Old 2nd July 2008, 17:32   #1
Thanked: 16 Times
Default Maruti 800 5 speed aircon refrigerant
Hi all,
My AC mechanic found that the refrigerant level has reduced and inturn the AC effect has reduced too.
Now I need to refill the refrigerant, and I am not sure of the type R12/R134A used in the system.
The car is acutally a 2001/2002 800 MPFI 5 speed model.
As I lost the user manual, could anyone please enlighten me on the type of gas to be filled?
Filling R12 on a R134A system might not be an issue but viceversa, it will put too much load on the AC system and may cause AC failure.
Your inputs on this will be of great help to me.
Ram
ramkris is offline   Reply With Quote
Air-con Refrigerant: How much to fill? IndigoXLGrandDi Technical Stuff 24 21st April 2018 11:49
Car Aircon: Unicool Car Aircon, Ghatkopar (W) parsh Mumbai 26 18th August 2017 00:47
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Correct refrigerant level of a automobile air conditioner Sang Technical Stuff 6 15th May 2009 10:26
NHC - AC Regrigerant Gas and Refrigerant oil recharge anandpadhye Technical Stuff 12 27th June 2007 12:05
