Old 28th July 2008, 14:01   #1
ssjr0498's Avatar
Thanked: 120 Times
Default Steps to take before cranking (car lying idle for a year)
Hi All,
As I prepare to visit my parents who are returning from the US to Kolkata after a year or so. I realised that in my garage in Kol, lay my old war horse, a 2001 Zen Vxi (MPFI) about which I had totally forgotten.
Now, I plan to bring it alongwith me to Blore this time and yeah! I am planning to drive it from KOL
My question to all the gurus on the forum is:-
As this car has not been cranked for more than a year, what all steps should I take so that I dont wreck the engine. I had disconnected the battery mains before coming, so one thing that I know is! To get the battery recharged.
What else! please advice!
Shrey
ssjr0498 is offline   Reply With Quote
Old 28th July 2008, 14:09   #2
khan_sultan's Avatar
Thanked: 3,872 Times
Easiest way: Approach a Maruti Service Station, tell them about the situation and get them to your home.
They will for sure check everything out and will take very reasonable rates (assuming that you don't tell them that you have just landed from US in american accent :-) ).
khan_sultan is offline   Reply With Quote
Old 28th July 2008, 14:17   #3
ssjr0498's Avatar
Thanked: 120 Times
Nice one! Still! what are the precautionary steps that one should take, assuming there is no way out other than driving the car to the service station.
Shrey
Old 28th July 2008, 14:36   #4
Rudra Sen's Avatar
Thanked: 4,295 Times
Try to reach Kolkata early to spend some quality time with your old warhorse. Few steps I suggest here. More than these you’ll get from all auto gurus.
1. If your car is standing normally on tyres then there is a chance of getting dead patches on tyres.
2. Get your car serviced. Clean fuel line. Tell service station to clean injectors and all fuel related parts.
3. Check electrical lines. Any brittle or rat bitten wire.
There could be more as you go along. Lastly, drive down safe.
Old 28th July 2008, 14:45   #5
tsk1979's Avatar
Thanked: 16,422 Times
Since you disconnected battery, the recharge issue won't be there.
If you find rats, don't crank the engine, get it towed to the service station. Don't take the risk of cranking as rats are the worst pests your car can get
Apart from that, inside you will find fungal deposits, get them removed.
With no pest infestation here are the steps.
Manually push the car up and down for the suspensions benefit.
roll the car back a little, check for flat spots. Your car won't have much air left. So remove all old air, and refil air.
Connect battery, and crank. If she cranks good, if she does not, jump start using a good battery.
Let her idle for 2-3 minutes with blower on(no AC), then switch on AC and see if you smell anything foul. If the smell is bad, cooling coil has fungus, so dashboard has to be opened.
After idling for 15 minutes drive around a bit, and take her to the service center for "all fluids" change.
Old 28th July 2008, 14:47   #6
planet_rocker's Avatar
Thanked: 368 Times
Slightly OT:
@ Shrey - where in Kolkata do you stay? if you are not able to get it checked at MASS, then please try to get in touch with Alok da & / his son, Suman (Shazid) of Alok Automobiles, Maruti Bagan off EM Bypass. Alok da used to work with Mr. Niaz Ali and his son is doing a great job as well. Most of the Kolkata TBHP gang will rate him No# 1.
Alok Atumobiles is a Hyundai A.S.S but they do work on Hondas, FIATs, Suzukis, etc unofficially. Alok da / Suman (Shazid) is associated with Bengal Motor Sports Club - so they know their work.
planet_rocker is offline   Reply With Quote
Old 28th July 2008, 14:57   #7
gd1418's Avatar
Thanked: 656 Times
Last but not the least, you shall get more tips from our more learned bretheren, open the plugs and pump in with an oil can some clean fresh engine oil since the innards would be bone dry and you wouldn't want to crank a very very dry piston.
Old 28th July 2008, 15:01   #8
Sideways's Avatar
Thanked: 18 Times
In additon to what everyone else has already mentioned: -
1) Check all fluids - oil, water etc. before you crank the engine.
2) Petrol has a shelf life. Since your car has been standing stationary for this long, I would recomend draining out all the fuel and refilling with fresh petrol.
Sideways is offline   Reply With Quote
Old 28th July 2008, 15:04   #9
ssjr0498's Avatar
Thanked: 120 Times
Thanks @planet and task! will keep all of this in mind.
But what would you say about the following
1.condition of the engine oil (Magnatec is what I always filled)
2.Gearbox oil
Also, I had changed all 5 tyres last year before leaving, would overflating them and running them for a while help! if they have had flat spots!
OT:
@planet: I am planning to come a bit early and if viable will try and get my vtec to kol. Lets have some drags with the skoda's the baleno's n all! what say!
I have been longing to meet enthusiats like yourself and other Tbhp members. I guess this time it will be.
I used to stay near Kalamandir but shifted to New Alipore. I know the owner of Autokraft (Parnasree,Behala) so will have him do all the stuff that you guys have suggested.
I am confirmed that keeping in mind the Kolkata weather (hot and humid) the a/c will have fungus. I can only keep my fingers crossed for rats!! When in Shakespeare Sarani I would have been sure that there would have been no rats but here! I hope they haven't had a look at my car.
Cheers,
Shrey
Is it necessary to wait for Glow Plug light to go off before cranking a Diesel? IndigoXLGrandDi Technical Stuff 56 25th October 2013 19:51
Are Cranking Handles Practical For Starting Old Cars? anjan_c2007 Vintage Cars & Classics in India 27 6th April 2011 01:04
Toyota Supra Lying Since A Year....Sad - now with pics Cyrus43 Super-Cars & Imports in India 63 12th August 2010 22:55
Cranking the car when the engine IS currently running - What happens? dsinz Technical Stuff 18 4th November 2006 08:04
Indica Turbo - Idle for one minute before shutting off? nikkibike Technical Stuff 12 24th August 2006 21:44
