avatar
Thanked: 150 Times
Bump.... no CNG users here?
Old 1st November 2008, 13:14   #15
ashthedivx's Avatar
Thanked: 22 Times
huh...
http://www.team-bhp.com/forum/modifi...-cng-cars.html (Performance Mods for CNG Cars)
cheers:
Wagon R LXI CNG Vs Wagon R VXI + CNG Kit ajay387 Hatchbacks 37 7th October 2013 22:54
Company Workhorse : New Eeco 5 seater CNG or Used Dzire + CNG kit? NMM What Car? 2 4th February 2013 19:29
BRC Kit Problem - Cedia LPG LetsGo Technical Stuff 1 29th May 2011 10:22
