Thread Tools
Old 28th June 2008, 01:31   #1 (permalink)
married2speed's Avatar
Default McLaren - Heikki's Barcelona Crash
Hi Guys
Just got this piece of information from msn today. Would apprecaite if someone could shed some more light on the "bold" part.
A meticulous joint investigation into the cause of Heikki Kovalainen's Barcelona crash has finally got to the bottom of why the McLaren driver was pitched into the barriers during the Spanish grand prix.
It was originally speculated that the Finn's accident was caused by a sudden, catastrophic, structural failing of the left-front wheel rim.
McLaren chief executive Martin Whitmarsh later added that, based on initial trackside evidence and speculation, stones or debris coming into contact with the wheel could have triggered the structural damage.
At the same time, an exhaustive investigation, in collaboration with wheel supplier Enkei and the FIA technical team, was launched.
"The investigation not only involved thorough scrutiny of the telemetry data and a microscopic analysis of the surviving components, but also a simulated reconstruction of the event back at the McLaren Technology Centre," Whitmarsh said at the Silverstone test this week.
He explained that the investigation showed that a central area of the rim had been left unmasked before being sprayed with lacquer -- a common practice to improve the efficiency and longevity of components.
The resulting lacquered surface significantly reduced lock-hold on the wheel rim.
This meant that the wheel and axle on Kovalainen's MP4-23 began to move apart under high cornering loads, leading to rubbing against the brake drum, fatigue, and a failure of the rim's inner lip.
"We now thoroughly understand how the failure occurred; not, as was originally reported, as a result of a wheel failure but by the incorrect application of a lacquering process which was beyond the control of our wheel supplier, Enkei, with whom we have enjoyed a fantastic relationship for more than 10 years," Whitmarsh added.
He said procedures have been put in place to ensure the incident cannot repeat.
Does this also apply to normal indian cars?
Would appreciate the info.
Cheers!
M2S
P.S. : Mods, please move to relevant forum if this may not be it.
__________________
Married 2 Speed, can't divorce it
married2speed is offline   Reply With Quote
Old 28th June 2008, 05:14   #2 (permalink)
Tight , nice catch - reading up on it soon.
Cheers man
cyneverdie is offline   Reply With Quote
Old 28th June 2008, 07:08   #3 (permalink)
Shan2nu's Avatar
I don't think this is possible on indian cars.
1. F1 cars corner at 3-4Gs. Our cars can at the most manage around 1G on track and prob 0.3-0.5Gs when we drive normally.
2. F1 cars use a single central nut, where as our cars use 4-5 nuts.
As long as your wheel nuts are tightened properly, you shouldn't face any probs.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 28th June 2008, 08:02   #4 (permalink)
Shan2nu
My friend theMag can testify to this
__________________
I love the whoosh, but i miss the bellowing
Old 28th June 2008, 10:49   #5 (permalink)
iraghava's Avatar
And his friend McLaren too.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 29th June 2008, 01:39   #6 (permalink)
jalsa777's Avatar
Shan2nu
1G is achieved only by super-cars.
A normal road car will usually do only around a max. of 0.6Gs with high-performance tyres
__________________
Orion Racing India
jalsa777 is offline   Reply With Quote
Old 29th June 2008, 02:48   #7 (permalink)
Shan2nu's Avatar
Nope, when OD tested the Indian cars on track, the RS and Baleno were cornering at 1G. This was tested using Racelogic Vbox II.
Shan2nu
__________________
Old 29th June 2008, 05:46   #8 (permalink)
i have a feeling that mclaren are being looked at with a microscopic eye on whatever they do.
bharanidharang is offline   Reply With Quote
Old 30th June 2008, 01:38   #9 (permalink)
Rehaan's Avatar
Shan2nu
Well this really depends on whether you are talking about instantaneous (peak) lateral acceleration OR sustained lateral acceleration.
Shan2nu is talking about instantaneous - which means the cars did manage a lateral force equivalent to 1G, but momentarily, probably for a fraction of a second.
Jalsa is talking about sustained - (which is a more realistic test of handling, adhesion, suspension etc and would correspond to a skidpad / most other G stats) - basically it means the car has to continue to pull that amount of Gs for a specific amount of time (1second? 3 seconds? 1lap around a 200ft radius circular track? i dont know what the standard is...). The lowest lateral acceleration during that period is the sustained Gs that the car is capable of. There may even be a peak G rating in that sample timeperiod that is much higher.
cya
R
__________________
The memory of you will ride by our side forever.
Old 30th June 2008, 01:42   #10 (permalink)
theMAG's Avatar
I testify, I testify !
__________________
If you lose your temper, you’ve lost the argument
Old 30th June 2008, 02:28   #11 (permalink)
Shan2nu's Avatar
Ofcourse, i never said Indian cars can hold 1G of "Lat Acc" but they are definately capable of producing 1G, even if it lasts for a fraction of a sec.
Come to think of it, i doubt even an F1 car can pull 3-4Gs on a 200ft skidpad. It would never be able to reach the speeds required to produce enough downforce.
Shan2nu
__________________
Thread Tools
F1-2007 Barcelona Test-The King Returns merve_extreme Motor-Sports!! 42 18th November 2007 08:55
Mclaren vs 2 Ferraris!!! Shan2nu A Collection of the best threads 55 16th October 2007 13:55
Mclaren vs 2 Ferraris!!! Shan2nu A Collection of the best threads 29 7th December 2005 17:39
Radically different TF105 at Barcelona.. Hatari Motor-Sports!! 0 15th February 2005 11:36
Mclaren Drivers ? haryan Motor-Sports!! 17 2nd January 2005 14:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
