Old 13th July 2008, 16:08   #16
mnhegde's Avatar
@ anil : Anil bhai, I got curious to know which other vehicles has fuel (remaining) display. I thought may be some gurus will shed light on this topic. simple.
mnhegde is offline   Reply With Quote
Old 13th July 2008, 16:25   #17
anilkalvani's Avatar
Thanked: 79 Times
sir i am attaching an old picture of the instrument panel. if you see clearly the LED display shows clock, fuel & temperature and above its hows mileage & other displays, i will post a picture in a couple of days which shows the fuel remaining in litres for your viewing.
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00667.jpg
anilkalvani is offline   Reply With Quote
Old 14th July 2008, 08:59   #18
Thanked: 79 Times
For that follow these instructions:
1. Keep Engine Off.
2. Press the Trip Button (there's only one there)
3. Keeping the button pressed, turn the ignition key to turn on the Panel (dont start the car though) PIC 1
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00713.jpg
4. Keep the button pressed until you enter "Diagnostic Mode" where you will the see the Tachometer & Speedometer move wierdly in steps (may freak you out) PIC2
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00714.jpg
5. Press the Trip button again, you will see all the LCD segments displayed PIC3
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00715.jpg
6. The next click there is a number with a small 'L' at the bottom of it. Thats the fuel remaining in the tank! PIC4
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00716.jpg
Old 14th July 2008, 10:56   #19
hellstar's Avatar
Thanked: 17 Times
now thats one trick i will definitely try out on my verna and will report back .... pretty handy trick it sure is !
hellstar is offline   Reply With Quote
Old 14th July 2008, 11:05   #20
esteem_lover's Avatar
Thanked: 451 Times
I am sure it works only in the Logan
Nice find
Old 14th July 2008, 12:26   #21
yogi1771's Avatar
Well tried it on my Fiesta and the same things happen with the odometer but couldn't find the litre thing,will check again was in a hurry while trying it
yogi1771 is offline   Reply With Quote
Old 14th July 2008, 12:35   #22
snaronikar's Avatar
Thanked: 23 Times
Woah!! This is very good trick....Guys, try in your respective cars. Hope this works.
@ anil: Are you sure that the "L" and 13 is that of remaining fule left in tank? Did you open your tank and check or you tested this with the mileage? I'am just curious....
snaronikar is offline   Reply With Quote
Old 14th July 2008, 12:38   #23
Thanked: 245 Times
Safari doesnt have the digital display for Fuel/ Temp, but still I tried and did not work.
Old 14th July 2008, 13:18   #24
Thanked: 79 Times
my friend who tried it had reading displayed as 20L & when he went to the petrol pump & topped-up his car with 29L going in. So it is pretty accurate.
Old 17th July 2008, 08:27   #25
Thanked: 79 Times
Just topped up my car yesterday. the reading is pretty accurate i may say
the image shows the reading before filling fuel 10L, note the time 10.56
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00762.jpg
after filling the image shows 50L, the time is 11.01
Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants-dsc00763.jpg
Invoice attached (40.32L, so i feel its pretty accurate)
Old 17th July 2008, 09:54   #26
Hemanth's Avatar
But why is the RPM and KM readings on the move?
Hemanth is offline   Reply With Quote
Old 17th July 2008, 10:09   #27
Akshay1234's Avatar
Thanked: 7,242 Times
thats the first logan to reach 7k rpm. watch out vtecs.
Old 17th July 2008, 10:23   #28
Thanked: 79 Times
well as i said earlier, i found this freaky too... have no answer to it.
yeah 7k rpm is the way to go...
Old 17th July 2008, 14:35   #29
manikjeet's Avatar
Thanked: 110 Times
tried it on my NHC both zx and non zx innova and alto
doesn't work on any of the above mention cars
will this work on a 1.5 dls version of the logan
manikjeet is offline   Reply With Quote
Old 17th July 2008, 15:42   #30
Thanked: 79 Times
As i said it worked on the Logan & i dont think any of the cars you mentioned have a LCD display similar to the Logan's. Talking about the DLS version, it does'nt require this trick, it shows the reading by simply pressing the trip button!
Odometer suddenly started showing a lower reading! kippu Technical Stuff 7 28th July 2017 10:14
Safety features in lower variants of B2, C1 & C2 segment cars zenren Road Safety 36 12th November 2014 02:59
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
Logan Odometer reading correctness Sush Technical Stuff 13 24th May 2009 08:15
Mahindra launches two new variants of Logan rahul_intlad The Indian Car Scene 11 28th June 2007 11:02
