| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hi All, I have just made a purchase of a Palio 1.6 GTX. Link to the photos is 41786-bought-2002-palio-1-6-gtx-premium-2.html#post894012 . 1 problem i discovered was that once 120 is crossed, the gear slips from 5th to nuetral. This happened a couple of times. This could be because the 5th gear haven't been used much, since the car was mainly driven in Mumbai. But it can also be an issue with the Gear Box. Will get this checked on weekend. I could have never tested this while taking test drive since engaging the fifth gear in Mumbai is itself a rare possibility, forget going beyond 120. Had called up the owner to ask whether he faced similar problems but he said the same thing that engaging 5th was not possible in Mumbai and he used it only while on his way to Lonavala. He dint face such problems. I will further test the gear. Today while coming to office, I engaged to 5th and it did so smoothly and did not slip thereon. Now will have to test it further on Highways beyond 120kmh after a week or so to see if problem persists. The reason being If the 5th gear smoothens with use, need to check if the slip continues after the gear gets smooth. Has any fellow Palio User encountered such an issue? What coulds be the possible reason? If it is a Gear Box issue which needs to be replaced, it means it is a costly affair. An insight on what amount of expenses would this need? Advice needed.
__________________ Red Santro 1999| Palio 1.6 GTX | Bajaj Scooter 150cc 1999 | |
| | #2 (permalink) |
| BHPian | i havent faced this issue - i guess you need to get used to engaging the 5th gear properly - hope you are getting me - i havent hit 120 in 5th...ever but i have hit 120 in 3rd and boy it was fun ![]() well i am facing this issue which is kind of irritating http://www.team-bhp.com/forum/893655-post33.html (RPM shoots up when clutch depressed) Last edited by planet_rocker : 7th July 2008 at 18:55. |
| | #3 (permalink) | |
| BHPian | Quote:
My brother said that if it is,then be prepared for atleast 30-35K on getting it rectified. Can there be a chance of fautly gearbox when there is a slip, in 5th gear only and only at speeds higher than 110-120? Does this make sense or could there be a chance where the gear was not engaged properly? I remember I engaged it properly the second time, still it slipped.
__________________ Red Santro 1999| Palio 1.6 GTX | Bajaj Scooter 150cc 1999 | | |
| | #5 (permalink) | |
| BHPian | Quote:
Two confusing points here 1. Why is there a slip only in 5th gear and not any other if gear box is at fault. 2. Why is the slip only at high speeds and not at speeds below 100?
| | #6 (permalink) | |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Quote:
And If by any chance the car is under warranty its makea lot of differnec of you take the car to the A.S.S ASAP | |
| | #7 (permalink) |
| BHPian Join Date: Apr 2008 Location: San Francisco, Delhi
| This type of slipping should not happen with a low mileage car. It can be indicative of larger problems with the gearbox. Is the transmission otherwise smooth and noise free? A gear whine means you have a problem. Have you checked the gearbox fluid level? If there is any chance that this vehicle was subject to flooding, drain the gearbox and refill with fresh gear oil. (I would do this anyway even with no flood issues). Slipping out of a gear probably means insufficient gear teeth engagement, and could be a simple adjustment of the linkage. Get the linkage greased and checked out. Good luck, Gaurav |
| | #8 (permalink) | |
| BHPian | Quote:
Yes, the car was once in water till tyre level 3 years back. Do you think this indicates a Gear Box replacement?
| | #9 (permalink) |
| No, gearbox replacement is not required. Like I said, drain and fill with fresh gear oil. Just cost Rs. 200 for the oil, so give that a try first. If you still have the problem, then the first thing to check is the linkage. It may just require a little adjustment to fully engage 5th gear. I would disconnect the gear linkage cable, and spray some lube like WD40 and make sure that it is free and not binding. If that does not work, have a good Fiat service center take a look at the linkage and make any adjustments to make sure that is not the problem. Then you look inside the gearbox. But this must be done by an expert, and again it might be something relatively simple. Don't let someone sell you a complete gearbox. At least not at this stage. If that is the advice you get from where you take the car for repairs, chances are they are trying to rip you off, and it is time to find a new service provider. |
| | #10 (permalink) | |
| BHPian | Quote:
I will not be taking the car to any place other than the Tata-Fiat A.S.S. Never. I will note down the things mentioned by you and take the car to the A.S.S. this weekend and get the things checked. But I have heared that touching the gearbox in Fiat is in itself a costly affair, labour charges coming to 5k. Did you do anything about the Linkage in your car?
__________________ Red Santro 1999| Palio 1.6 GTX | Bajaj Scooter 150cc 1999 | Last edited by vinit.merchant : 7th July 2008 at 20:31. | |
| | #11 (permalink) | |
| BANNED Join Date: Nov 2005 Location: ??
| Quote:
1. Did you slot into 5th fully? Sometimes you may fail to do that and the gear will slip. 2. As per your post the problem only occurred at speeds beyond 120 kmph. Were the roads a bit rough/bumpy and did you feel a lot of vibrations in your car? If you had seen the gear lever, it might have been vibrating hard. Under those conditions, the gear can sometimes slip. It has happened to my Santro a couple of times, sometimes from 5th to neurtral, someitmes from 3rd to neutral. Also check that gearbox is mounted securely. 3. If there are vibrations in your car at high speeds despite the road being smooth, you may have to analyze the reasons for that and find a solution. Then your gear slippage problem may also go away. Tyres/wheels are the first suspects here, but there could be other reasons as well. | |
| | #12 (permalink) |
| No I never had any problems with gear slipping with my GTX gearbox. No linkage adjustments were necessary either. But I did do a gearbox oil change as a preventive measure. I actually changed the gear oil, ran the vehicle for 500 km, and then did another gearbox oil change with full synthetic Mobil 1 gear oil. Just one other comment that may seem a bit silly, but might be worth a look. Are you sure that you are fully engaging 5th gear? Do you push the gear lever all the way up into 5th gear? Try this: sit in your car with the engine off, and cycle back an forth from 4th to 5th gear, pushing firmly up to fully engage 5th gear. Do this 50 times or so. It might free up a sticky or rusty gear cable. ![]() |
| | #13 (permalink) | |
| BHPian | Quote:
.@rks, Yes, I shall now check very closely whether the 5th gear is engaged properly or no. No, the roads were not bumpy at all, was on Expressway, from Mumbai to Pune. There is no slip for any other gear except for the 5th.
| | #15 (permalink) | |
| Quote:
One bad habit that can cause damage to the gear selector mechanism (as per my Santro manual) is that of resting your left hand on the gear lever while steering with the right. I have seen many people do this, especially cabbies. I wonder if the previous ower of your car had this habit. | |
« Loose Caliper problem in Hyundai i10
Matiz Engine Over Heating Problem After A/C is on for some time. »
| Thread Tools | |
Similar Threads | ||||
| The Speed at which you downshift from 5th gear | mithun | Technical Stuff | 31 | 19th July 2007 19:24 |
| PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) | karizma_devil | Hatchbacks | 16 | 8th March 2007 12:02 |
| Car Knocking at higher speeds please help | pramodkumar | Technical Stuff | 39 | 19th May 2006 22:58 |
| 5th-gear noise?! | ghostrider4385 | Technical Stuff | 25 | 6th February 2006 23:07 |
| 5th gear presenters!!! | Shan2nu | Shifting gears | 7 | 12th February 2005 17:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
