Old 27th July 2008, 13:25   #1
Default Skoda Engine Problem
I have a 2003 Skoda Octy Petrol; recently service and changed all the filters including air-filter. The problem started after that. There is an irritating engine noise shivering problem at while idling. Along with that engine is switching off while car is in running condition and I am coming to a lower speed and gear is in neutral position. My battery is old about 3 years is it happening due to battery problem? Please help with your suggestions.
Thanks and Regards
dibbasu
dibbasu is offline   Reply With Quote
Old 27th July 2008, 18:46   #2
Jaggu's Avatar
Thanked: 7,477 Times
Check your injectors and throttle body first, if filter is new and there are no leaks.
Old 27th July 2008, 19:10   #3
aaggoswami's Avatar
Thanked: 1,427 Times
IMO, there is some problem related to engine getting fuel.
aaggoswami is offline   Reply With Quote
Old 27th July 2008, 21:13   #4
GTO - Touring's Avatar
Thanked: 13 Times
Could be a malfunctioning spark plug too. Have that checked alongwith the injectors, throttle body, fuel pump, fuel filter & air filter (for clogging).
GTO - Touring is offline   Reply With Quote
Old 27th July 2008, 22:33   #5
normally_crazy's Avatar
Thanked: 387 Times
Injectors or the Throttle body - get those checked asap.
normally_crazy is offline   Reply With Quote
Old 27th July 2008, 22:50   #6
PJSPEED's Avatar
Is this 1.8T or 2.0L engine??????How the RPM behave at idling????
PJ
PJSPEED is offline   Reply With Quote
Old 28th July 2008, 09:57   #7
That's 2.0L BBS. RPM is shoots up a little between 1000 and 1200 but comes down under 1000 after a second or so. I have seen this behaviour earlier also before this problem surfaced.
Thanks GTO; fuel and airfilter has been changed a week back so I don't think they are the culprit. I will check the injectors and throttle body.
BTW it doesn't happen after I drive it for 30 mints or so at a little high speed (>80 KMPH).
Any clue?
Dibbasu
Note from the Team-BHP Support Staff : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
Also use "Multi Quote" option for quoting Multiple posts.
2009 Skoda Fabia Diesel 1.4 TDI - 93K KMs - Engine Crank shaft problem KishoreC Technical Stuff 37 14th January 2017 09:59
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
Skoda FSI Engine, More powerful Diesel engine, new VW/Audi Platform? rangaraj The Indian Car Scene 7 5th September 2005 11:24
