Old 29th July 2008, 17:32   #31
KSM-Vtec's Avatar
Thanked: 437 Times
@ Kuttapan that was not only for you, in general.
All i am trying to say is why would one like to do something like that?? When there is some provision made why not use it? besided for sure something or the other is getting scraped there when that sound comes.
Originally Posted by kuttapan View Post
If you directed this question to me, I very well do mean what I typed.
HowStuffWorks "Shifting Gears"
Quote -
"When you make a mistake while shifting and hear a horrible grinding sound, you are not hearing the sound of gear teeth mis-meshing. As you can see in these diagrams, all gear teeth are all fully meshed at all times. The grinding is the sound of the dog teeth trying unsuccessfully to engage the holes in the side of a blue gear."
KSM-Vtec is offline   Reply With Quote
Old 29th July 2008, 20:50   #32
kuttapan's Avatar
Thanked: 12 Times
Oh ! You were talking about using the clutch. I took your question to be about the meshing of gears.
Anyway, I am also of the opinion that clutch should be used when shifting gears. Unless you are racing cars and there is significant time to be gained by not using the clutch and rebuilding is one of your favorite pasttimes.
kuttapan is offline   Reply With Quote
Old 30th July 2008, 12:19   #33
KSM-Vtec's Avatar
Thanked: 437 Times
Ya now i guess we are on the same page of the book.
RPM shoots up when changing gears lambdaplus Technical Stuff 110 3rd February 2013 03:23
Changing gears on bullet 500 Cast iron deepikins Motorbikes 6 1st February 2010 11:02
Esteem 2002 - RPM Fluctuation (Blip) After Changing Gears genesis Technical Stuff 7 28th July 2009 10:25
Not changing gears !!! shirishindurkar Technical Stuff 27 14th September 2007 18:29
