Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 20th January 2009, 00:53   #16 (permalink)
akshay4587's Avatar
My car was dripping water last week,since winters here in north india,there is no question for AC.
on closer inspection i found out that water was leaking from the joint of windshield washer can where motor is attached.required 2-3 minutes to fix it.
__________________
1997 Gypsy MG410W(Sold)
2001 Bolero GLX
1983 Premier Padmini DX
1978 RE STD 350
1999 RE Machismo 350
2005 Zma 225
2006 Accent GLE
Old 2nd November 2009, 14:16   #17 (permalink)
Default Fiat Palio Stile 1.6 - Oil drip
Hi guys,
I must confess that I treated my car rather harshly on saturday by driving with full AC in the afternoon heat and going over a rather high road hump at a high speed. I came home and parked the car and the next morning found that there was some kinda oil drip that had happened. It wasn't much, pretty spreadout and also it had stopped.I immediately started the car again and checked to see if something was dripping but it wasn't so. I later stooped to see if there was any dripping and found that the area about a feet away from the right front wheel was mildly covered with oil. It seemed like a joint on the wheel and I have no idea what the part is. Also, there was no colour or odour to the oil. What could this be ? I plan to take it to concorde motors and what the are the things I need to check for this problem ? Any help would be most appreciated.
__________________
Citius,Fortius,Palios
rganeshiyer is offline   Reply With Quote
Old 2nd November 2009, 14:34   #18 (permalink)
JVH
JVH's Avatar
Oil filter could have cracked or broken. This would be the first area to be checked.
I'm not too sure about the wheel joint part though!
__________________
Jayant
JVH is online now   Reply With Quote
Old 2nd November 2009, 15:11   #19 (permalink)
Looks like you busted the driveshaft - the driveshaft boot contains a kind of grease (not oil).
Are you sure it was an oil leak and not grease. Stop driving the car and have it looked at. You might get away with just replacing the boot or you might have to replace the driveshaft completely.
__________________
The man who smiles when things go wrong has thought of someone to blame it on.
CrackedHead is offline   Reply With Quote
Old 2nd November 2009, 18:05   #20 (permalink)
Not sure if I have damaged it so badly. Can rough riding unsettle something near the engine / wheel shaft ? As I mentioned it seems to have stopped now completely. I am sure it has nothing to do with AC as the liquid did not evaporate and looks oily. However, it was colourless and odourless.
__________________
Old 3rd November 2009, 01:21   #21 (permalink)
johnda's Avatar
hope you've checked, power steering, brake & clutch fluid outlets??
Also the radiator leak possibilities.
__________________
you are where you are because you want to be there...
johnda is offline   Reply With Quote
Old 3rd November 2009, 01:34   #22 (permalink)
The "leak" wouldn't have stopped if it was oil that was leaking. The driveshaft boot contains a small amount of grease (which could be all gone by now).
Please have the driveshaft boot checked. Also read - http://www.team-bhp.com/forum/techni...ntainance.html (Driveshaft/Axle Maintainance)
__________________
Old 5th November 2009, 12:48   #23 (permalink)
Thanks mate ! I had a hard look this morning and found the culprit. It is something like a piston with a big clamp beside the engine on the right side of the bonnet. Not sure if it is the brake/clutch. The piston rod has fresh oil all over it and infact that had dripped on to the wheels and the ground beneath. I will call up fiat today and check for the issue.
__________________
Old 7th November 2009, 20:45   #24 (permalink)
Hmmn....i guess our observations get exaggerated without logic sometimes. I saw a small puddle of oily liquid and immediately linked it to my rash driving. The FIAT guy took exactly 30 secs to diagnose the problem and told me it's just the water from the AC drainage that had leaked. It was slightly slimy though but he laughed it off by saying it is quite normal and that I shouldn't be concerned if it happens again. So much for my hysteria !
__________________
Thread Tools
Enfield: Oil Leak! v12 Motorbikes 54 19th August 2009 10:23
Oil leak!!!! Manoj2268 Motorbikes 4 23rd September 2008 20:28
Leak in Exhaust pipe- Help leadf00t Technical Stuff 12 25th July 2008 12:31
Oil Leak on my bike abdriver2000 Motorbikes 9 7th December 2006 19:59
City Driving NHC/NHC-CVT or Vtec Rahulk76 Sedans 7 27th April 2006 17:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
