Old 12th July 2008, 09:58   #1
anilkalvani's Avatar
Thanked: 77 Times
Default Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants
guys a friend of mine showed me something really awesome for people who dont have the top of the line DLS / GLS Variants. We can actually get a numeric reading of the litres of fuel remaining in the fuel tank.
For that follow these instructions:
1. Keep Engine Off.
2. Press the Trip Button (there's only one there)
3. Keeping the button pressed, turn the ignition key to turn on the Panel (dont start the car though)
4. Keep the button pressed until you enter "Diagnostic Mode" where you will the see the Tachometer & Speedometer move wierdly in steps (may freak you out )
5. Press the Trip button again, you will see all the LCD segments displayed
6. The next click there is a number with a small 'L' at the bottom of it. Thats the fuel remaining in the tank!
Will try to post a couple of pics later... Try it out & lemme know if it worked!
Adios,
Anil
anilkalvani is offline   Reply With Quote
Old 12th July 2008, 10:14   #2
Thanked: 91,472 Times
Sweet trick! I'd love to know how accurate this is.
Old 12th July 2008, 10:24   #3
Thanked: 77 Times
well even if its + or - 1 litre i still feel its pretty useful. See there are 9 lines on the display, yesterday when i checked this out, the fuel indicator was showing 4 lines & tried this 'trick' where it showed i had 23L remaining(btw The fuel tank capacity is 50L)
Old 12th July 2008, 10:57   #4
Thanked: 245 Times
Good you posted it, I had read about this trick, but never knew if it worked in Indian cars and was too lethargic to check it out. Anil, it would be good to post some pictures of the same as you tested.
Old 12th July 2008, 11:00   #5
mnhegde's Avatar
@ Anil : good find man. how about some accuracy update??
@ Dadu : Is it the same in all indian cars??
mnhegde is offline   Reply With Quote
Old 12th July 2008, 11:11   #6
Thanked: 77 Times
See the accuracy is not in decimals, i'm still getting to know about it so i will be able to tell you when i try it more often.
I don't know if you can do it in all indian cars, coz the Logan has a computer display which is deactivated/not installed for Lower & Mid Variants. I just don't understand what difference it will make to them if it is present across all variants. Cost cutting i guess
Old 12th July 2008, 11:16   #7
mnhegde's Avatar
@ Anil : ok Sir. Hope you find good results.
Old 12th July 2008, 11:24   #8
Thanked: 245 Times
I wont be surprised if it did.
Well let the ppl here check and post, if it did or not for their variants.
Old 12th July 2008, 17:28   #9
abhinav.gupta88's Avatar
Thanked: 309 Times
To check if its correct
Top up your car and then check it.
Wish something like this was in honda and others!
Old 12th July 2008, 17:35   #10
snaronikar's Avatar
Thanked: 23 Times
Guys, is this workable in other cars which has digital meters? I can't try mine as it is analogue ;-(
snaronikar is offline   Reply With Quote
Old 12th July 2008, 19:45   #11
mnhegde's Avatar
I dont think its possible in wagon r. What say guys????
Old 12th July 2008, 19:51   #12
Thanked: 7 Times
The thread starter said Logan. How did Wagon R come into picture?
diabloo is offline   Reply With Quote
Old 12th July 2008, 20:08   #13
mnhegde's Avatar
@ diabloo: brother. (snaronikar's post: is this workable in other cars which has digital meters? I can't try mine as it is analogue). i meant there is no such thing in the car (wagon r atleast ). got my point friend?? cleared that fuel indicators are provided only in mid sized vehicles (starting). this thread started with logan , may be later some guys find such things in different vehicles, Do you mean to start a different thread for that?
Old 12th July 2008, 20:55   #14
wischvuanaudh's Avatar
@ diablo: Everyone be curious too see if such a trick works in their car.Thats it bro. chill.
By the way,doing it often means no harm to the car or its electricals ir that digi-meter's accuracy right? (sorry for my ignorance)
wischvuanaudh is offline   Reply With Quote
Old 13th July 2008, 13:56   #15
Thanked: 77 Times
as i said, i tried it on my Mahindra Renault Logan 1.5dCi DLX variant so i can't comment on other cars & yup it cannot harm the electricals dude, i dunno where all guys came up with it?
Odometer suddenly started showing a lower reading! kippu Technical Stuff 7 28th July 2017 10:14
Safety features in lower variants of B2, C1 & C2 segment cars zenren The Indian Car Scene 36 12th November 2014 02:59
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
Logan Odometer reading correctness Sush Technical Stuff 13 24th May 2009 08:15
Mahindra launches two new variants of Logan rahul_intlad The Indian Car Scene 11 28th June 2007 11:02
