Old 19th July 2008, 01:52   #1
Thanked: 9 Times
Default Sudden FE problem in Santro
i have a 2004 Santro that has been running on CNG for the last 2 years. it has done over 51000 kms till date.
suddenly since last week the car started giving almost half the average it used to give before. nothing has been changed or any service done. i have tried changing the air filter and checking tire pressure etc but still no change in the fuel efficiency of the car.
help needed guys.....
coolmob is offline   Reply With Quote
Old 19th July 2008, 15:57   #2
ASHISHPALLOD's Avatar
Thanked: 286 Times
Go to service station. possible causes-
1] spark plug problem causing misfire
2] engine tuning to be set
3] petrol pump delivered incorrect amount of fuel
i had same problem with my alto last month. servicing solved the problem.
ASHISHPALLOD is offline   Reply With Quote
Old 19th July 2008, 18:56   #3
rider60's Avatar
Thanked: 47 Times
and another possible reason could be the carbon formation and the grime that would have settled in the engine, just check for this too, you might need injectors cleaning etc.
a good service and check up all these and the above mentioned things should solve the problem.
rider60 is offline   Reply With Quote
Old 19th July 2008, 19:20   #4
Thanked: 18 Times
I agree with rider60 here and assuming you might have already done the injector cleaning once before around 30K Kms, might be the reason as well resulting in drop in FE @ the new odo reading.
VJ_MAVRICK is offline   Reply With Quote
Old 20th July 2008, 00:48   #5
Thanked: 660 Times
Check the following,
1. air filter
2. plugs (does it misfires)
3. injectors
4. tuning & timing check
Sudden Drop in Fuel Efficiency. What could be the cause? ashwin390 Technical Stuff 2 15th June 2011 21:49
Sudden fall of RPM in my Indigo marina..help.. boombox Technical Stuff 11 13th August 2009 14:12
Sudden Cedia Surge?? pooshnark The Indian Car Scene 56 24th July 2008 19:27
Bangalore traffic cops: Whats with the sudden change? kvish Street Experiences 36 30th April 2008 11:10
Speedo and Odo stopped all of a sudden kamat2004 Technical Stuff 5 4th June 2007 16:53
