| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Sep 2006 Location: Mohali, Bangalore
| Hi folks, I have noticed lately that my Ikon's front left tyre is getting uneven tread wear on the inner most side.Also the tyre position doesn't feel straight to me. It seems to be protruding out. I went for Wheel alignment & the guy there advised me to get the car checked for camber repairs. Before going for a checkup, I want advise on what could the cause be. Is it due to faulty lower arm? Also the silenser assembly needs to be replaced & as i have recently shifted to Bangalore ( I am in Brookefields) , I would request Bangalore members to guide me to a good car mechanic. lastly, if you guys can let me know what i needed to shell for camber repairs / lower arm replacement & for a new silenser assembly. The car in question is Ikon 1.6 2003 model. |
| | #5 (permalink) |
| Senior - BHPian | Pankaj, defintiely seems to be a problem with your alignment which is leading to the uneven tyre wear. As you rightly said, make it a point to get the camber settings also checked. I would suggest you get it checked from Cauvery Ford (now called Magnum Honda) on Kanakpura road, or some good tyre shop. I think Madhu's is a good option? Ajmat's option is also worth checking out. Have heard good things about them on the forum. |
| | #6 (permalink) |
| BHPian | Hi Pankaj, I would suggest getting a second opinion regarding the wheel alignment (it obviously is an alignment/camber issue), just to be on the safe side from a good place. Ajmat and Benny have mentioned some and though I am not familiar with them, please do have it checked from there. Maybe Ajmat and Benny would be able to give you their contact info and address so it is easier to reach there. Regarding a faulty lower arm, did u happen to bump your car tyre on to something or went into a pot hole too hard? It usually takes some abuse to have a faulty lower arm, though you can never be sure of those things. I have been a Metro Ford customer (near MG Road, before Koshys on the opposite side of the road) and have been satisfied by the service rec'd however would be good if you check with Cauvery also once as have heard better reports for them.
__________________ Honk your A** off. I will NOT jump the red light Last edited by sammyboy : 24th June 2008 at 16:15. Reason: addition |
| | #7 (permalink) |
| Senior - BHPian | As others has mentioned it, it certainly is a alignment issue. The cauvery Ford (Now Magnum Honda) on Kanakapura road no longer is a ford A**. Hence the only authorised A** left in Bangalore is Metro Ford. I do not want to comment on the servicing of this as I have not experienced on this dealer on A**. But one more ford A** called Lathangi Ford Opp to IIM Bangalore is a new dealer in place of Cauvery Ford. You may try it. If you are staying in Bangalore (West), I would recommend to try United Motors at Rajajinagar Industrial Town. He does a pretty decent job. Hope this helps.
__________________ Love your job but Never love your company because you never know when your company stops loving you-NRN Last edited by snaronikar : 24th June 2008 at 19:30. |
| | #8 (permalink) | ||||
| Thanks a lot ajmat, benbsb29 & samyboy for your suggestions Quote:
Is Metro ford service center also at MG Road? Quote:
I stay in Brookefields (south east ) so might be i'll try to check Suraksha as ajmat pointed out or will go to Metro Last edited by pankaj_sachdeva : 24th June 2008 at 19:42. | ||||
| Thread Tools | |
Similar Threads | ||||
| Good Mechanic for Pulsar 150 cc old type-Bangalore | msvg | Motorbikes | 10 | 28th February 2008 17:13 |
| Required Good Maruti Gypsy Mechanic in bombay | devil_in_flesh | Modifications & Accessories | 0 | 2nd January 2008 16:30 |
| Ford Ikon - Need a good Mechanic | sherintjacob | Technical Stuff | 4 | 12th October 2007 14:41 |
| Info Required : Good Petrol Station in Mysore | manjubp | Indian Car Dealerships | 3 | 5th May 2007 13:13 |
| Good Maruti Mechanic in Bangalore | rameshspassion | Indian Car Dealerships | 3 | 21st February 2006 20:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
