Thread Tools
Old 24th July 2008, 10:27   #1 (permalink)
Default Changing gears without using the clutch
Hey guys,
Yesterday, was reading one of the supplements with the Hindustan Times, and saw this article on how to prolong your clutch life. The article said that you could change gears without using the clutch in order to prolong clutch life. Caveat was that you should know how to do so, but there were no instructions on how to do so.
I used to think that pressing the clutch was essential to be able to change gears, since that was the only way of disengaging the engine from the driveshaft, and then you could change the gear. I guess I was wrong.
Anyways, am curious to know how does one change gears without using the clutch? How does it work and are there any issues that might arise as a result of this?
Thanks!
Lalvaz is offline   Reply With Quote
Old 24th July 2008, 10:36   #2 (permalink)
Don't believe in non-usage of clutch while changing gears to prolong clutch life, but I could be wrong.
Not sure about technicalities involved in this, but this is similar to the saying 'Most secure computer/system is the one which is not connected to any other computer/Internet'.
sukiwa is offline   Reply With Quote
Old 24th July 2008, 10:39   #3 (permalink)
You can , ppl used to before the syncromesh was invented. I dont know exactly how its done but I guess you will have to listen to the engine and match the speed with the vehicle before changing.
Its probably an art to listen and then change the gears without the clutch but can do a lot of damage in todays setup, if not done properly.
__________________
Remember, its a machine
dadu is online now   Reply With Quote
Old 24th July 2008, 10:52   #4 (permalink)
We have talked about this one before.
Suggesting it to prolong clutch life is utter nonsense. There are many drivers who have never had to replace a clutch; it depends on good usage.
It is not changing gear that wears your clutch out: it is slipping the clutch, holding the car on the clutch on an incline --- stuff where friction is happening between the clutch plates for more than a few moments. Even resting the foot on the pedal.
The combination of syncro-mesh and clutch means we don't have to be too fussy about engine speed when changing gear, although, of course major mistakes lead to uncomfortable jerks and stress on the poor car. Equalise the speed of the two gear cogs that are coming together by getting the engine speed right and --- no clutch needed!
Certainly it can be done. I don't claim to be able to, but I have seen it.
Engine speed is what it is all about. This was a Thad's-Dad trick; driving, even on hilly, winding roads, without using the clutch --- but he only did it as an occasional show-off trick. I'm sure that if it had any financial benefit, he would have done it more often!
Probably many of actually come close much of the time. Consider that the text-book method is to fully disengage the clutch, pressing the pedal to the floor, while changing gear. The realise that what we actually do, many times, is just a quick dab on the pedal as we change.
In my opinion, the guy who wrote this has shares in a gearbox company. If people take it as serious day-to-day advise, many cogs are going to be damaged as people try it. I guess most people, after the initial graunching noise just won't ever try again, and will spend the rest of their lives stating that it is impossible.
As general advice, it is stupid and irresponsible. Gear boxes are a lot more expensive than clutch plates!
<cross-posted> Dadu, yes you are partly right. The clutch was used in the days before syncromesh. When changing down it was necessary to "double de-clutch". This involves de-clutching, changing to neutral, taking foot off clutch, reving engine to speed up the cogs on the engine side of the box, pressing the clutch again and engaging the lower gear. Have to say that I tried this only once, and it is harder than it sounds! But only a real non-syncro gearbox would test you out: a syncromesh gearbox would absorb the mistakes.
I suspect there may be stuff llike old trucks on our roads that still don't have syncromesh?
Last edited by Thad E Ginathom : 24th July 2008 at 10:59. Reason: added comment to Dadu
Old 24th July 2008, 11:06   #5 (permalink)
androdev's Avatar
it is like catching a fast cricket ball with your teeth. one can do this in theory, by making the relative speed = 0, and then decelerating to rest slowly. any small mistake can hurt real bad.
btw, it is safe to get the car out of gear to neutral without using the clutch but engaging into gear is risky. just apply gentle pressure on the gear knob to slot into neutral (but not enough to actually slot into neutral) and hold it under this pressure and let go off the accelerator. as the car begins to slow down, at some point the RPM match happens and the stress on the tranny will be zero, then it will slot into neutral without clutch.
androdev is offline   Reply With Quote
Old 24th July 2008, 11:16   #6 (permalink)
ashthedivx's Avatar
Oh god... I have been holding clutch on inclines and straight lines to get better fuel economy, so as i'll not need to revv my engine and car flows in usual speed and once pickup is required i can release clutch and come back to previous gear easily. Didn't knew that it will wear clutch faster then normal circumstances.
But, I am still confused how come clutch will wear fastly when practically we ain't using the clutch. Can you clarify the doubt ???
ashthedivx is online now   Reply With Quote
Old 24th July 2008, 11:21   #7 (permalink)
diabloo's Avatar
Is this same as Heel n Toe, which is discussed to death here?
__________________
NHC - City of Life !! - Symbol of Luxury
________________
diabloo is offline   Reply With Quote
Old 24th July 2008, 11:24   #8 (permalink)
watashi75's Avatar
This technique is called speed shifting and is sometimes used in car racing to shift without using the clutch. There is some information here on this and other such advanced techniques -
http://www.team-bhp.com/forum/collec...e-driving.html (The Manual On Extreme Driving!)
However contrary to popular belief there is no significant gain in time and there is a greater risk of damaging your gears.
I am not sure if this technique can be used for both downshifting as well as upshifting. Can somebody calrify?
watashi75 is offline   Reply With Quote
Old 24th July 2008, 11:26   #9 (permalink)
Mr.Bangalore's Avatar
well i have tried changing the gears without clutch in my bike, but never tried it on Car. One financial benefit is that FE increases defently if you dont use clutch and dont know about the clutch life though.
__________________
"To the question of your life, you are the only Answer.
To the problems of your life, you are the only Solution"
Mr.Bangalore is offline   Reply With Quote
Old 24th July 2008, 11:27   #10 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
Not tried it with cars (and don't really plan to), but many a time with my bike and yes possible to do it by listening to the engine. This was not to prolong clutch life or anything, but just for the heck of it. Curiousity factor being the introduction of the geared, clutchless bike Street by HeroHonda many years ago.
__________________
One half of what we eat enables us to live; the other half enables the doctor to live. :-)
- Anonymous
Old 24th July 2008, 11:55   #11 (permalink)
Yes, it can. You have to increase engine speed to match geerbox.
Any situation in which the clutch is neither fully engaged nor fully disengaged will lead to wear, as there is friction between the plates if they are not totally locked together and thus rotating at the same speed.
On an incline the car should be held on the brake until ready to move.
In real life, I find city driving impossible without some clutch slipping in traffic queues (just releasing the clutch a little to edge the car forward when it would be travelling too fast in 1st with the clutch engaged) and for brief stops on inclines, like at a junction. I don't, however, drive with my foot resting on the clutch, ever --- so not all bad!
Old 24th July 2008, 12:11   #12 (permalink)
sudev's Avatar
Done that and can be done shifting up or down. But not with purpose of saving clutch. Come on cost of clutch is much less than a "kaput" gaer box at worst or even " worn out synchro-gear rings.
In theory the two gears inside your gear box have to be at same revs to slot in (further helped by synchro rings) The driving gear is rotating as per engine rpm's and the driven gear (while not slotted) is rotating with wheel rpm's. If you can get both at same rpm's you can slot in the gears to lock with each other. When you press the clutch this is what is happening. The engine side gear is free wheeling because of clutch and can easily slot with driven gear.
First to do a change to neutral you need to practice slight easing off accelerator and pushing the gear to neutral. This is easy part.
Second do get in to the next gear (say second to third) just wait a second in neutral and then push the lever towards third - all the while keeping off accelerator. As soon as gear revs match the gear will slot in to place.
Problem is doing in other direction (third to second) where you need to pump accelerator to rev up the engine and then let it slow down enough so that again revs on both side match up and gear slots in.
Have driven in emergencies on plains and even in hill but it is something to be done with extreme caution and only if you have practise.
BUT again this is no way to save the clutch and if that is the intention then you may save the clutch only to land up with much bigger bill of gear box.
sudev is offline   Reply With Quote
Old 24th July 2008, 12:31   #13 (permalink)
I used to do that on my bike whenever the clutch wire broke.
But would not advise anyone doing it - of course if you wanna screw your gear cogs - then proceed by all means.
Old 24th July 2008, 12:35   #14 (permalink)
Rehaan's Avatar
...by making the relative speed = 0 ....
Exactly!
Oh god... I have been holding clutch on inclines and straight lines to get better fuel economy, so as i'll not need to revv my engine and car flows in usual speed and once pickup is required i can release clutch and come back to previous gear easily....
Bad for many reasons.
See this post, you will find your answers :http://www.team-bhp.com/forum/techni...tml#post226145 (Shifting to Neutral or Pressing the Clutch when Braking - Is this right?)
Originally Posted by supremeBaleno View Post
...Curiousity factor being the introduction of the geared, clutchless bike Street by HeroHonda many years ago.
...though that really doesnt work in the same way. However, some new electronic-manual transmissions found in sports cars do, if i am not mistaken.
Lalvaz,
Please search next time before creating a thread. This has been brought up many times before :
http://www.team-bhp.com/forum/techni...ut-clutch.html (shifting without clutch)
http://www.team-bhp.com/forum/techni...ut-clutch.html (Shift without clutch ??)
And redirected to other similar threads where the topic was touched upon :
http://www.team-bhp.com/forum/shifti...le-breaks.html (wat do you do if the clutch cable breaks)
http://www.team-bhp.com/forum/techni...nge-gears.html (How to change gears)
http://www.team-bhp.com/forum/collec...son-2-use.html (Whats double clutching & whats the reason 2 use it)
cya
R
__________________
The memory of you will ride by our side forever.
Old 24th July 2008, 12:36   #15 (permalink)
Alfa_Kilo's Avatar
I have done it a few time with my 540 when the clutch actuator failed. One has to match the engine speed with the vehicle speed and then gently shift into gear from neutral. It does not take long to get the hang of it. The problem is in moving from a standstill, which requires slotting the vehicle in 1st and cranking the engine, quite a pain in start stop city traffic.
Alfa_Kilo is online now   Reply With Quote
Thread Tools
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Not changing gears !!! shirishindurkar Technical Stuff 27 14th September 2007 18:29
How to change gears speedsatya Technical Stuff 114 7th July 2007 11:33
Problem with Siena gears & clutch satish_appasani Technical Stuff 11 10th June 2006 20:51
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
