Old 11th March 2006, 15:10   #31
highwayblaze's Avatar
Originally Posted by Harrie
Two stage turbos are usually twin turbo systems where two turbochargers are used
So does it have two wastegates/blowoff valves or just one. Two phuuushhh sounds ???
Two stage same as stage II??? In that case what are Stage - I or Stage-II ECU's?
highwayblaze is offline   Reply With Quote
Old 12th March 2006, 02:28   #32
Turbos are generally classified as
1.) Free Floating(No WG or boost control mechanism)
2.) WG turbos, with the wastegate, whose function has been explained in great detail.
3.) variable geometry turbos, mostly available in diesels, but now porsche's put two in the new 911 turbo.
So, if a WG turbo is being used, then irrespective of the no. used, it will have a waste gate.
mostly, two turbos will have two blow off valves too.
two stage turbocharging is currently used only on heavy diesels, which involves two turbos one after the other, used to produce very high pressure ratios(upto 4:1).
sequential turbocharging involves two turbos side-by-side, in which there is a small turbo which operates at low engine RPM and a larger turbo which takes over as the air flow through the engine increases(which may cause the smalller turbo to choke). this system is complicated to implement and control, but gives the best driveability of all and is the only turbo charging system which can boast of having negligible lag.
porsche_fan is offline   Reply With Quote
Old 12th March 2006, 17:14   #33
black12rr's Avatar
Thanked: 274 Times
Now.. who all supply them in india ? how much ? how easy to fit ? ..just curious ..
black12rr is offline   Reply With Quote
Old 12th March 2006, 21:09   #34
Could you please throw some light on Tata Indica Turbo?
murlidar is offline   Reply With Quote
Old 12th August 2007, 00:32   #35
ST7677's Avatar
Thanked: 45 Times
Bump...
Was also curious what boost do people usually run on stock internals and is reliability compromised?
ST7677 is offline   Reply With Quote
Old 12th August 2007, 01:13   #36
binz's Avatar
Thanked: 412 Times
Got this when i was doin a bit of light reading on the subject,
Very nice topic btw!
Old 12th August 2007, 09:46   #37
Rehaan's Avatar
Thanked: 25,038 Times
Check this thread out - How Much Boost in India (Turbo Facts - How Much Boost In India?)
cya
R
Old 13th August 2007, 12:07   #38
ST7677's Avatar
Thanked: 45 Times
Thanks Rehaan, I have been through that thread, but it looks more of bragging rights / extreme boosts.
I wanted to know how much boost is advisable for a daily driving petrol car in India with no (minimum) compromise to reliability.
It will be great if a Polling thread can be started to see how many T-Bhpians are running a turbo, at what boost, What kits on what cars and if they have faced any issues?
Old 16th August 2007, 15:15   #39
ST7677's Avatar
Thanked: 45 Times
In custom turbo setup, how is exhaust manifold created and how is Engine management done?
Old 16th August 2007, 15:17   #40
Vid6639's Avatar
Thanked: 21,042 Times
Have you gone through this thread?
http://www.team-bhp.com/forum/modify...-your-car.html (ARTICLE: Points to consider before TURBO-Charging your car)
Old 20th August 2007, 13:27   #41
ST7677's Avatar
Thanked: 45 Times
Have been thru all turbo threads in details but didn't get answer to these questions...
I ask this because, exhaust manifold connects engine to the turbo and it doesn't seem like a simple thing to fabricate. There may not be ready made ones available for all engines, specially the new engines or not so popular ones.
Secondly ECU remapping/flashing to control the engine operations is again something that does not come ready made for a custom turbo charged engine. Having the right map is a crucial aspect in getting the tuning correct to run the engine optimally. How is this done?
Old 1st June 2012, 19:14   #42
Carrera555's Avatar
Default Re: Turbocharge your knowledge (Learn how Turbochargers work)
Hey Guys,
Just gone through the whole thred & was immensly informative.
I have a query here, whats the exact diffrence betweed FGT (Fixed Geometry Turbo) & VGT (Variable Geometry Turbo)?
AFAIK, VGT has 2 or 3 stages of turbines, size wise into the same turbo charger, so that it can give the boost from 1800 RPM till almost the red line. Is that correct?
Cheers,
Carrera555 is offline   Reply With Quote
Old 2nd June 2012, 06:04   #43
1self's Avatar
Thanked: 270 Times
Carrera555, VGT has a set of moveable vanes at the turbine which control the rate of exhaust gas flow to the turbine blades. No wastegate is needed. It is generally used in premium & sporty diesel cars & very high end petrol sports cars (Porche turbo).
The effectiveness of the turbo at all rpm ranges is vastly increased with this system. It is also a LOT more complex, more expensive than fixed geomerty turbo.
FGT does not have this vane system. Such turboes need to be carefully chosen with engine compatibility & power goals in mind.
The pic is one example of VGT turbo working mechanism.
1self is offline   (2) Thanks Reply With Quote
Old 3rd June 2012, 17:00   #44
Carrera555's Avatar
1self, thanks for the explaination. But I am still not clear with the concept.
How do the vanes work? From the picture it looks as if the vanes act as an obstruction for the exhaust gas to reach the turbine. Does these vane's flip due to the pressure of the exhaust gas?
Old 5th June 2012, 06:11   #45
1self's Avatar
Thanked: 270 Times
This is one more pic to show you how the system works. The vanes are rigidly connected by metal links to the controller.
1self is offline   (1) Thanks Reply With Quote
Remote Mounted Turbochargers nikhilv12 Technical Stuff 12 23rd July 2008 23:22
Turbocharge It !!! ranjan united The Indian Car Scene 22 29th June 2006 00:13
Team-bhp-the ultimate motoring knowledge centre purnendubagchi Introduce yourself 3 2nd January 2006 11:26
want to turbocharge theguy Modifications & Accessories 0 25th March 2005 22:10
