| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2008 Location: New Delhi
| Hello Everyone, I own a Honda city ZX Vtec. The car is not even 2 years old and is working fine. Recently when I parked my car in a multi level parking and I was walking off, I heard some dripping sound. I went close and bend down to see something dripping under the car. It was kinda located in the middle of the vehicle a bit closer to the hood but it didnt seem to be directly under the engine. Something was dripping and it was like transparent in colour. Thus it could have been water or fuel. Though I didnt smell fuel but my ability to smell isnt great becoz of cold at times. And it was little more than just a few drops. I was puzzled and thought I will come later and check it out. I came in an hour and the dripping had stopped. Though I didn't notice such an event again but I am wondering what could it be. It was a dry day and I was using the A/C. Was it water from AC or something related that was dripping or so. Has such a thing happened to anyone before. Would be glad if someone can tell me if i should do something or it was something else which is normal. Thanks, JG |
| | #3 (permalink) |
| Senior - BHPian | its mostly the water from AC! if you are really concerned then do a quick check of opening the hood and check for any visible leaks any where, and if not satisfied just do a casual visit to the service center and have a technician check the car, it does not seem very serious though! |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Apr 2007 Location: Delhi
| It has to be water. Since you were able to hear the drip, I assume that the leakage was big enough for it to be the AC only.
__________________ Car is no longer a luxury; parking space is. Swift VDI(ABS) Sep 07 - 53K Kms Ford Ikon Flair Sep 04 - 70K Kms |
| | #6 (permalink) |
| Senior - BHPian | My car creates a pool every time it is parked for more than 15 minutes. It is pretty humid here & water drips all the time. Nothing to worry about. Just make sure it is water, feel it & see.
__________________ Let us learn from the past to profit by the present, and from the present to live better in the future.- William Wordsworth |
| | #7 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Your AC is working as it is supposed to, look underneath and see if the water is originating from a small rubber tube handing near the fire wall and confirm.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #8 (permalink) |
| Thanks guys for assuring me that it is most likely to be A/C water. Though I didnt notice such a thing again off late but if I do then will surely check it out. Is such a water stored and then drops or it just falls. When I view a thread I see my original post at the bottom and most recent one at the top. Can I change this?? Didnt find anything in the options though. |
| | #9 (permalink) |
| BHPian | Guys, 2 days back after I finished a short drive I noticed a rather bigger patch of water drip. this is located right behind the front tire (right side) in line with the front door hinge. It dripped for a good 3 / 5 mins. but the interesting point is i used the A/c only for 10mins. It was also a hot afternoon. Is there something I should check? or is it normal?
__________________ you are where you are because you want to be there... |
| | #10 (permalink) |
| BHPian | johnda - Was the car washed before you started the short drive? Sometimes water collects in the door sills / other places (also possible with the way the car is parked). So after you stopped, the water could have come to the front and drained out.
__________________ • åĐïğŧėđ Tŏ Ÿoů... |
| | #12 (permalink) |
| BHPian | No washing, only a small 15 min drive and this drip happened after the drive. I checked again but no issues after that. I want to be sure that was the A/C drain, any ways to know that there is nothing else wrong?
| | #13 (permalink) | |
| BHPian Join Date: Nov 2008 Location: Lagos
| Quote:
If you have the slighest doubt if thats coolant, then please check the coolant levels. You would notice a green fluid stagnant and not just water. Highly unlikely though | |
| | #14 (permalink) |
| Newbie Join Date: Jul 2008 Location: rajkot
| for last few days i was having the smell of petrol in the passenger cabin. then suddenly yesterday the smell was horrible. i looked under the hood and found a rubber pipe leaking. the fuel tank was full at that time. i immediately took it to the service centre. its 3 kms from my place. by then half of the fuel had gone. when i reached there the service guy told me that it was the return pipe that was leaking. he immediately replaced it with a new one without any charge. but today morning the same thing happened. it was the new pipe which was leaking. i again took it back to the service station. the service guy told me that the original pipe has wire mesh in the wall and that is not in stock at the moment. and it would cost 2300rs. the rubber pipe he had put was just a temporary solution. he again put in a new rubber pipe till the original one arrives. but is it safe to drive with such a pipe? my car has cng kit installed. has it got anything to do with this problem?
__________________ Baleno Vxi Wagon R Vxi |
| | #15 (permalink) | |
| BHPian Join Date: Oct 2008 Location: Mumbai
| Its better dude you try to get the original pipe as fast as possible or goto a other service station. You must use proper products for your safety. Quote:
__________________ YoYo... Live n Let Live! :D | |
| Thread Tools | |
Similar Threads | ||||
| Enfield: Oil Leak! | v12 | Motorbikes | 54 | 19th August 2009 10:23 |
| Oil leak!!!! | Manoj2268 | Motorbikes | 4 | 23rd September 2008 20:28 |
| Leak in Exhaust pipe- Help | leadf00t | Technical Stuff | 12 | 25th July 2008 12:31 |
| Oil Leak on my bike | abdriver2000 | Motorbikes | 9 | 7th December 2006 19:59 |
| City Driving NHC/NHC-CVT or Vtec | Rahulk76 | Sedans | 7 | 27th April 2006 17:51 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
